Question about NetGear WN2000RPT Repeater
My netgear extender keeps telling me it has no internet access. It looks like the extender is dropping the connection to the router.
  • 11 Answers
SOURCE: netgear wireless router DG834PN wireless access local only
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Posted on Mar 07, 2008
SOURCE: NetGear Wireless Router - continous internet connection drops
when im on a site with a video/music the connection drops, takes time to load ..then rebuffers can any one help
Posted on Jan 01, 2009
redhaze89
  • 854 Answers
SOURCE: I cannot access internet when connected to VPN.
1. Please assign an IP address to your computer using the IP Address Reservation.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
d. On the setup page, please click LAN IP Setup under Advanced tab.
e. Click Add under Address Reservation then you will be brought up to a new window.
f. On the Address Reservation window, please select the radio button of the computer you wish to add.
g. If the computer you want is not on the list; click the Refresh button to update the table.
h. If the computer is still not on the Address Reservation Table; please enter the IP Address, MAC Address, and Device Name of the computer you wish to add.
i. Please click on the Add button when finished.
2. On the Set Up page of the router, select on Port Forwarding/Port Triggering under Advanced tab.
3. Click Add Custom Service and type VPN on the Service Name box.
4. Set the Service Type to TCP/UDP and input the VPN port numbers under the Start and End Port field.
5. Type in the last digit of the IP address of your computer. Then, click the Apply button.
Example: The IP address of the computer trying to establish the VPN connection is 192.168.1.2.
Service Name Start Port End Port Server IP address
VPN1 47 47 192.168.1.2
VPN2 50 51 192.168.1.2
VPN3 500 500 192.168.1.2
VPN4 1723 1723 192.168.1.2
Posted on Aug 16, 2009
garethmt
  • 116 Answers
SOURCE: I have two routers Netgear DG834Gv3 and Thomson
sorry, can't be done. the key word here is "router".
Posted on Nov 13, 2009
anandg27
  • 1272 Answers
SOURCE: iPhone keeps dropping wifi signal on Netgear DG834G router.
Hi, please perform the below steps to configure settings on the router:
1. Connect a computer to the router using any one of the 4 available ports.
2. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router, usually with http://192.168.0.1 or http://www.routerlogin.com.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
5. Click on WAN setup from left menu. Check the box for 'Disable Dos Protection'.
6. Set the MTU size to 1400. Click apply.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jan 08, 2010
How do you connect netgear extension to router
This article provides instructions on how to wirelessly connect to your NETGEAR Wi-Fi Extender using manual setup after the NETGEAR WiFi Extender has been successfully connected to the Access Point (AP) and obtained a valid IP address.
https://kb.netgear.com/25504/Unable-to-connect-my-NETGEAR-WiFi-Extender-using-manual-setup?cid=wmt_netgear_organic
Feb 23, 2017 | NetGear Computers & Internet
How do I keep my netgear r6200 from dropping internet?
What is it connected to for Internet access? How is it connected?
Feb 23, 2015 | NetGear R6200-100NAS AC1200 802.11...
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
I have a netgear wnr3000 router and all of a sudden my internet stopped working now there is an orange blinking light
The orange blinking light tells you, you have not got an internet connection. Check the settings on the router.
Jun 22, 2014 | NetGear WGR614 Wireless Router
Your connection is limited
What router and where is it that you are connecting the Extender to? An extender is not a router. You need a router to extend the wifi signal from.
Mar 22, 2014 | NETGEAR CONSUMER New - Netgear Wn3000rp...
Dropped internet and NAS access
Try changing the channel.
you'll have to logon to the router - best to google the make/model for IP address etc.
Jan 23, 2014 | Computers & Internet
Mywifiext net
Connect a LAN cable from your computer's LAN port to your Netgear WiFi extender' LAN port.
Open a browser and enter www.mywifiext.net or www.mywifiext.com
This will get up into the Netgear WiFi extender setup.
May 04, 2013 | Computers & Internet
Cannot connect NetGear WN3000RP with wireless
If you use a Netgear router to broadcast a WI-FI (Wireless Fidelity) signal in your home, you can easily double the range of your network by connecting a second router to one of the LAN (Local Access Network) ports located on the back of the Netgear router. You can use a Linksys, Belkin, D-Link or even a second Netgear router to extend the range. Any router that allows you to access the router settings to turn off the router's DHCP server is usable as a range extender.
Complete a master reset on the router you want to use as an extender. Typically, routers have a reset hole located on the back or side of the router. Push a metal push pin into the hole until the lights on the router flash. Often the settings on routers have been manipulated to enhance a network connection. Resetting the router ensures you can access all of the settings and not encounter any issues when making the connection. Plug an Ethernet cable into one of the router's LAN ports located on the back of the router. Plug the other end of the Ethernet cable into the Ethernet port located Enter the router's IP address into an Internet browser Web address field. If you do not know the default IP address, reference TechSpot.com for a list of router IP addresses. Enter the default username and password for your router. If you do not know the default login information, reference Router Passwords.com for the default login information for your router brand. Access the DHCP server settings. Usually, this is located in the "Basic Setup" section of the router settings page. Turn off the DHCP server and then select "Update Settings." The location of the DHCP server can be located on a different page if the router is an uncommon brand. Access the "Wireless Setup" page and change the SSID to match the network name you use for your Netgear router. Select "Update Settings" to save the network name. This allows computers to move from the Netgear router to the router used as a range extender without requiring a second wireless profile being set up on the computer. The SSID could be located on a different page if the router is an uncommon brand. Access the "Wireless Security" page and update the router's password to match the password used on the Netgear router. If you do not secure your network, skip this step. The wireless password could be located on a different page if the router is an uncommon brand. Remove the Ethernet cable from the router and the computer. Plug one end of the cable into the WAN (Wide Area Network) port located on the back of the router you want to use as a range extender. Plug the other end of the cable into one of the LAN ports located on the back of the Netgear router. Hope this helps
b>
Dec 05, 2012 | NetGear Universal WiFi Range Extender...
Internet keeps dropping out using this router
One simple solution, can you try using the router on another ISP connection (at your friends' place possibly?) This will rule out the possiblility of your ISP fault saving you $65 straightaway...
Dec 17, 2008 | NetGear RangeMax WPN824 Wireless Router...
Belkin f5d7132
For best results, you should connect it directly to the other router with an ethernet cable.
Jul 21, 2008 | Belkin (F5D7132) 802.11b/g Wireless Access...
NetGear WN2000RPT Repeater Logo
411 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
