Samsung dvd writer model number sh s202 jumper settings it is set to slave with a sata hard drive what do i do about the jumper settings?
Drawsalot
  • 38 Answers
SOURCE: jumper settings for an older maxtor hard drive
Support can be found at Seagate.com in case this is not the exact drive. The model number you listed was not an exact match.
Posted on Nov 25, 2007
SOURCE: jumper settings for maxtor
how to setting jumper for external maxtor 80gb model?
Posted on Aug 22, 2008
ODCaloney
  • 260 Answers
SOURCE: jumper settings for samsung dvd drive
There should be a diagram on the drive indicating the jumper positions. Good luck!
Posted on Mar 13, 2009
siawolf
  • 749 Answers
SOURCE: pin settings on a samsung hd080hj/p sata hdd
Hope this helps.
Posted on Apr 11, 2009
  • 173 Answers
ok
check your ide connectin that blue end of ide cable always at motherbord .also check that your ide cable is working properly.
Posted on Jun 23, 2009
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
I have a dell computer and installing a samsung dvd-writer model sh-222 and it is not seeing it. How do the cable get installed on the slave or master?
if your using sata connect then it really does not matter the mother board will detect it as it wants though it should be plugged into master 1 and hdd into master 0 if your using the older type ribbon then you must make sure that the dvd player has its jumping pin plugged into slave at the back of the dvd writer. there is a small cluster of 6 pins with a small plastic jumper that needs to be put on were it says slave
best of luck need more help feel free to email
merry christmas
Dec 07, 2010 | Samsung Computers & Internet
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
How to put a second dvd drive in computer i ave both in but only reconises 1
if you are using IDIE cable.set as try to see the jumper on the markings slave. if sata it will auto detect.
Jul 10, 2009 | HP DVD1040i 20x Super Multiformat Dvd...
Cdw dvd sh-m522c
please have a look to your jumper setting...
if you didn't got your dvd driver after jumper sittings then reply to this thread.
Nov 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Samsung SH-s203 dvd writer is compatable with this motherboard
put the sata cable to sata terminal and also connet the sata power cable to drive.
Oct 28, 2008 | Intel D845GVSR Motherboard
Unable to detect second
Check the jumpers on the back of the drive to ensure you have no conflicts. There are 3 settings M, S, CS which mean master, slave and cable select.
Cable select requires a special cable in your computer with fine pitch 80 wires, usually with one blue connector at the motherboard, one black for the master drive and one grey for the slave. This colour code is not used by all computer manufacturers, though and they may all just be grey.
If you have this cable, make sure the jumper on your drives is set to CS. Otherwise, on each cable (there should be 2 in your computer and the hard drive should definately be master on one) you can have only one master device and one slave.
Jul 17, 2008 | Samsung (SH-S162L/BEBN) DVD RW Burner
Dvd writter not working
if the device is set up as a master and not a slave device it may be interfering with the hard drive. check the jumpers on the back of the device. If it's plugged into the same cable as the hard drive it must be a slave device. Otherwise, check your bios upon bootup to see if you it's trying to boot from the device instead of from the hard drive.
Nov 29, 2007 | Samsung WriteMaster SH-W162C DVD?RW Dual...
DRW-1814BLT compatibility with IDE hard drive
put hard drive as Master. dvd rw as slave!
if DVD comes with sata then just put hard drive as master.
configure it on the bios setting!
if it still don't detect it
try replacing IDE cable and sata cable!
Nov 15, 2007 | ASUS (ASUDVDRWM6N) DVD-RW Burner
Samsung dvd writer
Most common problem is the "jumper" setting is wrong. You can do several things. Some you may already have done, but check it any way. 1. make sure the SATA cables are completely plugged in correctly. Power is plugged in. 2. Check the "jumper" on the back of the burner. Should be in "Slave" position even though the manual doesn't say it, it says "Master/Slave". 3. Go into "control panel", then to "system" then to "Hardware". Check to see if you have a "yellow !" for CD devices. If you do click on it and remove it. Close all windows and "restart". That should fix it. If it doesn't, check the "compatability" of the Motherboard per Samsungs website. Some mother boards are just not compatible. Might not hurt to check that first before you do anything else.
Jul 20, 2007 | Samsung Super-WriteMaster SH-S183L Burner
Computers & Internet Logo
514 people viewed this question
David Payne
David Payne
