Question about Measuring Tools & Sensors
The back plastic part of my stapler the one the pushes the staples in need to be replace (light green color) the rest is black Model #90002
    Novelist:
  • 157 Answers
Hello. The stapler is manufactured by Swingline. Here is the link to their contact page.
http://www.acco.com/contactus.aspx
If this helps, please rank it a four-thumbs up. Thank You.
Posted on Mar 28, 2011
Just bought and tried to load my Swingline Smart Touch low force stapler. Don't know how to get it opened
I have one of these models. Just push the gray lock mechanism at the end of the stapler and the loading magazine will pop out. The chrome plated magazine opens towrds the front....it slides forward and backwards.
Jun 17, 2011 | Office Equipment & Supplies
How do you add staples to a swingline 8784x stapler
You need to remove the black cap at the back of the stapler, then use a screwdriver to press down on a lever inside the stapler. The stapler holder will pop out at the front, then pull it further out and load with staples. May be an easier way, but this what worked for me.
May 20, 2011 | Office Equipment & Supplies
I can't seem to reload staples into this stapler. I used the staples that came with it and it worked fine. I try reloading and it doesn't staple.
With the stapler sitting a solid surface, turn it 180 degrees so it is pointed away from you, and you are looking at the back. Press down on the plastic extension that you see (about mid-height on the stapler). This releases the staple-holding compartment (it shoots out the front of the stapler). Reload it with standard staples, push the compartment back in place until you hear a click. Voila!
Apr 15, 2011 | Staples One-Touch DX-3 Desktop Flat Stack...
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
I just received the Swingline SmartTouch Stapler, but the problem is ... I CAN'T FIGURE OUT HOW TO OPEN IT TO LOAD STAPLES. It's getting rather frustrating. What's the trick?
I can solve it!!!!!!!!! Remove the clear tape at the front of the stapler...the tape you cannot see, and push from the back of the stapler! Please note on the bottom of the box......it reminds you that this stapler does not come with paper or staples!!!
Mar 30, 2011 | Office Equipment & Supplies
How do put staples in this stapler?
vaduvur.jpg1. Hold the black handle -- top part -- of the stapler with your right hand thumb and forefinger. 2. Hold the metal casing right beneath the black handle, with your left hand thumb and forefinger. 3. Use your left hand thumb and forefingers and a wedge to separate the top black part and the metal casing beneath it. 4. Bingo!
Note: Switching the two different operations on to the other hand is unlikely to work.
Mar 14, 2011 | Swingline 87845 Optima ® 40 Desk Stapler
How do I replace the staples in Stanley Bostitch B310HDS? I cannot seem to figure out how to open it.
"The staples load from the rear of the stapler. At the back end of the is a piece of black plastic that extends beyond the end of the stapler. This device holds the staples inside the stapler. To open the area where the staples are placed, push this extended button and lift up on it. The spring device that holds the staples inside the stapler will then slide out. Place a new strip of staples inside the stapler on top of the two metal guide rails. Then insert the spring device to lock the staples in place. The stapler is now loaded and ready to work. " hope this helps you out
Jan 06, 2011 | Stanley Bostitch 00540: 00540 AntiJam ?...
WHERE do I open it to refill it??
Located on the end opposite of where the staples come out, there is a spring loaded cap. Push it in toward the base of the stapler and slightly down to release the retaining hook. then let the spring release the pressure rod and pull it out. Connedted to the end of the rod you will see a plunger that is shaped like a short run of staples. Make a mental note of how and where this plunger slides into the base of the stapler. Place a run of staples into the stapler in the same manner that the plunger fits then replace the plunger into the same place following the run of staples. Compress the spring into the stapler and attach the hook as it was. Now you are ready to work.
NOTE: If you cannot compress the spring enough into the stapler you have inserted too many staples, just remove some of the run of staples and try again.
Nov 12, 2010 | Arrow T50P ARROW STAPLE GUN
How do i load the staple gun?
1 Hold stapler upside down.
2. Release black plastic catch at rear and pull out.
3. Drop staples into bottom of gun, with open side up.
4. Push black plastic catch closed and latched.
wallyp
Oct 30, 2010 | Stanley Bostitch Pc4000oc2 Outward Clinch...
How do you open the optima powerease stapler to add more staples?
Push the black half-oval button at the hinge to release the staple cartridge. Extend the staple cartridge from front of the stapler, add staples, push back in.
Jun 25, 2010 | Swingline 87850 Optima PowerEase ? Full...
Measuring Tools & Sensors Logo
225 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
