Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Where is the thermostat located on a frigidaire gallery model GLRS2642AQ6 Electrolux side by side. Keeps freezing up even after turning down both side to just cold.
    Scholar:
  • 116 Answers
Hi this is most likely the damper assembly not the thermostat, the damper assemly is on the left side of the refrigerator compartment in the very top corner up there, sometimes depending on the model this damper runs 3/4 of the length of the left wall there. This entire assembly needs changed.
Sean
Posted on Mar 28, 2011
Gallery. How do I lower the temp in food section?
Should be 2 thermostats in the unit in back or on side. One for freezer & one for fridge. Turn it down to preference.
Aug 01, 2015 | Frigidaire Refrigerators
Where are the inline fuses on the Electrolux Frigidaire double ovens?
I appreciate your post, Richard Balzer!
I see that you would like to know the location of your inline fuses on your Electrolux wall oven. I have located the wiring diagram and the parts manual for your wall oven. I do not see the location of an inline fuse. I hope this is helpful information. -Matt
Frigidaire Manual Search Results
Jan 18, 2015 | Electrolux Frigidaire Gallery 30" Double...
Why wont my dryer stay running?
Good Morning Friend,
I understand that your Frigidaire dryer, model# FEQ1442ES, will not stay running. Please check to make sure the door is staying closed. If the door is opening in mid-cycle, then the dryer will stop running. Also, make sure the plug is in the socket tightly. Your dryer could be shaking the plug loose, which could possibly be causing it to stop running. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire FEQ1442ES Electric Dryer
Refrigerator side is freezing.
The damper control which is the control for the refrigerator has gone bad not letting the damper door close to control the airflow into the fresh food section. the part number is 5303918283 at a price of about 245.00. To me this is rediculous but that is the manf suggested retail. It should be a crime to charge so much for this particular part. Soory on the cost but it is the problem.
May 28, 2010 | Frigidaire FRS26H5AS Side by Side...
My side by side refrig. keeps freezing everything. It is turned lowest setting. Model GLRS2677AW6
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | Frigidaire Refrigerators
Frigidaire gallery pro series model frs26zsh water leaks out somewhere goes into backside of freezer eventually goes down to underside of bottom basket and freezes
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
We have a Frigidaire refrigerator-freezer that started freezing our food in the fridge side trying to find out what might cause this?
Hello, Your problem is going to be with the cold control, it is not shutting down which is why the food is freezing, You did not supply a model # so am unable to see if theis has a thermostat or control board, will assume it has a thermostat. Most likely place to find it is where the know for controling the freezer is...usually inside the fridge. Replace this thermostat and you will be good to go...Thanks for using Fixya, if you have any additional questions or concerns please feel free to comment again. Good Luck!! Mike
Jul 26, 2009 | Electrolux Refrigerators
Frigidaire is freezing everything!
Possible defrost timer or thermostat failure.
Jul 11, 2017 | Frigidaire FRS26H5AS Side by Side...
Frigidaire FRS23H5ASB is too cold
Your thermostat is faulty and needs replacing
Mar 04, 2009 | Frigidaire FRS23H5ASB Gallery 22.6 Cubic...
Frigidaire Gallery Side by Side - Fridge not cooling
Locate the defrost timer and rotate the dial a small amount clockwise. If the compressor starts the timer should be replaced. If the compressor does not start check the temperature control. It may be bad, if it is bad try jumpering the thermostat wires. If it starts and runs the thermostat is bad. Replace the thermostat.
Mar 30, 2008 | Frigidaire FRS26ZSG
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
389 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
