Question about Kenmore Side by Side Refrigerator
I have a Kenmore side by side. The refrigerator section is freezing everything. Its turned all the way down too.
    Scholar:
  • 116 Answers
HI this is a bad damper assembly, depending on the model the price can vary alot. This is usually located in the upper left corner of inside the refrigerator compartment.
Sean
Posted on Mar 28, 2011
Why would food in the refrigerator side freeze?
probably your Damper unit! In the fridge section is a hit and miss type vent using a motor to open and close via PCB temp sensor!
Oct 07, 2015 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The freezer section of our Danby DFF8200W freezes well. However, periodically the refrigerator section freezes everything in it with the temp control turned as low as it will turn for me. The dial does not...
Make sure you clean the backside of refrigerator at bottom from dust. Make sure you have the recommended clearance from wall. Also make sure the food in freezer and frige have clearance to allow air to circulate around food. Keep playing with your controlls...The dails might be on wrong
Aug 11, 2013 | Danby Refrigerators
Kenmore 50522 refrigerator freezing everything
What is the model number listed in the refrigerator section?
Oct 15, 2012 | Kenmore 50522 / 50524 Side by Side...
Suddenly the refrigerator is freezing everything we have not changed the settings we tried to even turn down and is still freezing the food.Help!
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 04, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water wont dispense but still makes ice. Also fridge side gets extremely cold no matter the settings and freezes stuff in the bottum drawers
Since your freezer control is the main thermostat , and your refrig control is only a damper , lower your freezer setting and turn the refrig control mid way . This will make the refrig run less , and keep the air flow moving , throughout the complete unit . When the airflow stops , by turning down the refrig control ( closing the damper ) , all the cold air will settle in the refrig section , thereby freezing everything in the lower section .
Since the water line runs thru the freezer door , too cold in the freezer section , will cause the water in the line to freeze . I would also suggest installing a dispensor heater ( pt. # WR49X10173 ) , which would hopefully avoid water line freeze , in the future . This part comes with installation instructions .
Nov 08, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Comperssor kicks on but quickly cuts off intermittently every 5 minutes on my frigidaire fridge side by side
Freezer defrosted everything fan continues to run but will not freeze. Compressor is cycling enough to keep refigerator section cold. 106 Series Kenmore. Turned up thermostat to keep fridge cold and a shorter intermittent compressor cycle run
Jun 06, 2009 | Frigidaire FRS26H5AS Side by Side...
Kenmore Elite fridg freezing everything
Faulty Thermostate, shouldn't cost much to replace. good Luck , the Yeti
May 20, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Pop and water freezing on the frig side
turn the temp control down a notch or 2
Dec 30, 2008 | Refrigerators
Kenmore Side by Side Refrigerator Logo
46 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
