Question about Boating
I have a 1988 model GameFisher 9.9HP motor. The problem is that it will not syck gas on its own. I can pump the primer until firm like you are suppose to and then the motor will start fine but as soon as I run it for about twenty seconds at full throttle I will have to pump the primer again. It will run longer if I am at idle speed. The short block assembly has been replaced due to engine failure and also all the gaskets have been replaced. The only thing I have not replaced is the actual fuel tank itself and the hose and primer. I have not replaced and reeds either. Is it possible it could be a reed valve not working? Beacuse there is a couple on the carb and on the fuel pump as well. I took the motor to a private mechanic before I replaced the short block assembly and he said that the motor was sucking air was the reason it wouldnt **** fuel but in replacing the gaskets and short block assembly I cant see that being a problem now. Please reply back. The motor runs strong but it is a great inconvenience having to pump the primer every so often to stay running. Any replies will be greatly appreciated. Thanks, J. Pendry
  • 48 Answers
There are several things that it might be. It could be the gasket on the crab sucking air from not being tight or from being craked. The first thing I would check however is the air vent on the gas tank. It sounds to me like the tank might not be getting enough air. I myself have run a motor before without thinking to open the vent on the top of the gas tank. If these things don't work also check the gas line for cracks or a loose hose calmp or connector. It sounds to me more like the vent in the tank though.
Posted on Mar 28, 2011
  • william moore
    william moore May 02, 2011
    Sounds like you have the Clinton 9.9. this engine had a ported crank shaft. (no reeds) The fuel cap vent was good, but that fuel pump on the side of the carb had a tiny screen pressed into a pocket under the fuel line connector on the carb that would varnish over. Also the nylon reeds on the carb at that same location had a tendency to curl away from the ports they were supposed to seal. Finally- if you are running the remote tank on a long hose or far from the motor, that tiny orange bellows pump bladder in the carb couldn't do the job. Try setting the tank on the seat at engine level and see if it improves.
  • tiltdeck May 02, 2011
    Hi again. From the sounds of things you have a fuel pump problem. If the hose connections are all tight and the tank is vented properly it can only be a fuel pump or carb problem. Without physically having the motor here to work on it is very hard to diagnose properly. If you had accesss to another motor the same you could also swap parts until you find the exact problem. You might also try gravity feeding gas to the engine and see if this helps and it will also help to see if it is in fact the carb or fuel pump.... hope this is helpful
The main jet is clogged, the one that screws into the Main Nozzle, it looks like a screw and has a hole in the center, it is probably clogged, this will solve your problem
VIC VICJ6349@GMAIL.COM
Posted on Jun 14, 2012
  • victor Jun 14, 2012
    the main jet is clogged, the one that screws into the Main Nozzle, it looks like a screw and has a hole in the center, it is probably clogged, this will solve your problem
Starting proceedure for 72 evinrude outboard?
  • Check all connections , fuel, battery, etc
  • Squeeze primer bulb until firm
  • Lift choke switch , listen for operation (click)
  • Raise idle speed lever, not too much, be prepared to lower quickly if engine starts to over rev . (remember, this is a 1972, it does not have much for safeties.)
  • lift and HOLD choke switch
  • Turn key to crank
  • release choke when fires
  • if running, you may have to flip choke switch again until it warms up.
  • watch idle speed as 2 cycles can "run away"
  • Hope this helps
  • All of this assumes the motor is in the down position and IN THE WATER or hooked up to a flush device.
  • NEVER start the motor without water going to the gear case(water pump)
Feb 16, 2015 | Boating
Out of Diesel
This particular JD engine has an individual fuel pump for each cylinder. The injectors, fuel lines, and pumps are not accessible from outside of the engine. There is a hand primer pump built into the top of the fuel filter. Start by removing the rubber outlet line from the filter base and pump the primer pump until fuel come out of the filter base outlet. Ounce fuel comes out of filter reconnect the line and continue pumping by hand until the pump button feels solid, then crank engine until it starts. This works better if a helper is available to operate the starter while continuing to pump the hand primer. This is normally all that is needed after running out of fuel.
If fuel does not come out of fuel filter base there may foreign material inside of primer pump. Primer pump can be disassembled and cleaned. If fuel comes out of filter, primer pump become feels solid but engine does not start the fuel control rack inside of engine may be sticking in the off position. This may sometimes be overcome by clicking the key switch from off to on rapidly. If not you may have to have your dealer remove the governor cover to free the rack.
Mar 19, 2014 | John Deere 4020 Gas & Diesel Tractor...
I have a 50hp johnson outboard the motor is turning over but I dont seem to get a spark to the plugs
would this help
Primary cause of hard cold start: operator error.
Open gas tank vent, pump primer bulb until it is firm, raise hi-idle lever full up, push the key in and hold it in while turning it to "start".
If you can flood your engine with the primer bulb, then your carbs need rebuilding. Pump the bulb until it is firm - that fills the carb bowls - they have a float valve that closes when full. This is true of every carbureted 2-stroke outboard ever made.
"Pumping the throttle" is useless - these are not automotive carburetors - all it does is open and close the butterfly valves.
Your motor does not have conventional choke plates; instead it has a primer solenoid, which opens a valve and allows fuel to drain into the cylinders to richen up the mixture for cold starts. You should hear the solenoid "click" when you push the key in.
Bad compression leads to hard cold starts - you should have at least 100 PSI in all cylinders, and the lowest needs to be within 5% of the highest.
If you have good compression and spark on all cylinders, the primer solenoid actuates, and the fuel line holds pressure, then you need to remove your carburetors, dissasemble, soak overnight in carb cleaner, blow out passages with compressed air (or aerosol carb cleaner), reassemble with new kits (including new o-rings, gaskets, and float valves & seats), reinstall, link & sync, and adjust slow-speed mixture
Mar 15, 2013 | Boating
The saw s primer bubble split ...i replaced the primer and it ran fine..then just quit... i changed the gas and checked the plug for fire .its ok..........but it will not fire ????
I would see if you have a air pocket in your gas lines.Try removing plug and pumping primer bulb until you know engine is flooded. Then let dry out before you put plug back and try to start. Thank you.
Apr 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
I have a 1988 ranger and I think I have a fuel delivery problem. The engine will turn over but It will not keep running.
Have you tried spraying starter fluid into the intake manifold while someone else tries to start it? If it will start that way, then it is most likely the fuel pump needs replaced. You can also try to push in the fuel primer, it is on the passenger side if it is a 2.9. It will or should have a black cap similar to what you would see on a tire inflation valve. Unscrew the cap (do not lose it!) and while someone turns over the motor press the needle in the primer in with a screwdriver, if fuel squirts out then your fuel pump is ok.
Dec 31, 2010 | 1988 Ford Ranger
Need to know how to re-connect primer bulb on McCulloch Model # B00032-32, Ser # 11-100258 (McCulloch Gas Powered Chain Saw)
Take the line off of the primer that goes to the tank and leave loose for a moment. The other line to the primer comes from the carburetor and it should be be tried on either port on the primer until it will pull fuel into itself when pumped. If neither port works, the primer pump may be faulty, the carburetor is plugged internally, or the fuel line from the tank to the carburetor is decayed or the fuel filter is plugged. When the primer pulls fuel into itself, reconnect the return line that goes back to the tank. Hope this helps!
Dec 03, 2010 | Garden
I bought a 5 HP gamefisher outboard motor. It 's been use once and then it sit for years outside. I change the spark plug,clean the carburator,fuel filter looks good.good compression. gas go all a way to...
If spark plug is dry, fuel is not getting to the cylinders. Next thing to check would be the fuel pump... Gas may be getting to carb, but the pump needs to push it into the cylinders too.
Oct 18, 2009 | Boating
I have a 1988 gamefisher outboard motor I need to put a water pump on other than taking the bolts out at the bottom is there any thing else that need to be disconnected before pulling the lower unit thanks...
yes!! there will be a cover in the back of the upper part of unit. you will need to remove this and disconnect the shifter from the lower end.
Jun 20, 2009 | Boating
Where is the thermostat and waterpump located on a sears 9.9hp gamefisher outboard motor
water pump is in the lower end of out drive and there is no t-stat
May 05, 2009 | Boating
Boating Logo
718 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
