Question about Refrigerators
Same model as alot of others posting FRT04L5DB0 COMPRESSOR will not kick on all else works fan is on and with freezer door open and goes off with fridge door open and closed light is on evap is warm serial RA72768537
    Scholar:
  • 116 Answers
Hi this is either a shot compressor or start relay for the compressor, relays are $25-50.00 you could try that first if ifts the compressor your looking at $500+ to have it changed.
Sean
Posted on Mar 28, 2011
Rb215labp Samsung fridge with freezer on bottom isn't working correctly. Fridge got cold after I defrosted it but only last 24hrs or so and keeps accumulating frost/ice on the back. Freezer doesn't hardly...
This is a twin cool unit. refrigerator works independently from freezer unless compressor failure so compressor is not the problem. you may have a defrost problem or an evaporator fan failure in the freezer easy way to check open door hold the door switch and listen for fan draft if you hear it is good is not you have a bad fan or a bad door switch. the refrigerator has a defrost problem usually is the sensor you try that the other thing can be the heating element but rarely goes bad.
Amazon com DA32 00011E Amazon com DA47 00095E
Dec 20, 2014 | Refrigerators
Fridge not cooling
Your description is quite complete but is rather baffling. Pls bear with me while we process by elimination. A few basic/working ideas:
  • most designs call for a single compressor to cool the freezer;
  • the cold air in the freezer is drawn towards the fridge to cool that area;
  • this is performed by a fan drawing air in the freezer through the evaporator;
  • most would have a vent or air pathway to guide the freezer air;
  • all would have thermostatic control to set the desired temperature;
  • some designs have two thermostatic control , 1 for the freezer, 1 for the fridge.
As applied to your concern:
  • compressor is working since freezer is OK;
  • fan is working as you posted but is the air drawn from the freezer, better still, is the air forced/vented into the fridge?
  • could you please check that the air is strongly blown into the fridge area;
  • a little experiment, open the fridge door, look for and press on the door switch, the light should go out, after a lengthy seconds, the fan should trigger on, not only would it be audible, you would notice the frozen air swirling inside the fridge area. If you hold on long enough to the dorr switch, the compressor should kick in (if it is not already running) since the thermostat of the fridge area (if one is present) would sense that the fan is turning but the fridge area is not cooling.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 02, 2008 | Refrigerators
ARB1914CW AMANA REFRIGERATOR. FREEZER PART SEEMS TO BE WORKING FINE BUT THE FRIGE SECTION IS NOT. TEMPERATURE IS STARTING TO RISE IN THAT SECTION AND TURNING THE THERMOSTAT UP HIGHER DOES NOT EVEN TURN...
HI,
First, check to see if the light comes on or if there is any fan, motor, or other sound coming from the appliance? If so, the refrigerator isn't really completely stopped--go to the specific problem you are having. If not, try adjusting the thermostat to a colder setting. If that doesn't work, read on.
Second, check to see if there is power getting to the refrigerator. To do that, plug a lamp or other device into the same outlet the refrigerator is plugged into. If there's no power, check the fuses or circuit breakers. If the fuses or breakers aren't the problem, contact a qualified electrician to restore power to the outlet.
If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
  • Wiring
  • Thermostat
  • Defrost timer
  • Compressor
  • Overload and/or relay
Jul 23, 2008 | Amana Refrigerators
Ess25lgmb freezer fan doesnt shut off
Most fans only run when the compressor runs, it must be wired wrong, OR if the unit has a computer control (LED digital display) it may be the main board has shorted, you can try unplugging it and let it sit for 10 minutes, then replug it. ALSO sometimes there are sensors that sense the temurature and will kick on a fan if they are out of parameter, changing sensors if they are malfuntioning can fix this as well...
Feb 08, 2013 | Kenmore Refrigerators
2005 Maytag Refrigerator Fan Stopped WOrking
What is the model number and is the compressor kicking on?
Oct 28, 2012 | Maytag Refrigerators
My Whirlpool refrigerator quits working and restarts
Good day,
If it only occurs on a monthly cycle, even a service tech would not find it unless it happened while he was there.
First choice would be to replace both the thermostat and the defrost control. These are the items that turn the machine off and on and either one could hang or stick once in a while.
NOW, that is based on the fact that the machine goes totally dead during that period. If you hear something, anything running then the above does not apply.
The possibilities then, are, the fan motor in the freezer won't run (you can hear it running when you open the freezer door), the cooling fan motor behind the bottom rear cover that cools the compressor and condenser same situation, will not run.
Lastly, the start relay mounted on the side of the compressor is weak. It will not kick in the compressor, but in that situation, the fans will run.
Hope that helps. I've serviced a lot of refrigerators with that complaint, and it's always been the first 2 items.
Feb 17, 2010 | Whirlpool ET1FTKXK Top Freezer...
Model gss20iepcbb freezer side works fine ...fridge
on most units they have two controls refrigerator control is electric t-stat that runs compressor freezer control think of it as a door colder freezer door is barely open warmer freezer door all the way open all cooling coils are in the freezer and a fan moves the air to refrigerater side possible problem fan not running
door freezer control all the way closed
light switch broken light staying on door gasket not sealing tight find door switch press verify light shuts off and fan starts
look for torn or damaged door gasket can look from outside with light and see if gasket contacts case on all four sides
freezer is cold enough so compressor is ok hopr this helps good luck ron
Dec 10, 2009 | Refrigerators
Just got back from vacation opened fridge door and wow, was greeted with god awful smell everything hot, i noticed the freezer temp was on zero, possible due to my four yr old but know cant get the...
if the freezer is at o then the compressor is working and frost buildup in freezer back panel check to make sure the cooling fan is working on the compressor area
Aug 19, 2009 | GE Refrigerators
Frigidaire side by side refridge
pull the kick plate off under the doors. if you look in behind the kick plate youll see alot of dust build up. this area needs to be cleaned once a year to keep air flowing properly over the condenser coils. if the dust build up is minimal then remove back panel of refrigerator and make sure the fan is running behind the refrigerator. if not, or if running real slow replace the fan motor. the heat is the because the condenser is getting too hot. it needs to be fix or the compressor life will be greatly shortend
Nov 20, 2007 | Refrigerators
Refrigerators Logo
179 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
