Question about Philips 42PFL5603D 42 in. LCD HDTV
We were playing playstation last night on our tv, then afterwards we watched a movie until about 1:30 a.m. Turned it off and went to bed. When we turned it on this morning there is sound but the screen is totally black.
  • 1,606 Answers
That sounds like your back light has gone out. Either the back light or it's power supply failed. If you turn it on and get close a bit to the side you should see a ghost image. That will confirm it is a back light instead of a video section problem. A lcd type display creates the images on the lcd panel, but it doesn't generate any light. The backlight shines through and illuminates the images. Very much like a slide or move projector.
The repair cost really varies from model to model. The actual backlight can be repaired for under $150 in most cases. How ever if the power section is part of the main tv board then the entire main board needs to be replaced. That board on other sim sized tv's can run over $450. This is covered under warranty so the first thing you need to do is check if you have any warranty either extended store or the oem warranty. Then contact the store you purchased or go through the Phillips support to find your local repair depot and get ti sent in. If you do not have warranty then you have to be careful as you are paying for this. You need to get a estimate. A repair depot will have a very good idea of the repair cost.You should also have an idea of what a replacement tv is worth. Once you know how much the repair cost is you can then judge if it is worth fixing or if you should get a new tv. A new tv has a new warranty while your repaired tv will not. So if the repair gets too high you are better off replacing and not having any worries.
Posted on Sep 24, 2011
Sansui volume
Check whether the 'mute' function is ON. If it is On, there will be no sound output, but picture will be OK.
Jan 24, 2013 | Televison & Video
The sound on my Magnavox CD130MW9 stopped working
If the problem is same with different input devices and you have ensured the are no loose contacts in power outlet, RC jack, cable and sockets, the TV needs servicing.
Aug 21, 2012 | Televison & Video
Just bought a ps3 two weeks ago. Played games just fine and everything worked well. We watched a movie last night. Turned off the system and went to bed. The next morning we tried turning it on but it...
This may be a simple fix. Do you still have the original cable that came with it for the video OUT? Plug this back into your playstation and TV while leaving the HDMI cable connected.
check now both HDMI channels and AV/Composite options on your source selection this should give you the display,
Now what we need to do is setup your HDMI output again.
From the menu bar,
  • Go to settings
  • Display Settings
  • Video output settings
  • choose HDMI
if you have the choice to choose OK choose it. If your screen goes blank go through your HDMI channels again and if the Playstation screen is there then select OK,
Then you can remove the composite cable again
Jan 14, 2011 | Video Game Consoles & Games
Watching DVD's
Did you move to the Movie/Video section of the Main Menu? When you see it scroll down, your movie should be the item next to last. Thanks!
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't play and disk of any kind
Sounds like the laser just took a dive.
You can try updating the firmware to 2.76 but 95% of the time the laser needs to be swapped.
Jun 15, 2009 | Sony Playstation 3 (PS3) Console
Mitsubishi WT-42313 42 in. rear projection tv
I guess I have to pay money for a solution, which is not what this website says. The only answer I got was pay money and we'll tell you. Is that true/
Sep 16, 2008 | Mitsubishi WT-42313 42" Rear Projection...
PS#
I was at my brothers house last night playing Madden NFL 2009 and the game stopped working, we tried all the games he had, none would work. DVD movies worked, music cd's worked, but games no. So what I did is came home and searched the net until I found a solution. Here is a video clip of that solution from youtube.
http://www.youtube.com/watch?v=a6X1-vFYpEU&feature=related
Sep 06, 2008 | Sony Playstation 3 (PS3) Console
Playing DVDs
try to use an Audio-Video(AV) cable(it has two or three wires,ask for it at the electrics shop),and push the button AV on your remote control.
May 24, 2008 | JVC AV-27230 27" TV
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
No pic but sound :/
You are having a high voltage problem. Quite possibly in the horizontal deflection. I would check the horizontal output and regulator transistors.
Sep 27, 2007 | Toshiba 40H80 40" Rear Projection...
Philips 42PFL5603D 42 in. LCD HDTV Logo
94 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
