Question about KitchenAid Refrigerators
I have a kitchen aid side by side with a slide out bottom freezer. The ice maker motor is not functioning properly. It is making a grinding noise like it is stuck. It is not making ice. I removed the motor cover and it states not to manually move the motor dial. The model is KBFA20ERBL01
  • 16 more comments
  • michael_d40 Mar 28, 2011
    the link you sent said page not found????
    I have a kitchen aid side by side with a bottom pull out freezer. the ice making machine is not working.the motor is making a grinding noise like it is stuck. the last expert sent me a link that would not open.model # on the fridge is KBFA20ERBL01
  • Anonymous Mar 11, 2014
    my sim card is puk
    I need a pop up camper 1995 dutchman 1203 owners manual.
    how to export data to excel
    starting problem after running in water it only switch on
    misfire on 2002 isuzu rodeo coil pack
    need details for disassembly
    top element works in bake mode, bottom works on broil mode
    Quick release plate for p118 tripod
    hooked battery up wrong now radio and interior lights will not come on
    Have unit but no instruction manual
    New computer - need drivers for Kodak all-in-one ESP C315
    my 1991ford explorer with auto trans. sometimes does not want to engage in gear and fluid is full
    samson TXM20 - Powered Mixer user manual
  • Anonymous Mar 12, 2014
    a e32 appeared previously,then camera shut down
    The radio is not working and i cant set the clock
    Conexant High Definition audio drivers
  • 794 Answers
Hi michael_d40,
With the issue that you have relayed, that the ice maker is no longer working you may be at the early stage of defrost problem. There's a certain temperature that the ice maker needs to be, to make ice. There will be no ice production if the temperature is too warm and if something is going on inside your machine. If this will be the case try the simple steps below:
1. Try putting a thermostat inside the freezer to see what the temperature is.
2. It should be at least Zero.
3. If not, turn the temperature of your refrigerator to the next coldest setting inside the freezer.
4. Let it go for a day and see if the machine starts to make ice.
If this will not work, you may take a look on another possible cause of the problem which is the Fill tube for the Ice Maker may be froze. If you look at the ice machine inside your freezer you will notice a tube entering it from the rear wall, it's your fill tube. Here's how you can check it:
1. Check the tube if it's blocked with ice. If so, that's the problem.
2. You may use a hairdryer to thaw it out and your machine will be making ice before you know it.
Hope it helps.
Thank you for using Fixya.
Posted on Mar 28, 2011
    Guru:
  • 262 Answers
See my tips and how to's for your answer
Please consider giving us a four thumbs up for our rating!
Using FixYa and this procedure has saved you a minimum of $125.00!
kdrake84
Rank: Guru
Rating: 95%, 96 vote
Click on the link below.....
Ice maker repair http://www.fixya.com/support/r8753658-whirlpool_style_ice_maker_repair
  • Keith Drake
    Keith Drake Mar 28, 2011
    I have no idea why that link was dead. Sorry about that. Here is the new link.
    kdrake84
    Rank: Guru
    kdrake84
    Rank: Guru
Could some please post how to remover the ice maker from my kitchen aid model ktrc 19 m refrig thank you
Look right above the icemaker part that forms the cubes. Its usually brown in color, Just above it are 2 extensions of that brown part that has 2 screws going into the left side of the freezer, Remove the 2 screws and the unit comes out. The power plug for it is just to the back bottom of the ice maker. If you can see it you can probably just unplug it to stop the noise.
Apr 11, 2015 | Refrigerators
Kitchen Aid ice maker is making a pumping noise. The noise is itermitten. It still makes ice. Freezer is at 5 degree and fridge is at 34 degree. Aquasensor filter is at 44 percent left. Thanks...JA
noise from ice mker can only be the ice maker unit... turn of icemker for a while and see if tn=he noise comes on during that period . if not replace ice mker head . mm
Dec 07, 2009 | Dishwashers
Ice maker makes grinding noise (no ice)
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Sep 25, 2009 | Maytag MBB2256G Bottom Freezer...
Ice maker makes too much ice
In my Kitchen Aid bottom freezer there is a metal arm(?) that I lift up to stop the ice maker from making ice. When I start running low on ice, I push the metal arm(?) back down for it to make ice again. Hope this is the solution for your Kitchen Aid too.
Jul 22, 2009 | KitchenAid Superba Architect KSCS25INSS...
Keeps making ice, i can't seem to make it stop.
You have an emitter and receiver in the freezer section...Actually when you slide the lever on the right side in the middle of the freezer section, you break the beam...and it is suppose to stop the ice maker from harvesting ice anymore. If this shut off device fails, it can fail in the on position and continue to make ice. Replace this assemlby sold in a kit and you will be fine. In the mean time, if you can remove the ice maker head and unplug it, that will stop the ice until you can replace the emitter and receiver assembly. You can also shut the water off but the ice maker will continue to operate, just not dispense ice. If extending and waiting on this repair you should disconnect the ice maker.....
Mar 20, 2009 | KitchenAid Superba Architect KSCS25INSS...
A creaking noise when the freezer is opened & then closed
In some freezers they build up excessive vacuum which pulls the plastic housing away from the internal polyurethane insulation, hence the creaking sound. You can make a vacuum breaker by attaching a small stick or similar to the bottom of the door gasket, this will break the vacuum without losing temperature.
Mar 12, 2009 | Refrigerators
Amana Bottom Freezer door when shut starts a noise
The light is switched on and off by a small lever which is pushed when closing or opening the door. This operates a microswitch. It would not make any grinding noise. Grinding noise can come from the fanmotor which would also stop when the fridge door is open.
Mar 08, 2009 | Amana ABB2227DE Bottom Freezer...
I have a Kitchen Aid side by side KSRS25IL. The ice maker after
Sounds like you need to defrost.
if you can move everything out unplug it ,turn it off w/ doors open,you can put pans of hot water in the freezer to speed up the process 12 to 24 hrs this will free up any clogged tubes.After its completely defrosted Only turn it up to 4 or 5. Good luck.
Len West
Feb 27, 2009 | KitchenAid KSRS25IL Side by Side...
Kitchen Aid KSRP25F Ice Maker
The ice maker is not working, no ice ice is coming in the tray on my Kitchen Aid KSRP25F Refridgerator, the red light keeps on
blinking
Del
Dec 05, 2008 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
