Question about HP Compaq dc7100 Ultra-slim PC Desktop
After my computer is idle for a short while I cannot get on the internet without repairing the adapter.
  • 31 Answers
Goto start>right click on computer>manage>Device manager>Webcam uninstall then restart computer. Computer should auto install it back after restart. This should fix it. If not Uninstall software then the device and reinstall software. If this does not fix then it will be a hardware issue and will either need a new one or fix the current one.
Posted on Mar 27, 2011
Dell inspiron 560 won't recognize network adapter
if there is no netework adapter in device manager or any device that is not instaled try checking in BIOS if it is enabled. sometimes after power loss bios is reset. if it is enabled in BIOS that short power outage probably killed your network adapter. you can add some PCI network adapter and solve your problem.
Nov 04, 2012 | Dell Inspiron 560 MT Celeron 450@ 2.2GHz...
Dell latitude d520 starts with battery but not with ac adaptor
It could be a bad adapter, a short that drags everything down when plugged in.. could be a short inside the computer doing the same thing.
Borrow an adapter to see if you get the same result, if a friend or shop will help you with that.
A digital VOM could tell you if the right voltage is being put out by the adapter. Read on it, if it's supposed to be DC voltage and you get AC, the adapter is bad.
Oct 02, 2017 | Dell Latitude D520 Notebook
Hello, I have a Dell Inspiron 1501. It has shut down on me in the middle of my session and now will not come back on. I plugged in the adapter for it to charge a few mins then the charging light shows but...
Don't think as a battery error, if you can use without the battery ,pls check with ac adapter without battery.because there may be a short circuit with charging unit or power side, you have to test before blow up the unit. if blow up chip or mos fet, it will be hard to repair.
May 05, 2017 | Dell InspironTM 1501 Notebook
How do you do a factory reset without a system recovery disk on a dell 1300 inspiron laptop
for the computer reset or windows? computer reset: disconnect everything ( adapter, battery, etc) then hold the power button down for 30 seconds, connect adapter and turn on. windows: try to get an installation disk if you do not have one of the same copy that's on the computer, run but shortly into setup there is an option for system recovery, run it ( win 7 is listed as "repair my computer")
Jan 07, 2011 | Dell Inspiron 1300 Notebook
Internet works fine on all other computers, but on my desktop with this wireless adapter. The internet works off and on throughout the day, but usually never lets me connect.
it sounds like your computer is set to turn off that device for when its not inuse (or system goes idle) you can fix this by going into the properties of the card its self and turn off that option it should be under the last tab if you wold like more help please message me back
Jan 06, 2011 | Linksys WUSB54GC 802.11g/b Wireless...
I recently had my computer "cleaned out" from any viruses, etc...got a new ethernet cable also...since I have not been able to get wireless connect to our playstation 3 or dsi games...computer is...
Check your Device Manager and verify that the network adapter is listed and it's driver is installed. If not, you will need to download the driver from another computer (connected to the Internet) to a USB flash drive and transfer it to this computer because you cannot get the Internet without the Network Adapters' driver. Go to the manufacturers website, search for your particular model of computer, select the drivers download section, and locate the network (LAN) driver. The shop who repaired your computer should of done this for you.
Oct 28, 2010 | Computers & Internet
I have a 2001 infiniti i30 and my car will start but than shut down unless i press the gas for a couple of secs
If you need to give it gas to keep it idling, it is probably the idle air control valve that is shot. It fails by leaking antifreeze into the solenoid of the valve and shorting it out. (quite common with the i30) Unfortunately, when it shorts out, it also shorts an integrated circuit in the engine computer. I ordered the IC and had the engine computer repaired by a tv repair man. I had to order 10 IC's off the internet. If you are looking for an IC, email me. csyoung@vianet.ca
Mar 04, 2010 | 1993 Honda Accord
Cant connect to internet verizon says network
Have you installed tnhe drivers for your Network Adapter? Without the drivers the adapter is, as far as the computer knows, not there. Did you get a disk with your computer and/or adapter? If so install the drivers and problem should be solved.
Dec 20, 2009 | Dell Ethernet Card Network Adapter
Drivers 4 Linksys BEFW11S4 ver. 4
Your wired network adapter will talk to a wired router without a driver for the router on your computer. Your wireless adapter likewise will talk to your wireless router without a driver for the wireless router on your computer. Your wired and wireless adapters however do require drivers and the wireless adapter can require configuration. Please provide the manufacturer and model of your computer so I can learn about your wireless adapter and we can work to get it connected to the router.
Do you currently have your router connected to your internet service providers connection and do you have another wired or wireless computer successfully using this device to access the internet?
Dec 09, 2007 | Linksys BEFW11S4 Wireless-B Broadband...
HP Compaq dc7100 Ultra-slim PC Desktop Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
