Question about Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
Put on the belt deck - Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut
  • 3,740 Answers
Hi nd welcome to FixYa, I am Kelly.
The installation steps can be found in the following pdf file:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_532432802.pdf
See page 21 for the "how to" and page 19 figure 27 for complete routing pattern.
Thanks for choosing FixYa.
Kelly
Posted on Mar 28, 2011
I HAVE A CRAFTSMAN 1000. I AM TRYING TO PUT NEW DRIVE BELT ON AND CANT.DO I NEED TO TAKE DECK BELT OFF TO DO IT?
most probably as most drive belts are above the deck belt owing to the fact that the deck height can be shifted
Jun 21, 2016 | Craftsman Garden
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
A diagram of deck belt on deck 46 inch cub cadet
Look here then when you put in your Model number look under ATTACHMENTS for a parts diagram showing the Belt layout
http://www.cubcadet.com/webapp/wcs/stores/servlet/ARIPartFinderView?storeId=10051&catalogId=14101&langId=-1#/s/CUT/782/
Jul 27, 2014 | Cub Cadet Garden
What kind of lubricant fdo you use on treadmill decks
Silicone spray. Did you put it between the deck and the underside of the running belt? Not on the surface of the belt ( where you walk ) . if you put in on the top of the belt , then this is why it is slippery.
Nov 24, 2013 | Bh Fitness TS1 Treadmill
Why dose my john deere ltr 180 have smoke near currung deck when i put the cutting deck down
the only thing other than a frozen pulley it could be check the routing of the belt it is rubbing somewhere.
Sep 08, 2017 | John Deere Garden
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Do you have a diagram on how to put on a craftman belt, like a picture, got the belt on, but not engage some where in the middle not right.... it a 38" deck
You have to (or should) take your deck off before putting on the new belt. If there isn't a schematic on the deck go to this website:
http://www.searspartsdirect.com/partsdirect/index.action
and look up your tractor number. Should give you a good idea of the routing. While you have the deck off, clean out all the debris around the pulleys and tensioners.
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Husqvarna cz 4815 diagram to put deck belt back
there should be a routing diagram sticker somewhere on the deck. look at the back side of the deck in the middle
Aug 24, 2009 | Husqvarna Garden
Deck belt need to no how to put the belt on
How to install a belt for a poulan riding lawn mower deck S#120403A001222 15.5Hp 38" 5sp
Jun 26, 2009 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Husqvarna Riding Lawn Mower Yth24v48ls 48 Inch Cut Logo
76 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
