Question about ASUS Eee PC 1005HA-PU1X-BK Netbook
Cap lock is not working. it remains on the all caps mode. what should i do?
    Novelist:
  • 107 Answers
This might help - click here
Posted on Mar 28, 2011
2 Suggested Answers
AndreaBl
  • 218 Answers
SOURCE: Caps Lock stays in this mode and types capital
hi there,
have you tried cleaning your keypad with a brush?
also check your onscreen keyboard, if it has the same effect.
lastly, go to your control panel, then to your keyboard options and check if everything is in order. there could be that you have added another option to your keyboard's list of languages.
Posted on Jun 26, 2010
Ì can't get the gas cap off, any ideas
One or two things. Does the cap lock with a key? If so, the cap is either still locked or is remaining in the locked position. Get it to a lock specialist as soon as possible. Another possibility is that the lip on the tank filler neck is damaged, and the solution is to force the cap off. If nothing else works, you can remove the filler neck from the tank by undoing the flexible hose that holds the neck to the tank, the bracket/s that holds the neck to the body of the car - this must be done usually from the underside of the car, and there should also be screws that hold the filler neck to the body inside the filler well. It is a finicky job, but if you can do this, you can take the neck complete with cap to someone who can help, or get a new neck from the dealer or a breaker yard and fit a new cap.
Feb 21, 2015 | Cars & Trucks
The caps lock key came off. How do I put it back on? Do you have any pictures or diagrams?
  • hi,
  • as you can see below is the screen shot of a keyboard. there is a key named "Caps Lock" you just need to press it to activate and deactivate the caps lock mode
  • hope this will help you
Feb 28, 2010 | Office Equipment & Supplies
PC shuts down while running Windows
Attempt to boot the machine in Safe-Mode.
While powering up continuously hit F8.
You will get a Boot Option Menu, Select Safe-Mode boot
If you can get into safe-mode I would suggest to try doing an online scan, as it sounds like your issue could be related to malware:
www.trendmicro.com/housecall
Let us know
Good luck
Apr 15, 2009 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
My Logitech EX110 wireless keyboard has no light indicators for CAPS LOCK and NUM LOCK. Should it have those indicators?
Your EX 110 receiver has 3 indicator lights (LEDs) that display the status of the Caps lock, Function key, and the Num lock during normal operating mode. These lights will also flash when the connect button on the receiver is pressed.
LED A: Indicates that the Caps Lock (Capital lock) key is on when lit.
LED F: Indicates that the F keys are in Standard F Keys Mode when lit and in Enhanced F Keys Mode when the LED is off.
  • Your EX 110 keyboard has an Enhanced F Keys Mode for F keys that provides additional functions you can program. See Knowledge Base article 9526.
LED 1: Indicates when the Num Lock (Number lock) key is on. This function allows the number pad to produce only numbers
Mar 27, 2009 | Logitech EX110 SP CORDLESS Keyboard/Mouse
Motorola w260g Caps Lock
Solution: Type a letter and press the 0 key. Happened to me too.
Feb 13, 2009 | Motorola Cell Phones
Cap Lock on or off
Feb 11, 2009 | Logitech Cordless Desktop EX110
Letter remains in uppercase
Is the caps lock key light on? If so hit the caps lock key to get the light to turn off. If it doesn't turn off then your keyboard is bad and will need to be replaced.
Jan 29, 2009 | E-Machines eMachines Desktop PC
Lumix DMC FX8 lens cap opens intermitently,some images shoot rotated 180 degrees
hi, i've an fx8. i had a problem 2 weeks ago. my objective didn't want to close when i switched the camera off. it remained open. when i switched the camera on again, the objetcive has closed and opened again, and the _Turn Off the Camera and Turn On again_ message appeared on the sisplay. and remained in open position after switching it off. i tried some button combination, like menu button on, and power the camera on. it didn't work, but the second was the shotting button on, power on combination. an it worked, my camera did some kind of reset. it returned to the original position, and everithing is working since then.
Feb 12, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
No display in record mode on Samsung VP-D31
Sounds like you may have a problem in the auto iris curcuit or the auto settings was switched to manual and the lens is closed. Check first to see that the lens is setup in auto mode. If it is then the auto iris as i said before is bad or stuck closed unless the small caps in that curcuit went bad as they always do after a few years. Good Luck
Apr 14, 2006 | Samsung VP-D31 Mini DV Digital Camcorder
ASUS Eee PC 1005HA-PU1X-BK Netbook Logo
181 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
