Question about Dell 924 All-in-One InkJet Printer
How can i clean the inside of my dell 926 printer
  • 436 Answers
Here is the link to the user manual.
http://support.dell.com/support/edocs/systems/prn926/en/index.htm
If you are asking about how to clean out the indise, unplug first!!! get a can of compressed air at your local computer store or best buy and spray this inside to remove dust and bits.
Posted on Mar 28, 2011
How do I trouble shoot problems with color prinouts?
Inside printer when open righthand side You'll see a pad and set of brushes clean with clean rag, and run clean in printer options. Then run align cartridges. should solve problem. make sure when putting in ink you just snap in and not mess with after that.
Jul 08, 2014 | Dell 926 All-In-One InkJet Printer
My Dell 926 AIO Printer will not print after installing new ink cartridge. Ink level on computer still says empty.
you must cleaned cartridge before you plug on printer, for level ink detection you must waiting for moment for ink spread on cartridge.
Mar 09, 2011 | Dell 926 All-In-One InkJet Printer
Error 1203 for Dell Printer AIO 926
Ok Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jan 17, 2010 | Dell 926 All-In-One InkJet Printer
Installing 926 printer
First connect your printer to computer then your printer is found as new hardware then click on no at this time then select install driver manually then next then click on show all devices then browse and locate your driver folder.then next.
Also you can update driver in devicemanager for that right click on my computer then click on property then hardware ->device manager
then select your unknow device printer and right click on it then updste driver then browse abd lacate your driver folder.
Aug 11, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
I have a Dell 926 all in one printer and it will not take the paper at all and if it does it jams up inside please help!!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 27, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 printer
Go to Dell Journal ID: 08086MJJNF
Article ID: 316455
Date Published 1/4/2008
Last Revised: 3/25/2008
Go to www.dell.com and top right type in 926 printer; it will bring you to the next page, click on the first result: Install Dell 926 All-In-One Priter Drivers. This should help you. Follow all the directions exactly!
***Did you uninstall the first 926 driver before you did anything else. You must uninstall the first driver and install the driver for the second 926 printer.******
Mar 26, 2008 | Dell 962 Photo All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
