Question about Sewing Machines
NEED THROAT PLATE COVER - Sewing Machines
  • Sewing Machines Master
  • 1,133 Answers
For what make and model? you could try www.sewingpartsonline.com or the manufacturer's website and see if the part is available.
Posted on Mar 29, 2011
Phaff throat plate 98-694826-00
hi beth.
not sure what you are asking,but try this link out.
Pfaff throat plate 98 694826 00 Google Search
Nov 03, 2017 | Sewing Machines
How to replace the throat plate spring
This can be tricky. At a 45 degree angle push the top spring under the holding area of the machine. Hold this spring firm and push down on the second spring. Rotate the throat plate simultaneously until the plate is in its correct position.
Aug 13, 2015 | Sewing Machines
My needle is hitting the plate when I try to make a buttonhole
Sue: According to http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0CCAQFjAA&url=http%3A%2F%2Fwww.consew.com%2FFiles%2F112347%2FInstructionManuals%2FCN2230R.pdf&ei=ZGtVVaa7OYKRyQTGo4GoBA&usg=AFQjCNG-1xhxBFtfhJZJn7y5QZ_0E1r48w&bvm=bv.93564037,d.aWw : "The Throat Plate is not held firmly in place. Its screws are not tightened securely. The Throat Plate shifts around and is being hit by the Needle. Solution: Locate the Throat Plate correctly and tighten firmly the throat plate screws."
May 14, 2015 | Sewing Machines
I took the throat plate off to clean my Imagine serger. When I try to put bak on it has to be pushed back down and is against a small piece, seems to be too close.
THROAT PLATES ARE HELD ON EACH SIDE WITH A SMALL PIECE OF METAL (SPRING). 1. PLACE THE PLATE AT AN ANGLE OF THE THROAT. 2. AT THE SAME TIME CAREFULLY PUSH EACH SPRING UNDER THE PLATE. 3. SLIDE THE PLATE TOWARDS THE AREA WHERE THE PLATE SHOULD FALL INTO THE LOWER POSITION.
Feb 26, 2015 | Baby Lock Imagine
Please help my throat plate[needle plate] is banging loudly..the faster I sew the louder it knocks[throat plate against its base]..it's as if its too loose but see nowhere to tighten or screw it in...
I would like to help you but I do not know what model your machine is. Please answer this and I will try to help you. Knocking is usually lint built up under the throat plate and has to be removed to get it cleaned out.
Apr 18, 2011 | Singer Sewing Machines
I am wondering if I need a throat plate to sew. Everytime I start sewing, it gets clogged up and makes buzzing noises. I cut the tight threads, start again, and then it happens all over again. So, Is there...
Yes, you need the throat plate, Somehow you are not threading it right. Do this, change your needle, flat side facing away from you, totally rethread, with the presser foot up, pull the threads, it should move smoothly, now put the presser foot down, the thead should barely move when pulled. This normally will seat the thread in the tension discs. I don't know what else to try without being able to see the machine.
Jan 14, 2011 | Sewing Machines
I cannot get the thread from my bobin to come up out of the face plate for my Singer Zig Zag 753. The bobbin does not rotate, though the bobbin winder part works. The bobbin is in seew position. The bobbin...
When you slide the throat plate cover back into place, there may be a little lever the plate is suppose to move back into place. Try to reset the cover to see if it will catch.
Recheck the manual to see if there is another function that should be reset.
Make sure the bobbin is not over wound.
Feb 28, 2010 | Singer Sewing Machines
Removing needle plate from viking sewing machine
throat plate is usually tight with screws may be that the holding magnet and once the button is located near shuttle and it should press plate up...
Dec 24, 2009 | Husqvarna Viking 1
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
