Question about ION Audio SLIDES2PC
I bought an Ion Slides2PC device yesterday. I got as far as trying to "get photos" . When I click on that, I get a pop up, "Fail to register write". By clicking that five times , I get another pop up, "General failure in transfer bad info header info. Bad value error." Then it just seizes up and I have to "Ctrl Alt Delete" and start over. Help!
2 Suggested Answers
  • 32 Answers
SOURCE: Problem with SLIDES2PC
I think there is a buffer that has to be cleared after so many pictues ie processed.
Posted on Dec 14, 2011
Dec 14, 2011 | ION Audio SLIDES2PC
I have IonAudio Discover Guitar. I am a Mac user, 10.6.8, MacPro 3GHz Xeon Dual Core with 6 GB RAM. The instructions say I should create an Aggregate MIDI Device under Audio MIDI Setup with the following...
Have you tried the guitar in another Mac/ PC? If it still doesn't appear, there may be a problem with the guitar electronics. If you bought it new, take it back to the shop/ send back to the vendor.
Sep 10, 2011 | ION Audio ION DISCOVER GUITAR USB
I am running Windows 7, I purchased the ION VCR2PC, but could not load drivers from EZ VHS Converter disk included. I went to the ion-audio website and downloaded the zipped driver folder to my desktop. ...
what were the instructions you followed?
the drivers might be installed properly for this device
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
hope this helps you
Aug 30, 2011 | ION Audio VCR 2 PC USB VHS Video to...
We bought my son an RCA mp3 player yesterday (TH1814-A). We inserted the battery and are trying to plug it into my desktop using the usb connector so that we can upload some music. however, when i plug...
There are different types of USB port. For instance my computer has two types. One with a blue connector and one with a black connector. It might be that your USB ports are not suitable for that device. You need to check the specifications of the USB ports on your computer and the specifications of the MP3 player. Continuing to use the device might cause damage to the computer.
Mar 19, 2017 | RCA Audio Players & Recorders
I bought an Ion Slides2PC device yesterday. I installed the driver and the PhotoImpression 6 software tonight, but when I tried to launch the latter, I got a Runtime Error. What does that mean, and how do...
If you tried installing the 64 bit first on a 32 bit OS, that could be the issue.
Try doing a system restore back to a point before the installation, and install the 32 bit version and see if that fixes it.
Runtime errors can be a bit tricky to track down.
Mar 10, 2011 | ION Audio SLIDES2PC
My PC doesn't recognize my OVT scanner. Suggests I contact manufacturer regarding driver software support. Can I get access and a free download? What do I need?
this is the 32/64 bit drivers (copy and paste into your browser)
32 bit
http://www.ionaudio.com/stuff/contentmgr/files/26/d6d3a7895969750864ba4bd2db1ec94c/file /slides2pc_32_bit_windows_drivers_2.1.0.3.zip
64 bit
http://www.ionaudio.com/stuff/contentmgr/files/26/c62d2ba1c2036e5f1da81004314d23cb/file /slides2pc_64_bit_windows_drivers_2.1.0.3.zip
this will download the drivers for your product. you should not connect your device before installing the drivers. wait until the drivers are installed first. if you are unsure which version you are running, simple to find out .......
click start button, right click on computer, and select properties. the operating system version will be listed in the dialogue box.
Feb 03, 2011 | ION Audio SLIDES2PC
I have Windows 7 and have installed the correct driver, but it still gives a message - can't find scanner. Have tried uninstalling and re-installing a few times. Also looked on Google - it seems many...
if you ran the driver and it is installed ..check it on the device manager (right click on my computer ..properties/ hardware/ device manager ..and if the scanner appears in yellow you have to click right and update driver..It will run the add new hardware wizard and you will have to go along with it ..either let it make this manually ..it should find the driver you installed previously ..and install it ..or do this manually by choosing it from existing installed drivers..
There is always the possibility that the driver you have is not compatible ..so ..get on the support site and download the one for windows 7 from there or at least for the vista..
Jan 17, 2011 | ION Audio SLIDES2PC
I need help. I've used my memory card many times with no problems. Now I put it in my laptop and absolutely nothing happens. It shows under "Devices and Removable Storage" but nothing happens....
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. Apparently, you've gotten this far. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Instead of bringing up the properties, simply double-click the disk icon to open it.
Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Dec 15, 2010 | HP Photosmart M425 Digital Camera
ION Audio SLIDES2PC Logo
279 people viewed this question
Top ION Audio Office Equipment & Supplies Experts
Alun Cox
Brett Duxbury
Brett Duxbury
Are you an ION Audio Office Equipment and Supply Expert? Answer questions, earn points and help others
