Question about Dishwashers
Kitchen Aid Superba Wisper Quite will not start cycle
This is an 17 year old diswasher that will not start a cycle until you open and close the door kind of hard to get it started. Sometimes you have to do it 5 to 10 times before it "kicks" in. Other than that, once it begins, it finishes the cycle programmed. Before this problem, you use to open the door and hear "clicks" that sounded like relays resetting preparing the dishwasher for the next cycle. Since this problem existed, we do not hear those clicking sounds anymore when the operation is finished and we open the door.
Intermittent door switch, should be available, easy to change out and inexpensive.
Posted on May 19, 2009
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ksrg25fkwh01 wire harness
Called Kitchen aid and protested, frig was 4 years old at the time. door was almost $1200 to replace. Kitchen aid paid for new door and installation
Sep 19, 2012 | KitchenAid Superba Architect KSCS25INSS...
Hi!! My Kitchen Aid superba microwave oven says door and the door seems to work okay. Any suggestions?
the micro switch is probably faulty which tells the machine the door is actually closed or open. this would need replacing which means pulling the unit apart.
hope this helps
Aug 20, 2010 | KitchenAid Microwave Ovens
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
Kitchen Aid Superba - door needs adjustment
there is two bolts oin the very front of the unit behind the kickplate the oiu can turn clock wise until there is a slight tile toward the back of the unit so that the cams on the doors will have a little bit of gravity to helop them stay shut.
Mar 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid superba door problem
HAVE YOU TRYED ADJUSTING THE TOP HINGE?MIKE
Oct 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen aid -Superba 42,
Make sure the fan motor is running in the freezer.
Sep 15, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchen Aid Superba Dishwasher
check the holes in the spray arms to see if they are plugged also brand and model number will help
Mar 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Dishwasher
gagaweaver, couple of things you want to check here. Check the upper spray arm for any clogged holes or cracks along the edges. Position it in the 12:00 position and run the dishwasher for a little, open the door and verify that it has rotated. Make sure the water entering the dishwasher is min. 120 degrees, use a thermometer. Makes sure that there is no large pans or dishes blocking the upper spray arm from spraying onto the inner door. If all that checks out. You will have to remove the lower spray arm, filter cover and chopper cover to make sure the chopper screen is not coated or plugged up. If it is, it will prevent a good flow of water to the upper spray arm. Catriver..post back.
Mar 07, 2007 | KitchenAid 24 in. KUDU02FR Built-in...
Kitchen Aid diswasher controls don't work
The Button is part of a switch control (all the buttons are individual switches) - take the switch block out of the door and test the button (switch)for circuit continuity, if it is OK, then the timer control may be the problem. My machine had progressive failures through the various cycles until most do not work and it wa the timer that was failing bit by bit.
Dec 20, 2006 | KitchenAid 24 in. KUDI02FRSS Stainless...
Dishwashers Logo
138 people viewed this question
Top Dishwashers Experts
