Question about Nintendo DSi Blue Console
I cant connect my dsi to a wireless routar - Nintendo DSi Blue Console
  • 2,632 Answers
Welcome to Fixya. Nintendo Dsi/DS/Ds XL connects to the internet using wireless connection. You need to know the settings of your router. I've listed below the steps on how you will access the router and to obtain the information needed for you to be connected.
How to access the Router:
1. You need to know the ipaddress of your router. You can refer to the manual or check the Default Gateway of your computer (Make sure that you connect the computer to the router using an ethernet cable for you to get the Default Gateway). Click on START then RUN. Type CMD on the small box on the lower left of the screen. Type IPCONFIG on the black window and get the value of your DEFAULT GATEWAY (it starts with 192.168.x.x)
2. Open a Browser, Type the DEFAULT GATEWAY on the address bar of your Browser. It will ask you for a username and password. (Refer to the manual of your router or post a reply so that i can provide you the username and password of your router)
3. Go to the Wireless Settings Page of your router. Look for the SSID or the Network Name and theNetwork Key or Passphrase. You can personalize it so that you can easily remeber the details.
4. Make sure you connect to your SSID and enter the Network Key to make it secure.
Now that we already know the setting of the router then its now time to connect the Dsi to the network.
1. Go to Nintendo Wi-Fi Connection Settings of the Game
2. Search for an Access Point (SSID)
3. Select your Network (SSID), If you have an open network, just click "OK" and it should work just fine! If it's a Red Padlock, it'll prompt you for a Password or Network Key. This is the reson why we access the router.
4. Test the Connection.
Thanks for using Fixya.
Posted on Mar 28, 2011
I need internet on my dsi
Well, have you done the homework?
1. DSI needs WiFi, ie, wireless internet. Do you have a wireless router or wireless modem router in your place?
2. If yes, have you enabled the wireless radio in the router. This can be done by opening up the router options by typing the IP Address of the router (it should be somewhere written in the router itself) and login. If you don't know the password, google your model number and you will get all information like default ip address, login etc. If possible download the manual from the manufacturer website and go through it to familiarize the options. (If you have an apple router, you will need "airport utility"..google).
3. Once logged in as "admin", look for "wireless" options (Manual will help you), enable "radio", "ssid", note down the ssid name, and for troubleshooting purposes, leave the security "off/disabled". Save/apply changes.
4. Make sure wireless "G" is selected or a mode thats compatible with wireless "G" (go through the options, mostly default option will suffice). If this is in another page, again, save or apply changes.
5. Reboot the router, wait for a couple of minutes till the lights for internet and wireless appears.
6. From DSI, search for available networks, find the ssid name that you have noted down and click connect.
7. Hopefully, it should connect, otherwise, you may have to manually enter DSI IP Adress, subnet mask (255.255.255.0), gateway and dns servers (both router IP Adress). If your router address is, say 192.168.1.1, then give dsi an ip adress 192.168.1.xx where xx is a number between 2 and 255. That is, what ever ur router ip address is, just change the last digits to anything under 255, excluding the router address. Now try again, hopefully everything should be settled.
8. Look into DSI manual to see whether it supports wpa/wpa2 security or just WEP. You may also have to take into consideration any other devices that connect to router wirelessy, like laptops, smart phones, tablets etc. If all of them supports wpa/wpa2, go back to router options and select that security, create password, write it down. Otherwise select "WEP" encrryption. (The point to remember here is the lowest common denominator, ie, if DSI supports only WEP, selecting WPA/WPA2 will be useless, as DSI will not connect, even if it sees the SSID.
9. Save changes, reboot router, wait for lights to steady.
10. From DSI, again select your SSID name from available networks (just to make things easier, shut down DSI, restart to disconnect earlier connections), it will ask for password or both password and security type. If DSi supports WPA/WPA2, and ur security is set as such, and DSI is not connecting, play with the options, if any, like "WPA only", WPA2 only" WPA/WPA2" and try to connect.
You should succeed with this much details. Good luck
Jan 15, 2012 | Nintendo DSi Matte Blue Console
How to get free wireless internet for dsi
The DSI has the ability to connect to wireless networks. This means that if you are at home, or somewhere that offers Free Public Wifi, you can join that network and use the wireless on your Nintendo DSI. Otherwise, you will not be able to connect wirelessly to networks without their password.
Sep 06, 2011 | Nintendo DSi Black Console
I cant connect to the internet. It says that there something wrong with my access point settings because it cant obtain an IP address.I have tried to type in all of my codes that i could find that apply to...
some portable devices do not like certain WEP modes on routers. also some may be able to see the wireless network but cannot connect because of the format is either wireless "G" or "B" or wireless "N" the latter of which you won't be able to connect to because of the format. check your devices for wireless type "G" only or "B" only or "N" only connections. aslo check for WEP type allowed as well!
Wireless "N" and the "Super-G" are the newest wireless routering devices you must check for compatibility issues. this information may be found in your user's manuals for your devices.
Aug 22, 2011 | Nintendo DSi XL Burgundy
How do i connect my nintendo dsi system to the internet?
Hi there!
If you wanted to connect your Nintendo DSI to your wireless connection, just follow the following steps:
  1. Access the system settings while the Nintendo DSi is turned on
  2. Go to the third page and you will find there "Internet"
  3. Choose connection settings from the menu
  4. Click "none" for Connection 1
  5. Click on "Search for Access point"
  6. Your Nintendo DSi will search the available wireless connection in the area and your wireless should be listed.
  7. If you are using a secured wireless, you will be ask to enter the wireless key
  8. Once done, click on OK, Save Settings then Yes
  9. It will do a connection test and it will show if the test is successful or not.
If you want a video tutorial, just head to this website: Nintendo DSi Internet Connection Guide.
Hope this helps.
May 19, 2011 | Nintendo Dsi Pink Console
Try rebooting your router or modem and moving close to the source of internet when attempting to obtain an wireless connection for you DSi. If this doesn't work, try contacting Nintendo or your wireless internet provider for further solutions. If you need anything else, let me know!
May 18, 2011 | Nintendo DSi Black Console
Why cant i get on internt with my dsi when i have wireless connection?
the DSI only supports certain wireless security settings, if you go to the nintendo site there is a whole section based on how to get your DS/DSI on the internet
Mar 20, 2011 | Video Game Consoles & Games
I cant get internet on my dsi for some reason and i got wireless at home and i dont know how to get internet on it
Welcome to Fixya. If you want to connect yout Dsi to the internet you can follow my Guide.
Feb 21, 2011 | Nintendo Dsi Pink Console
I cant get the internet to work even when im at a place that has free internet its not working??
Greetings,
Here are the steps to connecting to a wireless network with your Dsi according to Nintendo:
  1. Turn on your Nintendo DSi and access your system settings by clicking on the wrench icon. systemsettings.png
  5. The easiest way to get connected to Nintendo's Wi-Fi Connection is through the "Search for an Access Point" function of the Nintendo DSi and Nintendo DSi XL.
Thank you for using FixYa! =) If I helped, please give me a rating.
Nov 25, 2010 | Nintendo Dsi Pink Console
I have a dsi and a sd card but i cant get internet
go to system settings, go to internet (page 3), connection settings select a connection (1,2 or 3), search for access point, choose your access point. For Aoss, go to a connection (1,2 or 3) tap Aoss, push the Aoss button on the access point until the light flashes (P.S you need wireless internet or Aoss)
Jul 11, 2009 | Nintendo DSi White Console
Nintendo DSi Blue Console Logo
212 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
