Question about Performance Designed Products Afterglow AW.1 Remote for Wii - Red
We just bought afterglow controllers for our wii. Followed "installation" instructions as printed. According to directions, remotes were synced with wii system, however, remotes DON'T work. They light up, and when wii game is on, the hand shows up on the screen but remotes don't work. We can't click on anything. THe original remote that came with wii is the only remote that will control anything on screen.
How do I get my PS3 afterglow controller with a chargeable battery installed to connect to my PS3 system. (afterglow controlder does not take AA batteries).
Afterglow AP 2 has a flat nickle battery
upgrade your controller
i take it yours is not a wireless
PS3 wireless afterglow controller uses aa rechargable
Mar 31, 2017 | HOW Video Game Consoles & Games
I had this remote for a bit now and today it just want turn on it is just vibrating what do I do
It sounds like your controller is having issues and needs to be repaired. This does not sound like a normal occurrence. Have you tried changing the batteries?
Oct 20, 2013 | Performance Designed Products Afterglow...
Wii remote afterglow keeps losing contact with wii
take the back off and replaces the battery or it's time for a new remote. you can Find Cheaper Ones on ebay and Craigslist
Jul 05, 2012 | Nintendo Wii Console
Whilst using the wii to go online my son said the wii remote just stopped working so thinking the batteries were low he put it back on the docking station & left it to charge up. Yesterday when I went...
Try buying a new remote.or press the sync button on the wii console for 15-20 seconds then resync all controllers in the wii one by one.hope this helps Julie Dentith. :)
Apr 15, 2011 | Nintendo Wii Console
How do you install batteries. Redoctane Wireless Drum Controller For Nintendo Wii Model No. 95521.805 How do I find print out of instructions? Chuck
The RedOctane Guitar Hero Wireless Drum Controller for the Wii is powered by the Wiimote. To replace the batteries for the drum set, you would remove the Wii remote from the drum set, replace the batteries in the Wii remote, then reconnect the Wiimote.
Mar 22, 2011 | Video Game Consoles & Games
I bought rock band 3 for wii. I plugged in the dongle for the keyboard and followed the sync instructions exactly. the lights flash on both devices, but when I let go of the sync buttons, the lights on...
This can be frustrated the first few times. Here's the likely issue: the wii version will not activate the keyboard (or drums) if multiple wii remotes are active and all-instruments mode is not enabled.
The multiple wii remote thing: one remote is considered the microphone, and the rest guitar controllers (you can use the wii-remote based wingman and guitar hero guitars with this title). Once you get to two plus wii remotes on, you can't add more.
So, assuming one of your guitar controllers is active, use it to go into the menu system and turn all instruments mode on. Once done, a wii remote is no longer needed to be used for singing, and now singing will be turned on by default (but you can ignore it). Now, your drums and keyboard should work fine.
Eventually, the game smartens up and turns on this mode automatically for you, but the first few times it does not. I nearly threw the game out the window the first day or so.
Dec 31, 2010 | Rock Band 3 Wireless Keyboard
I have a logitech remote for my tv, just bought a wii game. Do i need to program it into my remote as i cannot get the wii to work?
Because the Wii does not have IR receivers, it is not directly compatible with the Harmony remotes. However, you can still create a "Play Wii" activity that will turn on your other devices that are needed for the activity and set them to the correct inputs. So, for example, you would still need to turn the Wii on manually, but you the "Play Wii" activity would turn the TV on, set the correct input for the Wii and activate your sound system (if separate from the TV). Hope this helps!
Feb 17, 2010 | Logitech Harmony 880 LCD Remote Control
The best thing I can think of is to turn on the wii, go to the tv and press tv/video once and if nothing shows up then press it again (this will take your tv to video 2) and if that doesn't work then turn your tv to channel 3 or 4 and see if one of those channels work, also if your wii is plugged into a vcr or dvd player make sure that vcr/dvd player is on!
I'd recommend just directly plugging the wii into the tv though on the count that its easier to setup that way...
If this doesn't work then call nintendo because their customer service is superb in my opinion.
Jan 25, 2010 | Nintendo Wii Console
Unable to play my brand new wii fit
I was just being really thick!! Eventually I found the right button on the remote and there it was on the screen. Thanks anyway though, and I know where to find you again. Sure I will!
Apr 14, 2009 | Nintendo Wii Console
Performance Designed Products Afterglow AW.1 Remote for Wii - Red Logo
96 people viewed this question
Top Performance Designed Products Video Game Consoles & Games Experts
James Wishart
Are you a Performance Designed Products Video Game Console and Game Expert? Answer questions, earn points and help others
