Question about 7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3
Hi, my viper remote starter working good but there is no display on the screen when i start the car
  • 314 Answers
Hi jasandeep,
I understand that there is no display on the screen when you start the car, the issue probably lyes internally, have you tried replacing with new battery? if that does not help then i would suggest you to bring your Remote start to an electronic store and ask them about your issue so that it can be solved or replaced free of charge providing you have the receipt. i am afraid nothing can be done on the internet to fix your device as it is a physical problem.
i hope this helps.
Posted on Mar 28, 2011
Viper 5101 no longer starts
are your brake lights functioning properly? remote starts sometimes use this as a fail safe, or a bent hood pin switch? Also It may need the tach reprogrammed if used. there may be a seperate fuse for the starter.
here is the link to the installation manual: http://www.directeddealers.com/manuals/ig/viper/n4102v_2008_09_web.pdf
and the page regarding this issue: • The remote start will activate, but the starter never engages.
1. Check for voltage on the purple starter wire two seconds after the remote
start becomes active. If there is voltage present, skip to Step 4. If there is
not voltage present, advance to Step 2.
2. Check the 30A fuses.
3. If the gray/black wait-to-start wire is detecting ground upon activation, the
starter will not crank.
4. Make sure the purple starter wire is connected on the starter side of the
optional starter kill/anti-grind relay.
5. Does the vehicle have an immobilizer? Some immobilizer systems will not
allow the vehicle to crank if active.
6. Check connections. The heavy gauge remote start input wires on the
heavy gauge 10-pin connector should have a solid connection. "T-taps"
or "scotch locks" are not recommended for any high current heavy gauge
wiring.
good luck.
Apr 17, 2014 | Remote Start System
Camry 2002 Remote Starter Conflicts Car Starter
You need to call Viper and talk to their tech support. It sounds like the viper is actually disabling the starter. If you have all of your paperwork from the alarm system there should be a book that can help walk you through the reprogramming mode. Maybe your key fob is not synced to the alarm system. I have a clifford alarm which is still a viper. I have to press the star button 3 times in a row if I want my car to start remotely. hope this helps some.
Nov 09, 2013 | 2002 Toyota Camry
My car quite starting from viper remote :(
Does it power up (meaning do you see the dash light come on)? Does it turn the starter?
Dec 18, 2012 | Remote Start System
When I press the starter button, the function light appears and the car doesn't start.
Hi Kih8259! The vehicle might be in "Valet Mode" this does not let the remote start the car. In order to exit Valet mode do the following: Press and release the F button twice and then press the unlock key. Now, try and start it again to see if it worked. Hope this solved the problem!
Feb 28, 2011 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
Just bought a`used truck that came with a Viper RPN 479VPC remote. Is this just a car alarm or is this a remote start also? Any help? Little blue remote with car diagram on screen...has lock, unlock, aux,...
That remote can work with both a security system, and a combo unit security/starter.
Best bet is to take the vehicle and remote to your local Viper dealer and they can look the car over and tell you what was installed and help you learn how to use it.
Jan 16, 2011 | Directed Electronics 479V Remote Gen 2...
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Dec 30, 2010 | 5101 LE 1 Way Car Remote Starter System
I lost my viper remote starter, i already bought a replacement remote, but how do i progam it? I have the basic five button remote, black buttons and silver borders around the whole remote.
Dec 12, 2010 | 5101 LE 1 Way Car Remote Starter System
7752V Replacement Transmitter Supercode Remote for 5901 Responder LC3 Logo
302 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
