Question about HP Office Equipment & Supplies
HP Officejet J3680 don't scanning on linux ubuntu 10.10
onyeredson
  • 404 Answers
SOURCE: i have a vista, my hp officejet v40 won't scan
I had a similar problem with my Canon Mp 600 there were compatibility issues with Vista, I went to Canon's website and downloaded patches and drivers for the all in one to bond with Vista.
Perhaps a visit to www.hewlettpackard.com and a sniff on their support and downloads page might glean the necessary files/drivers you require?
Good Luck!
Paul 'W'
Onyer~EDSon(:0) {#><U.K.
Oh! please remember to rate my assistance.
Posted on Jan 22, 2009
RPFinney
  • 385 Answers
SOURCE: scanning with an Officejet J3680
Click Start , and then click Run .
In the Open text box, type msconfig , and then click OK .
In the System Configuration Utility window, click the Startup tab.
Search the list for HP Digital Imaging Monitor . tick the box.
If HP Digital Imaging Monitor is not on the list,
the driver was not correctly installed and You need to reinstall the software.
Open HP Solution Center with one of the following methods.
On the Windows desktop, double-click the HP Solution Center icon
On the taskbar, click Start , click All Programs , click HP , and then click HP Solution Center .
If more than one HP device is installed, click the tab for the All-in-One product.
Click Settings .
Click Scan Settings and Preferences .
Click Scan to... Setup .
Click the Destination List tab.
NOTE: Depending on the computer performance, it can take several minutes for the
Front Panel Destination List to populate after you turn on the printer or computer.
If the Front Panel Destination List contains valid scan destinations,
you need to reinstall the software.
If the Front Panel Destination List is empty, continue with this procedure.
Click each program to include on the Scan To list.
Click the Add arrow.
Click OK .
Scan a document using the Scan To button on the front panel.
If the scan fails, try to scan using the HP Solution Center Scan button.
If the scan still fails, re-install the software.
Hope this helps
Ric.
Posted on Apr 18, 2009
blueextc3221
  • 15935 Answers
SOURCE: Why am I getting this message? Error 402
Error Code: 402
Definition
During a V.34 transmission, the local machine is unable to connect (handshake) with the remote machine and is consequently unable to send a T30 frame. This occurs when the line is disconnected or if line conditions degrade during the session.
Solutions
  • Remove any pass-through devices from the phone line, and then try the fax again.
  • Confirm that the fax/phone cable is no longer than required, and that it does not pass near unshielded electric motors such as fans, heaters, or household appliances.
  • Try to send the fax at a different time when telephone line conditions have improved.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 30, 2009
komguy
  • 2306 Answers
SOURCE: i'm missing the HP Alignment page for an officejet J3680
when you do the alignment procedure, your printer prints the page to place on the scanner glass and complete the alignment. A page from another printer will not align your printer correctly. Select tools in the menu and then select printer alignment, the instructions are printed on that alignment page.
Posted on Jun 24, 2009
Riztech
  • 731 Answers
SOURCE: how to scan with hp officejet j4680
Please install the printer software and try to scan via the installed software from the computer. Or, start scan using scan button from printer; after installing software.
Regards,
Rizwan
Posted on Mar 03, 2010
HOW DO I CONNECT THE PRINTER WITHOUT A CD HP OFFICEJET J3680
Go here: HP Officejet J3680 All in One Printer Drivers and download the driver for your operating system. Follow the instructions to install it on your laptop, and you should be up and running!
Sep 17, 2014 | HP J3680 Officejet All-in-One Printer
Reset HP j3680
The link below will take you to all of the answers at hp support about resetting your printer. Without more info about what you are trying to reset (password, power on reset, reset after paper jam, etc.) this is all the help I can give.
HP Officejet J3680 All in One Printer Support search results
Jul 04, 2014 | HP J3680 Officejet All In One Printer
My hp officejet j3680 doesn't want to scan anything everything else seems ok but i don't have the disk any more and it says to refer to product device documentation top troubleshoot ..i do have it...
Some laptops cannot run some printers/copiers/scanners from the usb ports. If you have always run your officejet from your laptop with everything functioning correctly, there may be a problem with your printer hardware. If you have just tried it with your laptop, it may mean that your laptop cannot power your printer. It might help to plug your laptop into an AC outlet and make sure you have the most current, correct drivers for your printer. You can go to the HP website to download drivers. Will your printer make copies? If not, there may be a problem with the light in your printer which is used for copying and scanning.
You can determine if your problem is with the printer or the laptop by connecting the printer to a desktop by usb or printer port to see if all of its functions work correctly. If they do, you can print from the laptop through a home network.
Jul 26, 2011 | HP Officejet J3680 Multifunction Printer...
We have a new hp officejet J3680 all in one printer. we can not get it to scan but it does fax and print. Help!!!
Please click here to download and install the full-feature software driver and then try scanning. Make sure that the USB cable is disconnected before installing.
Regards
Riztech
Sep 06, 2010 | HP J3680 Officejet All In One Printer
I need to install my hp J3680 to my computer and don't have the cd
to install ur printer u need the drivers for ur HP J3680 Officejet All In One Printer. Go to www.hp.com for driver support for ur printer and download the printer drivers.
Jul 28, 2010 | HP J3680 Officejet All In One Printer
How do I use the scan feature on my HP Officejet J3680 All in One. I pressed the "scan" button and received message "No scan option, refer to device documentation to troubleshoot". I do not have "device...
The HP Digital Imaging Monitor (DIM) software must be running in order to scan from the printer.
  1. Click Start , and then click Run .
  2. In the Open text box, type msconfig , and then click OK .
  3. In the System Configuration Utility window, click the Startup tab.
  4. Search the list for HP Digital Imaging Monitor .If HP Digital Imaging Monitor is not on the list, the driver was not correctly installed or a custom install was used. You need to reinstall the software.
  5. Select the HP Digital Imaging Monitor check box.
  6. Click Apply , and then click Close .
  7. Click Restart to restart the computer.
  8. Try scanning again
Regards,
Riztech
Jun 16, 2010 | HP J3680 Officejet All In One Printer
Need advice on how to resize images using the scanner on the hp officejet j3680, I want to take one image from scanned page and make it a certain sizem may last scanner was great and easy to use this one...
I believe you can only adjust it from within your destination scan program. In other words, scan first, open the scan in your editing program and adjust the size from there.
Sep 18, 2009 | HP J3680 Officejet All In One Printer
It won't scan.
The first thing to do is to use your installation disc and reinstall the printer on your computer. It sounds like the install did not install completly. Also make sure you use the disc for your type of computer it will make a difference.
Aug 31, 2009 | HP J3680 Officejet All In One Printer
29 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
