Question about Bobcat Miller 225 Welder Generator 907209 Or 907210
It runs but does not weld i need help - Bobcat Miller 225 Welder Generator 907209 Or 907210
  • 407 Answers
Hi:
Probably your machines overloaded. Check your fuses F1 and F2 and if they are open replace them.
Both fuses are located at left hand side of machine, open it and you will find them on the bracket.
Good Luck.
If this was useful please vote, thanks.
Posted on Mar 28, 2011
  • robert cox
    robert cox Mar 12, 2014
    i have a trailblazzer 250g it runs but not welds f1 f2 test good so what do you think
My Gasless MIG wont weld
I hate gasless MIG welding. Bought the flux wire and could not get it to weld. Kept running the current up to stop cold welds and tripped the breaker. It welds very good with gas though, so it's not the welder.
Sep 26, 2017 | Welding Tools
What can happen when welding on frame of chrysler truck 1500 with 5.9 engine.
Many electronics have power running to them all the time and are ground controlled, sounds like you blew an electronic component in one of the modules, ECM, BCM, etc... should also disconnect the negative cable while welding to prevent arc'ing back through the electronics.
Oct 17, 2014 | Dodge Ram 1500 Cars & Trucks
Stand has broken can you weld it whilst still on scooter
you would be better of taking it off to weld it because you will need to protect it from heat and sparks
otherwise you will need to disconnect orremove the battery because once earthed all power will run through and possibly burn out your coil and could blow up your battery
and im not sure on the wiring on vespas
hope it helps
Nov 12, 2011 | Sport & Outdoor - Others
Trying find out what i would have to have to start TIG welding with a Miller Bobcat 250 1992 year model
you will need a AC high frequency unit to weld aluminum. For stainless and mild steel just need a dry run tig torch, hose kit and 100% argon.
Sep 11, 2011 | Welding Tools
My miller matic 35 welds and stops after about 2 inches let cool for about 30 to 40 sec and it welds again. fan runs
these need a good power supply , i looked and did not see the duty cycle on this welder if you are doing heavy welding 100% power it will need 30- 40 minutes to cool of to weld again. it all depends on the units duty cycle, stated on the welder spec plate ..can you bypass the auto feed speed mode ? this might be the issue.. good luck ..use all the protection you can when welding these are like the sun and can and will burn exposed skin and eyes .. if'n i was any help throw me a bone and vote thanks jay
Jul 28, 2010 | Miller MATIC 140 MIG WELDING PKG w/cart...
I run lazer welding macines that lazerweld gold
You should know every trick in the book, not every body runs wire welding machines or even knows what one does. There are a bunch of things that will color wire, but you might not get the color off. Ferric Chloride, steel ink, liver something? I know the steel ink will come off, the ferric chloride might not, also a potent acid. Used in copper etching. And the liver ? I can't remember what it is called, but it is used to patina silver jewelry. Hope this helps.
Mar 23, 2010 | Welding Tools
Miller welder starts fine bur appear to run out gas need help adjuting linkage to fuel control
you need to adjust the throttle governor on the side of the carburetor you will see a adjustment screw do a weld to get the welder to runs at high speed then adjust the screw till it runs continuously, if it still dies out change the fuel filter and try again drain the carburetor bowel if it's diesel replace fuel filter and run fuel threw the water trap.
Nov 18, 2009 | Welding Tools
Weld a new near side panel on a ford transit or a data sheet with sizes or any relevent infomation
Buy a quarter panel from a junk yard that you want to replace tell the junk yard where you need it cut and tell them all of it that you need then using a pair of nibblers cut out the area that you want to replace. To do this use a measuring tape to measure the area to cut out. Next get some 3/4 masking tape and run the tape along the lines that you want to cut. test cut a piece of metal to see how much the nibbler cuts out and how jagged it leaves the cut and figure this into what you need to cut from the piece from the junk yard. once it is taped off remove bumper, and any wires that might run threw the holes on the panel also remove fuel tank hose if it's in the panel you are replacing. Once its cut remeasure the 1/4 panel and grind any spots that might be to long then match the parts together. ON THE INSIDE OF THE PANNEL WHERE YOU CAN'T SEE IT WELD SOME TABS (Spot Weld) 3 or 4 tabs that will help you line up the two pieces together then slide it in place get one end lined up and a space of the wire you will use to weld it together once it is all lined up pull tape off and use a grinder or wire wheel to remove paint away from the area to be welded by 1 inch. Next start welding it together be careful not to weld one side more than another or yo will get warp age, also don;t let it get to hot. take your time welding it together be sure to get a solid weld be sure all holes that have to be lined up line up. after welding it together then grind it flat and used bondo to fill in and smooth out the welded edge prep with 2 part epoxy primer spray the bare metal and blend into the paint, this will show you if you have any areas to work on. THIS IS NOT A EASY JOB BUT CAN BE DONE. I have cut two cars in half and have welded then together and they were stronger than when they were new. but this requires knowledge of windshield repair and wheel alignment. good luck and if you need more help let me know so I can help you.
Nov 17, 2009 | Victor Welding Tools
Millerbobcat225gplus welding machihe w/onan16hp performer engine
carb is probly gumed up. I would put in a good dose of fuel injector cleaner in the fuel and start the engine llet it run 5 minites shut idown. What 2 days then restart,it should run fine. PS put sunoco ultra fuel in tank before you put in clean4er.drain tank before you start.
Dec 13, 2008 | Welding Tools
Bobcat Miller  225 Welder Generator 907209 Or 907210 Logo
639 people viewed this question
Top Bobcat Welding Tools Experts
Lawrence Oravetz
wadingriver
wadingriver
Are you a Bobcat Welding Tool Expert? Answer questions, earn points and help others
