Tak boleh menghantar video..
First check for any possible reason why FB
disable the account then contact their
support number or email them
Please review Facebook's Statement of
Rights and Responsibilities to learn more
about specific types of conduct and
content that are not permitted on the
site.
Via The Facebook Website:
You can report a bug via the Facebook
website by following these instructions:
1. Click on Help Center in the bottom
right hand corner of your screen.
2. Click on the Topic that most closely
relates to the problem you are having.
You may need to drill down a few times but
you should eventually see the link in the
next step.
3. Click on Bugs & Known Problems.
4. Click on "I'd like to submit a bug
report".
5. Click the link in this statement
when you see it, "Please submit bug
reports only here".
6. Fill out the form and submit it.
Here's some email addresses:
Send an email to these:
[email protected]
[email protected]
[email protected]
[email protected]
[email protected]
My Personal Profile was Disabled
http://www.facebook.com/help/contact.php?
show_form=disabled
Hope I help you a bit.
Your's Truly,
Christian from HP
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
