Question about American Standard Traditional Champion4 2034.004.020 Whit
How tight should I tighten the tank to the bowl on the American Standard Champion Toilet?
    President:
  • 1,489 Answers
There is no torque value as far as I know. There should be rubber washers to minmize the chance of cracking the ceramic and to provide a water seal.
But to try to give some sort of guideline, on a scale of 1 - 10, I'd say a 6 would be about right -- or perhaps you could call that medium tight. In any event, the bolts have to be tight enough to prevent leaking -- if it leaks, you'll have to keep tightening.
Charlie
Posted on Mar 28, 2011
  • Samuel Charles Spriggs Mar 28, 2011
    I must ask what is the correct answer -- perhaps I can learn from you.
    Charlie
Hello, I have an old American Standard toilet (1985) and one of the bolts that holds the fill tank to the actual toilet bowl is leaking......
Yes, those parts are a 'Standard' (excuse pun) part. Replace them both and the seal between the tank and bowl. Buy a small tube of silicone too. There are bound to be videos of how to replace. It is fairly straight forward. Don't overtighten the bolts, finger tight and a quarter turn.
Sep 29, 2016 | American Standard Home
How to tighten an american standard toilet seat
They all work pretty much the same. Feel around the top rim of the bowl near where the tank meets the bowl you should find one bolt underneath on either side of the toilet seat. Tighten the nut under there to tighten the seat.
Oct 24, 2013 | American Standard Church Seats EL270...
I am installing 2 new american standard champion 4 toilets and on both of them the tank will not sit on the base. the thick rubber gasket seems to be too thick to allow this. i don't want to crank down too...
The reason the tank doesn't sit down on the bowl is cause it's not supposed to just sit flush from the start. Your suppose to tighten the tank bolts down in order to get a water tight seal. There is also these little rubber " U " shaped things that sit on the porcelain lip on the back of the bowl thats what's there to protect it from cracking when you tighten the bolts down. Just place 1 on the right side and the the other on on the left side. and tighten down 'til the tank touches the bowl.
Nov 17, 2010 | American Standard AMERICAN STD 12 RGH...
I had an American Standard Cadet3 Right Height Elongated toilet installed. After flushing, water level in the bowl drops to a very low level. Enough remains to prevent gasses or orders, but just enough. I...
Adjust the water setting of the tank to higher level, meaning an additional water will be added to the tank. The purpose of this is to release extra water that will fill the missing water level in the bowl.
Nov 10, 2010 | American Standard 2002.800.021 Champion...
Problem: water tank running water and refilling itself
probably the flapper valve is not seating correctly over the outlet. you can fix it by reaching in and twisting the valve one way or the other till it seats properly and the leak will stop.
May 08, 2010 | American Standard 2004.014 - Champion...
How much draw down (tightening) do use to attach the water tank to the toilet bowl on a American Standard Flowise Cadet 3 toilet? Does the tank need to meet the bowl?
Seat the tank well on a new wax ring and then tightnen the two bolts on the sides evenly there is a small amount of pressure but thats it. To much and you'll snap the side of the bowl. You can caulk around the edge if you want more security,less movement.
The tension on the nuts is very tricky just a feel kinda thing.
Be carefull not to over do it.
Sep 04, 2009 | American Standard Cadet 3 Right Height...
Champion4 leaks water through flush valve
You have replaced the flush valve completely? If so and the unit is still leaking, you may have a small crack in the tank or your just not getting the tank to bowl fittings tight enough. Also, they make two different thicknesses in the tank to bowl gasket. Make sure you are using the thicker of the two. You posted this under the American Std. thread, so if this is correct, give them a call. There could be a recall on this particular toilet due to a flaw.
Apr 04, 2009 | American Standard AMERICAN STD 12 RGH...
American standard toilet
I have the American Standard Champion 4 toilet. Water is leaking from the tank to the bowl causing the toilet to refill. I've replaced the flapper and cleaned the surface the flapper contact. Nothing seems to work.
Nov 09, 2008 | American Standard 2002.014 - Champion4...
American Standard Traditional Champion4 2034.004.020 Whit Logo
136 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
