Question about Samsung Televison & Video
I have a 67" Samsung
Www.replacementremotes.com/ SAMSUNG/ BP59-00071B-BP5900071B Hope that helps!
Posted on Aug 02, 2011
My tv suddenly went to red and green double vision. Looks like 3D without the glasses. I want to repair myself. Samsung 1080i model HCR5245W. MFG July 2005.
That would be your Convergence, Encompass Parts Distribution
has Convergence Module for $50.00 that goes to a HCR5245WX/XAA 1-800-638-3328
Or you can just replace ICs will have STK on them
Mats has ICs 1-800-628-1118
Sep 27, 2010 | Televison & Video
Bad picture on a Samsung DPL TV
Failing DMD board or it is also possible it has bad ribbon cables
Jan 31, 2010 | Televison & Video
Purple dots on HD LCD samsung model LNT4661FX/XAA when on.
hi,
your lcd micron tube in the panel had already worn out.
got to replace the panel
Jan 27, 2010 | Samsung LNT4642H 46 in. LCD Television
http://www.youtube.com/watch?v=Mm51C_RDIZE
-and-
http://www.youtube.com/watch?v=BNHHrgX_6cs
Jan 27, 2010 | Samsung Televison & Video
SAMSUNG TV WONT TURN ON JUST CLICKS
I just fixed this very same problem. The capacitors are the problem. However, I think that if you have some minimal skills with soldering, you can fix this yourself. You just need to take out the system board, then the power supply parts are on the top right. The bad capacitor(s) will be bulging at the top and possibly have some brown stuff coming out. The ones that go bad are 1000microfarad, 10V, however you can replace them with higher voltage. I got 35V caps from radio shack for 1.59 each. You just need to solder out the bad ones and then put the new ones in and solder. Remember that the negative end goes on the side with the bold black part of the circle on the system board. Then just cut off the extra ends of the capacitors. If you are capable of doing this yourself, you will spend at most 6 dollars instead of however much a technician costs.
Sep 24, 2009 | Samsung LN-S4041D 40 in. LCD HDTV
Samsung HLR6768WX DLP TV
That humming sound is a sign that your color wheel is becoming or already is defective. If you don't replace it you might even lose picture in the future since it's part of the light engine system
Jun 30, 2009 | Samsung HLR5688W 56" Rear Projection HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
SAMSUNG 15inch LCD TV
Debra,
Don't bother... You've got a busted backlight inverter. Need to replaced a new one or repaired it.
Sep 28, 2008 | Samsung SyncMaster 910MP 19" LCD Monitor
Open Questions:
samsung pn64f8500 boot loop with evoulution kit 3000za installed I had perfectly working Samsung plasma ph64f8500 working fine with Samsung evolution kit 3000 ZA installed. Then we moved I took off the evolution kits so the movers would not knock them off. I powered up without the evolution kit installed accidently. Now both plasma are stuck in boot loop. They power up but go to the smart tv logo and cannot find the evolution kit. I read somewhere a long time ago that I needed to reset the evolution kit to a state where it had not been installed. The current issue is the Main Logic Board eeprom instructs the unit to boot correctly but it cannot find the evolution kit. If you boot without the evolution kit the system halts and indicates on the screen the evolution kit has been uninstalled and you must install it if you wish to view. If it could find the evolution kit one could go thru the menu to uninstall it correctly. One option is to manually reset the eeprom to remove the install instruction that boots looking for the evolution kit. I have been looking for the eeprom on the Samsung main logic board but I cannot download the logic board schematic. I cannot find the logic board number. The main logic board is BN94-0625C. The logic board has tow other part number references.• MFR Part Number 1: Samsung BN94-06205C • Board Number(s): BN41-01998A, BN97-06633G i have been researching the logic board IC Numbers and belive that IC 1701 is the eeprom that requires reset. The youtube videos for similar models indicate a eeprom that is listed as a part nmber for this samsung pn64f8500 unit as 24C512 and shows how to jumber 2 IC locations that will force the eeprom to reset to standard starup without the Evoution Kit 3000
Jul 16, 2018 | Samsung Televison & Video
Televison & Video Logo
50 people viewed this question
Jerry Greenberg
Jerry Greenberg
