Question about Gemini Sound Products Gemini Napco Gem-p800 Security Alarm System Keypad
Hello, We have a gem-p800, we wanted to change our user code 1, we followed the instructions, but now by changing the user code 1 (master code), we can not add or delete any other codes. We have one user code left, but it is not the user 1 code. What can we do to enter a new user code 1? Thanks, Nat
How to change code user 1 on a gem-rp8
I am in the same boat. We bought a house with this system installed in it. How can we change the user 1 code?
Nov 10, 2013 | Gemini Sound Products Napco Gemini Gemrp8...
I need to reset my combination to my mesa safe
This safe was shipped with a factory Master Code of 1-2-3-4-5-6-7-8.
If you changed the Master Code you will need to use the code you changed it to.
Deleting your current User Codes:
Input * - * lock will beep twice
input 6-6-6-# lock will beep twice
Input current Master Code - # lock will beep twice
Input user number - # lock will beep twice (not user code, user number is which user number you want to delete 1,2,3,4 or 5)
Re-input user number - # light stays green for 3 seconds
Example: * - * - 6 - 6 - 6 - # Master Code - # - 5 - # - 5 #
This will delete user 5
Unsuccessful code change: five beeps, repeat the steps.
Changing User Codes: Code length can be 3 to 8 digits long
Input 4 - 4 - 4 - # lock will beep twice
Input Current User Code - # lock will beep twice
Input User Number - #
Input New User Code - # lock will beep twice
Re-input New User Code - # light stays green for 3 seconds
Example: * - * - 3 - 3 - 3 -# - User Code 2 - # - 2 - # -New User Code - # - New User Code - #
That example will change user code 2.
Unsuccessful Code Change: five beeps, repeat the steps.
There are other things you can do with the MSL-500 lock that comes on the MFL-2014E. You can change the master code, activate user codes, change user codes, delete user codes, set single user or dual user modes (dual user modes requires two user codes to be entered each time you want to open the safe, set the time delay.
The Mesa safe company has a website which does have the operating instructions for the MSL-500 electronic lock. A Google search of "Mesa MSL-500 Operating Instructions" would get you there quickly.
Oct 18, 2013 | Mesa Safes MFL2014E Safe Depository Safe...
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
I have a Napco Gem-P800 Security System and the horn or horns have quit working. The manual says the horn output is 12vdc, checked voltage in alarm mode,but no 12vdc. The schematic shows a 2.2k resister...
First thing its not the resistor. The resistor is there only to make sure the siren wires are ok and not tampered with. Second found this in an install manual.
Bell Test
Enter this command to turn on the Bell, keypad
sounder and keypad LEDs for 2 seconds. The
battery is tested during a Bell Test, and automatically
every *24 hours to ensure proper battery
operation under load. The Alarm output
requires a battery in order to supply the specified
output. If the battery cannot sustain the load, a
low battery indication will be displayed. A battery
test is also performed on power-up after a 3
minute delay.
if the battery fails test replace it and try again.
Assuming no programming changes were made to the zone types that would diable the bell output. if this does not help, time for an upgrade. : ( GL
http://www.napcosecurity.com/images/panels/GEM-P800_WI850a_INST.pdf
Jul 27, 2011 | Gemini Sound Products Gemini Napco...
How do i set the ringtone on the samsung monte gt-e2550
You can change your sound settings by following the instructions below,
To change your sound profile,
1. In Menu mode, select Settings ? Profiles.
2. Select a profile you want.
To edit a sound profile,
2. Scroll to a user profile and press
? Edit.
3. Customize the sound settings as desired.
Regards,
May 15, 2011 | Samsung Cell Phones
Changing the alarm code on the gaurdtec 500 series alarm
For a guardtec 593
Programming User Codes
(Master code only)
system.
1) With the display showing ' Un ' enter a Master code
2) The display will show ' SE '
3) Press NO five times, the display will show ' Uc ' (flashing).
4) Press YES, the display will show ' U- '
5) Enter the User number you wish to program (1 to 7) followed by YES
6) The display will show ' Co ' Enter the required code (4, 5 or 6 digits) followed
by YES. (Entering 000000 will delete an existing code).
7) The display will show ' t- ' enter the code type from the following list
1 = Set Only 2 = Main User 3 = User 4 = Master followed
by YES. A full description of code types is given on page 3.
8) The display will show ' Uc ' (flashing)
If you wish to program other User codes return to step 4
Or
To return to the Unset condition press 0
this is for the led version.
Aug 27, 2010 | House Brand Intrud Alert House Home Alarm...
How do I unlock my sony ericcson p800 for free
To get the security code to unlock the cell phone from the current cell
phone provider so you can use it with a different phone provider, Please
click on this link and follow my instructions :-
http://www.fixya.com/support/r4049238-unlock_cell_phone
If your phone provider does not help you then this WEB site it provides security codes for a small price.
http://www.mobileunlockstore.com/?gclid=CKDb2_y2558CFSlJagodxBkDHw
Try this WEB site also - Unlock Free
http://www.unlock-free.com
May 19, 2010 | Sony Ericsson P800 Cellular Phone
Lock Code
Hello. This depends on which lock code you're referring to. To get into the service menu it's 000000 or 0000. If it's the user lock code or SIM lock code, you will need a cable and/or dongle/terminator and software to reset it.
Oct 31, 2007 | Sony Ericsson P800
Gemini Sound Products Gemini Napco Gem-p800 Security Alarm System Keypad Logo
209 people viewed this question
Top Gemini Sound Products Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Gemini Sound Products Home Security Expert? Answer questions, earn points and help others
