Question about Pioneer AVIC-S1 GPS Receiver
This unit has not been upgraded since it was new. Is there any thing that I can do?
    Sniper:
  • 54 Answers
Nothing, until you find mulfunction
Posted on Mar 28, 2011
I want to do an upgrade on my Garmin Nuvi 255W.
UpGRADE or UpDATE?
Upgrade, sell the old one and buy a new one.
Update, Register the unit on the Garmin site. Download Garmin Express to your computer. Connect the unit with a mini-D charging lead and you can take software upgrades. For map updates, it depends as some are free and some are on a subscription.
http://software.garmin.com/en-CA/express.html
Feb 05, 2017 | Garmin GPS
Tip
How to fix a hanged/frozen/non responsive Pan Digital Novel E-Reader
If your Pan Digital Novel Reader... does not respond or hangs, it means the unit/device has frozen. This is a software/OS (operating system) problem.
Usually, resetting should do the fix. To reset, push the hole at the back of the unit with paperclip and the unit will reset. But if you have reset the unit by pushing the small hole at the back with paperclip (which means reset) and that seems not to solve the problem, then it means the operating system of the unit is corrupt. This is a software problem and to fix this problem, you need to install the firmware for your unit.
Firmware helps to remove the corrupt software and re-install a new one. Your unit will be as new once this is done.
Upgrade via PC
This option is for Windows PC only at this time.
With this method, you must connect your pandigital novel to a PC and then run a downloader program which automatically downloads the firmware to your device.
1. On your computer, go to www.pandigital.net/downloads.
2. Choose the "Upgrade with Your PC" option.
3. When asked to Save or Run, select Run.
4. Follow the prompts in the Upgrader window to download the firmware into your device.
5. After the download is complete, turn your device off.
6. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
7. Your device is upgraded and restarts automatically.
8. In the Language setup screen, tap Save with English selected (other languages will be available in future firmware upgrades).
9. In the Date/Time screen, if necessary, tap in the Time Zone, Date, and Time fields to set the correct time for your location. IMPORTANT: In order to connect with your Barnes & Noble online account, the Date and Time must be set correctly according to your location.
10. Tap Save.
11. The HOME screen is displayed.
Re-Upgrade
If you have previously performed a firmware upgrade to your device using one of the above methods, we recommend that you move the existing upgrade file into a different folder before performing another upgrade, which allows you to revert back to the existing version if desired.
1. Connect the device to your computer.
2. In a Windows Explorer or Finder window, create a new folder titled Firmware, and then copy the existing upgrade file into the Firmware folder. (The upgrade file is named similar to SYY_MM_DDK_PD_INX7E_ENG_6410POP.)
3. Perform the new upgrade using one of the methods above.
Revert back to Previous Version
2. In a Windows Explorer or Finder window, delete the upgrade file from the root, and then copy the upgrade file from the Firmware folder back into the root of the device.
3. Turn your device off.
4. Press the Volume + key plus slide the power key on simultaneously for 5 seconds, and then release both.
5. Your device is upgraded again and restarts automatically.
6. Follow the prompts to re-set your language and date and time.
I hope you found the above helpful.
Regards.
on Sep 27, 2011 | Tablets & eReaders
How do i update map and software data online for my trax 430
Hello.
HOW TO UPGRAGE SOFTWARE ONLINE
If you are used to using an atlas or other map, you probablyalready know that new maps are issued each year because of changes on theroads. The same thing applies to the maps on GPS units. This means that if youhave a GPS unit, you need to update your GPS software regularly to make surethat you have the latest information. Each GPS manufacturer makes softwareupgrades available for GPS unit owners. Here are tools and instruction below
USB cable (as tool)
1 Visit the website forthe manufacturer of your GPS unit, such as Garmin or Magellan.
2 Go to the"Support" section of the site and then the "Downloads"area. This is where the latest upgrades are available for download.
3 Log in if you already havean account or key in the serial number of your GPS unit. Typically you get onefree upgrade on your unit, which is tracked by the serial number, which is whyyou have to enter it or have an account.
4 View the latest softwareupdates once you are logged in or have entered in the serial number. If you areeligible for the free upgrade, you will see it listed with no cost. If not, youwill see a price listed by the upgrade. Prices vary by manufacturer andupgrade, but average around $80 as of 2010.
5 Download the upgrade to yourcomputer or order the upgrade disk. According to CC Electronics & Gadgets,there is no difference between the two upgrade files. If you want to do animmediate update to the unit, you should download the upgrade instead of waitingfor the disk to arrive by mail.
6 Connect your GPS unit toyour computer with the USB cable that came packaged with it. When you do, theGPS update software will launch on your computer. If you have never installedthe GPS software onto your computer, you will need to use the disk that camewith the unit to install it so that it will launch for you.
7 Confirm that you want tosync the unit with the upgrade file that you download, or on the disk if youare using a disk. This will install the upgrade to your GPS unit. When itcompletes, you will get a message on your screen letting you know that it isdone. You can now disconnect the GPS from the computer. Thanks
Sep 18, 2011 | Uniden TRAX-430 GPS Receiver
How can i upgrade my av 302 to becomes best as konzert av-502
upgrade your 302 to 502 need to replaced the toroid transformer, set of output amplifier, set of electrolytic capacitor.
Purchasing of these parts one-by-one is much expensive rather that you buy a brad new Konzert AV-502. Also upgrading the unit is quite tech and need a lot of experienced in electronics.
Hope that it may help you.
Have a nice day.
JDVillanueva
Jan 31, 2011 | Audio Players & Recorders
Need to replace Panasonic AC electrical cord.
If the burn is near the end I would put a new plug on it and run it. If it's near the unit I recomend replacing the cord. You need to find out why the cord burned through in the first place. There may be a problem on the circuit that needs to be resolved before plugging the unit back in. Do you have very many things on the same circuit the unit is on? If so the wiring either needs an upgrade or you will need to plug some things into different places.
Aug 11, 2009 | Panasonic CW-XC84HU Air Conditioner
Looping after free map download
What free maps are you talking about? All updated maps I could find for mine cost money.
If these maps are provided by other users, is there a chance that they could be corrupted, making the Tomtom unable to read it?
Aug 02, 2009 | Tomtom Go 630 GPS Receiver
Upgrading processor
Contact the manufacture and ask them the following
whats the fastest processor i can put in my unit
whats the socket type for my chip
whats the brand
once you have this info you can order a new chip with out worrying.
codebluestore.com we can order the right one for you if you wish
phone 3868487115
Apr 01, 2009 | Gateway 500 X PC Desktop
Motorola V3 battery suddenly empty
You really need to Upgrade to a New Phone. My RAZR did the Same thing for over a Year and a Half until the Flip screen went Completely Blank.
Jan 04, 2009 | Motorola Mobility RAZR V3
Firmware upgrades
Installing/upgrading firmware is usally not requemented. You will not be adding any new feature to u're unit. There's no reason to do reinstall or upgrade the firmware other than to repair the unit in the event the units firmware is corrept.
Johnny Delstar
Apr 26, 2008 | Delstar DS 31024 MP3 Player
Dell Dimension 4100 Mobo upgrade to a P4 based system
Well the two would not be compatible cause one is a P3 and the next is a P4 two completely different socket types so it wouldn't work but what u can do is buy a new motherboard if u want to upgrade to a P4...thats the only thing that is recommended from such a devices cause an upgrade wouldn't be possible to do .
Nov 22, 2007 | Dell (2336V) Motherboard
Pioneer AVIC-S1 GPS Receiver Logo
16 people viewed this question
Top Pioneer GPS Experts
Marvin
Marvin
David Burbee
David Burbee
Are you a Pioneer GPS Expert? Answer questions, earn points and help others
