Question about Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer
When i try print the label..no output at the label..how to test whether the ink is function or not
  • 436 Answers
I'm including this link to the users manual:
http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html
But here is the basic troubleshooting info for that issue
No print on the label.The media may not be direct thermal media when printing without ribbon (i.e. thermal
transfer). See the test procedure
Determining Thermal Media Types on page 29.
• For thermal transfer printers, the media may not be outside wound or approved for use in
the G-Series printer. See the following ribbon test procedures: Ribbon Test with Adhesive
on page 32
and Ribbon Scratch Test on page 33.
• Is the media loaded correctly? Follow the instructions for
Loading Roll Media on page 11
in the Getting Started section. For printing using transfer ribbon, see
Loading Transfer Ribbon
on page 14.
Posted on Mar 28, 2011
Why are my labels coming out grainy while printing?
check your ink status.You may be needing more ink. Follow the instructions when putting new ink in and do a test page.That might help
Apr 03, 2016 | Kodak Office Equipment & Supplies
I replace my cartridges it says refer to printer documentation and will not print
These types of severe HP 74 black or HP 75 color ink cartridge errors (i.e. refer to documentation / incompatible cartridges, print cartridge(s) problem, etc.) typically indicate the internal micro electronics of the respective HP 74 black or HP 75 color cartridge are damaged. The cartridges electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal micro electronics failure. I suggest you first run a Tap 41 diagnostic test to check cartridges electrical health (this is a special forced service test, refer to video so you understand how to read the print out). You may also bypass the error (temporarily) on most models which use HP 74/75 cartridges.
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B. Print Self Test Page:
1. Press and hold the CANCEL button.
2. Press the COLOR COPY button. Release both buttons.
3. The self test page should print. The printed pattern will verify printer is generally functional
--- The self test page is a 'forced' test print whether the ink cartridges are good or bad. Inspect color bars to verify proper nozzle/jetting health. If normal/regular printing is still not permitted then the problem is with either one, or both, of the ink cartridges. Activate Tap 41 test to confirm which cartridge is causing the issue.
C. Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to video procedure or .pdf document at the following links on how to activate and read the service test report: http://inkjet411.com/?page_id=536
1. Load Letter/A4-size paper into paper feed tray.
2. If any lights are blinking, first press Cancel to attempt to clear.
3. Press and HOLD the Cancel button, press Ok button once.
4. At 'Mfg Commands' menu, click Right Arrow once until 'uiaux service' menu is displayed.
5. At 'uiaux service' menu, click the Right Arrow until Special Reports menu is displayed.
6. Select Ok, then click Right Arrow until the 'print-mech button tap' menu is displayed.
7. Select Ok (Code = 0 will be displayed); click and hold Right Arrow until 'code = 41' is displayed. Use the Left Arrow if you need to decrease numerical count.
8. Select Ok. Within one minute the Tap 41 diagnostic test report should be initiated and print (whether ink cartridges are good or not, i.e. this is a forced print test). See following 4 paragraphs (or video) on how to interpret diagnostic report.....
NOTE: You may also refer to this document for specific printer model 'Tap 41' diagnostic & 'Cartridge Error Bypass' step-by-step instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
--- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 75/75XL color cartridge should display 600 good nozzles, while a good HP 74/74XL black ink cartridge should show 672 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to video on how to read the printout.
---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
You can also test general printer performance by running the 'Tap 10' diagnostic test, use same procedure above and enter "code = 10". Both the 'Tap 41' and 'Tap 10' tests are 'forced print tests' - the printer will make every attempt to print the pattern whether the ink cartridges are good or bad...the patterns should be utilized to diagnose cartridge health. If 'regular' printing is still not possible then one or both of the ink cartridges is damaged.
ERROR BYPASS OPTION (TEMPORARY ONLY):
NOTE: It is possible to 'temporarily' bypass the cartridge error message (for emergency printing purposes only), please refer to link above/below for video/documentation instructions: http://inkjet411.retailinkjet.com/wp-content/uploads/2013/04/HP-74-75-Problem-Resolution_v10.pdf
However, if the cartridge is determined to be electrically damaged, largely dependent on the 'Tap 41' diagnostic test results, the cartridge will eventually need to be replaced with a new one. With a marginally performing ink cartridge, this typically results in allowing 1 entire print job to be printed at a time. If this does not permit any print operations then the cartridge has severe internal electrical damage and will need to be replaced.
*Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process. The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active electrical state of both cartridges.
For additional printer diagnostics information please visit: http://inkjet411.com/?page_id=1813
NOTE: If you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our internal labs have verified there are no issues (with ink compatibility or color output/richness) with all of these models: http://inkjet411.com/?page_id=3585
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors. We do NOT suggest refilling these types of ink cartridges.....refilling of HP 74/75 original/genuine ink cartridges is only suggested!
HP 74/75 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=WqnHRFpbo0w
If you ever need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty and free shipping over $20 (products available to US residents only).
HP 74 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2074
HP 75 Cartridges:
https://inkplicity.com/shop/?slug=advanced_search_result&keywords=HP%2075
For any additional questions please contact us directly: Inkjet411help@gmail.com
-Thank you
May 21, 2015 | HP Photosmart C5280 Printer
The light next to the ok button keeep blinking and the photo butten light stay on ..the screen says refer to printer documentntion
Regarding your recent inquiry about the HP Photosmart C5280 printer which uses HP 74 & HP 75 cartridges, and error message ("Refer to Device Documentation") and inability to print, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside one of the cartridges (please note is very rare for both ink cartridges to electrically fail at the same time....activate diagnostics below to confirm which cartridge is causing the error condition)....or refer to the Inkjet411 website and select you printer model (...the Inkjet411 site is primarily a self-service sitelet which provides over 85 technical videos and do-it-yourself printer remedies and corrections): http://inkjet411.com/
An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do!) occur with brand new ink cartridges and normally occur over time due to natural degradation of the internal micro-electronics.* To help identify the root cause, and to confirm which of the two ink cartridges is causing the failure condition, please run the 'Tap 41' cartridge's electrical diagnostic test below (refer to PROCEDURE C.)
NOTE 1: Your Photosmart printer model must have two (2) good ink cartridges installed to operate/print (unlike all HP Deskjet printer models which may operate using only one (1) ink cartridge).
IMPORTANT: First verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can (and frequently do) occur due to prolonged internal corrosion of cartridge micro-circuits, etc.
NOTE 2: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
* The "Incompatible Print Cartridge(s)" / "Print Cartridge(s) Problem" / "Refer to printer documentation" / "Cartridge Error: Cartridge must be replaced" / "Cartridge in left/right slot is not intended for use in this printer" / "Now printing alignment page" error messages are typically indicative of failed micro-electronics internal to the ink cartridge(s). Also note that it is common to have a marginally performing ink cartridge (which was performing ok before) in the adjacent slot (i.e. color), then when a marginally performing cartridge is installed into the other slot (i.e. black), both of the ink cartridge(s) then get flagged with electrical errors. Running the 'Tap 41' cartridge health diagnostics test will confirm the active electrical state of both cartridges.
For additional HP printer diagnostics information please visit: http://inkjet411.com/?page_id=1813
Please let us know if you have any additional questions regarding procedures outlined above and/or questions relating to the provided technical information. If you are interested in the top 'refill friendly inkjet printer models', our suggested list is posted on-line and our Inkjet411 internal labs have verified there are no issues (in ink compatibility or color output) with all of these models: http://inkjet411.com/?page_id=3585
INK CARTRIDGE REFILL SERVICES:
Costco USA (464+ stores): http://www.costcoinkjetrefill.com
Costco Canada (62+ stores, more coming soon): http://www.ca.costcoinkjetrefill.com
Costco United Kingdom (7 stores):http://uk.costcoinkjetrefill.com/
Costco Mexico (35+ stores): http://es.costcoinkjetrefill.com/
Fry's Electronics (34 stores): http://www.frys.com/ads/page195
Best Buy Canada (13 stores): www.geeksquad.ca/inkrefill/
10 Major Universities in USA & Canada
Ink Cartridge Refill Store Map Locator: http://www.go2ris.com/
Alternatively, if you need to purchase a new HP 74/75 ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating and provide a 1-year warranty and free shipping over $20 (products available to US residents only).
-Thank you
Inkjet411 Team Member
Jan 12, 2015 | HP Photosmart C5280 Printer
What can i do my brother dcp j125 printer not function black ink
Check whether the ink tubes from the ink to printhead is filled with black ink. Bubbles also will cause it not to print. Always use original inks for trouble free usage.
Oct 20, 2014 | Brother Office Equipment & Supplies
Need help in fixing HP Photosmart C5280 Printer two springs on the side of carriage bar
We suggest you contact 'Parts Here' as they provide most parts for the C5280 printer, including carriage assembly parts, along with the C5280 service manual: http://www.partshere.com/models/hpprinters.asp?printer=Q8330A
C5280 CONTACT CLEANING / SERVICE TEST DIAGNOSTICS:
A. Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding - refer to Inkjet411's support page: http://inkjet411.com/?page_id=1519
NOTE: If you need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (available for US Residents only).
-Thank you
Oct 15, 2014 | HP Photosmart C5280 Printer
Ptouch weak printing
You need to take a q-tip dipped in alcohol and clean the printhead. Let me know if this helps.
Lou
Sep 09, 2008 | Brother P-Touch 1180 Label Printer
Oki 320 Turbo -- Unclear characters in output
If it is not the ribbon, you may have to replace the print head.
Genuine Okidata Print Head
Mfr Part #:
50063802
Hope that helps...
Jun 21, 2008 | OKI MICROLINE 320 Turbo Matrix Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Possible print head failure
to test , press pause botton and turn on (press 5 sec.)
he print a "pause test".
check if print, if stop on ich gap and if come some lines across the print (if apear some lines, need new print head.) this step just pause wen print some labels, and then still print until turn off.
Turn off and turn on the printer to work normal.
To calibrate media, go on the setings to "sensor profile" and/or "run manual calibration, follow the steps. (dont forget to take the ribbon from the sensor.)
let the test run until finish.
May 02, 2008 | Zebra Z4Mplus Label Printer
Zebra GK420t thermal transfer and thermal direct label , EPL and ZPL language, 4" 203DPI prin... Printer Logo
445 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
