Question about Craftsman Garden
I have a 17hp Craftsman lawn tractor with a 42" deck (917.273180) I need to replace the Mandrel shaft assembly, (pt # 137645) on the mowing deck because the star at bottom of shaft that holds the blade in place has sheered off. I have removed the Mandrel guard and the blade, but how do I remove the flanged toplock nut (pt #178342) to release shaft from housing ?? I attempted to do it but all that happens is shaft & pulley spin. I tried putting blade bolt in but can't get it tight enough to hold whilst releasing toplock nut Thanks
  • bootslacey Mar 28, 2011
    Thank you Timydee, much appreciated, after reading through some of ways a few other people had tried, I came up with my own version of another guys success. I lowered the deck so that I could get a socket wrench on nut, put the mower deck in gear so that the belt would hold the pulley in place, then used a hammer to hit the socket wrench handle...(made my own impact gun) !!! Hit the handle of the wrench 3 or 4 times and it loosened the nut right up
    President:
  • 3,074 Answers
Impact gun is the easiest way, if not the you will need to use a pipe wrench and a ratchet. Hope this helped Tim
Posted on Mar 28, 2011
  • 4 more comments
    Thanks, although I guess, I should have said, my real problem is trying to hold the shaft still so that I can release the toplock nut. The shaft is runs trhuthe housing and there is nothing at the bottom end of shaft to hold on to now that the star has sheered off (blade won't stay in place to hold on brace it).
    Only thing to possibly get a grip on to stop shaft turning is the pulley immedietly below toplock nut
  • Tim Whalen Mar 28, 2011
    there should be four bolts that you can unbolt and remove the assemblage off of the deck
    Ah yes, there are 4 bolts but....to remove the housing from deck, , you have to remove the 4 bolts and...wait for it, the toplock nut and pulley so that housing assembly will drop down through the hole in deck (Pulley is too big to drop down through hole, and bottom of housing assembly is too wide to go up thru hole !!).
    I'm thinking /...SCREWED ;0)
    I'm tring to figure out some way to hold the pulley still without damaging it, so that I can get enough leverage on toplock nut, i was hoping there was another way around it but it doesn't look like it.
    here is a forum that people have posted one or more of the ideals may help, Good Luck Tim:
    http://forums2.gardenweb.com/forums/load...
    Glad to hear that it was helpful, as it always nice to help people out. Your Welcome Tim
Right mandrel assembly for craftsman model 917.273020 does the stripper, mower round attach on top of or under housing of mandrel?
The part called the stripper goes between the mandrel housing and the mower deck.
Hope this helps, if so please vote yes! Thanks!!
May 27, 2011 | Craftsman 20 hp 42 in. Deck Yard Tractor
The bolt holding the blades is broken off
Your st bet is to replace the entire spindle assembly.
It's not as cheap as drilling out the old bolt and using an "easyout" tool to remove it, but the outcome is certain.
Better yet do a web search on "137645, 137646 Shaft Kit For 130794 Mandrel, AYP" and you can find the shaft only with bearings.
On Amazon:
Sep 06, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Craftsman 42", 18.5 lawn tractor: blades are hitting in the mower deck. Blades are new and deck is balanced. Is it wear on the Mandrel - Shaft? Mandrel bearing?
Oh boy!!! Welcome to the craftsman worst design of their mower decks CHEAP!!!!! I had to replace my mandrel on the right side, side where the grass shoots out several times!! Cheap aluminum casting ****, one or more of your ears on the mandrel probably snapped, if you have an air wrench they are not too bad to replace, the screws that go into the mandrel are self threading and is easier to work on with air wrench but can be done with socket set, hope this helps!!!! good luck!
Aug 23, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
How do i take out the mandrile
remove the blade, remove the deck from the tractor, remove pulley covers, remove the deck belt, remove the bolts holding mandrel to deck, remove the mandrel. reinstall in reverse order.
Jun 23, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
How do i remove pully wheel to remove mandrel from deck? once i get the mandrel off the deck how do i remove the shaft and barings to put them in the new mandrels? 54in deck sears craftsman lawn tractor...
Think you're going at it from the wrong end, should be four bolts holding the whole assembly. Take off the blade and pull the rest up through the whole, leave the pulley on it. Don't buy new bearings, better off and cheaper to get a used one that works.
Oct 22, 2009 | Craftsman Garden
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Its not mowing evenly
You need to level the deck. On most mowers you level the deck from side to side evenly but have the front of the deck 1/4" lower than the back.
Aug 19, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Mandrel chews pulley
Are you sure the spindle is not bent and also are you balancing the blades when sharpening. Other then that make sure bolts are tight on the mandrel. With the deck off and standing up spin the blades and watch center of balde to see if something is bent. Also watch pulley on the other side to see if its bent.
Jul 19, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
316 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
