I printed two pages, and now my printer will not acknowledge there is paper in the tray and it just doesn't catch, so nothing will print.
    Guru:
  • 89 Answers
Power cycle the printer
Try printing again
If it does not work
Print a test page from the printer itself as stand alone
if it does not print
It could be a hardware issue
check also ink levels if they were low
We can give you specific answers if you can post exact model of the printer and its brand
If you can print from the printer itself without the help of the computer it means the issue we need to settle is the connectivity
is it usb cable?wired? or wireless?
if printer lost its connectivity with the computer it will defnitely not print
either restart the computer,check cables if they were plug correctly,reconnect the printer wirelessly to the pc.
Hope I help you a bit
Posted on Mar 28, 2011
I'm getting an error code Illegal attribute value on my hp 4050 printer
Nothing to worry about. It just means that you have printed a page or pages that all the trays do not have the correct paper size. Say your trays all have A4 papers and you printed a PDF document (US letter size) downloaded from America. Printer prints the page, then print another page with your error message just to tell you your pages do not match the papers. This is HP PCL6 code. A Postscript printer driver will just refuse to print if page size mismatches and keep the user wondering why.
To avoid the message, just make sure that your documents have the same page settings as papers in your printer trays.
Nov 26, 2013 | Computers & Internet
Hi I have a cannon mp470 and it will not pull paper through to print. It either doesn't catch at all, or it will jam to one side.
Hi
There is something stopping the paper feed process. Try the following
1. Check and make sure nothing is fallen inside the paper tray
2. Remove anything stuck
3. Even if you are not able to see anything stuck tray to use a air blower and blow air in the tray this will remove anything stuck.
Jul 15, 2011 | Canon PIXMA MP470 All-in-One Printer
When you print each page has a gray/black line running down the page from top to bottom about 2.5 inches from the edge of the paper. Sometimes it is darker and other times it is lighter. We have tried...
While the line is showing up on the output pages.
Stop printing and put paper in the manual feed tray (tray 1).
Start printing again. As a page gets pulled into the printer about 1/2 way open the top cover.
Pull out the toner and look at the page inside the printer. If it doesn't have the grey/black line, get the fuser replaced. It is defective.
Jun 09, 2011 | HP LaserJet 1300 Printer
My HP P2015DN only prints one page at a time. If I have a 5 page document, the first page prints and then I must print the go button for each page to print.
Is the paper feeding from the manual tray or tray 2. If you are printing from tray 2 and have this problem then it is likely that your driver or software is looking for different paper types than you have loaded in the printer. For example, if you have plain paper in tray 2 and your software wants to print on letterhead, then the printer will stop after each page and by pressing the button you are telling the printer that it is ok to print on different paper. If you have the paper in the manual feed tray (tray 1) then I would check to make sure you are telling the pirnter to print to tray 1 and not manual feed when you send a print job.
May 02, 2011 | HP LaserJet P2015dn Printer
How do I set OKI B4600 to print to top tray?
On the back tray where the paper comes out just push the extra piece in that helps to catch the paper until it clicks and it will automatically start coming out the top so you pages are in the order that you want them to be.
Oct 07, 2009 | OKI B4600 Digital Mono Printer - Black
Canon ir2200: data light comes on, nothing prints We have a Canon ir2200 installed as a local printer; no test page will print nor will a page sent from a program print, although the data light comes on,...
I would first try to see that your paper trays are set correctly. Meanning that the paper size are set to the same paper size in the tray. The knobs that input the paper size Magicly they move. Also, make sure that you clear out all the print jobs in the print "Q". Some body may have a odd paper size tring to print. Also, has anyone chaged anything on your network or the setting in the copier?
Mar 19, 2009 | Canon Office Equipment & Supplies
The Paper light keeps flashing when theres paper in the printer
A few things could be happening here.
1. Clear the print queue, and if there are jobs that won't delete, reboot the computer.
2. Now clear the jobs on the printer (cancel job button) until the status light turns green.
3. Put a piece of paper in the manual feed tray on the front.
4. Print a test page.
If the test page prints to the paper in the manual feed tray, then it is set as the default tray. Go into the printer settings and change it to "auto" or tray 1. If the test page prints to tray 1, but the original document you tried to print (when it got stuck) still won't print, cancel the job. Now, again, put paper in the manual feed tray. Try to print the document again and if it pulls from there, go into page setup of your document and change the setting from "manual" to "auto" or tray 1. Clear the job again (if it's stuck) and you should be able to print again. Hope this helps. This is one of the most common solutions - it happens a lot, especially with documents that are emailed from other people and once they get stuck in the queue, nothing will print (except the test pages directly from the printer, like you describe).
Jun 25, 2008 | Brother HL 5250DN Laser Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper tray full message and not printing
there is a black tab in the center where the papers come out that is the tray full sensor arm that is more then likely stuck
Dec 26, 2007 | Kyocera FS-4000DN Laser Printer
Printer won't eject paper correctly
I would try to clean the rollers with a damp rag. I would also recommend a good 'dusting' with some canned air. Pulling the paper out is never a good idea... you can always hit cancel to release the paper. If this printer is used in an office, I would put a little reminder on it for others. Hope this helps!
Sep 15, 2006 | HP OfficeJet G85 All-In-One InkJet Printer
29 people viewed this question
k24674
jasbo
jasbo
