Question about Lexmark Wheelwriter 3 Typewriter
Where do you put oil in a wheelwriter 3 - Lexmark Wheelwriter 3 Typewriter
    Champion:
  • 204 Answers
You should let a pro do this...too much oil and in the wrong place, can harm th unit. You can put a couple of drops on the carrier rails. Long silver rods theat the print wheel assembly travels on.
Hope this helps
Posted on Mar 28, 2011
Ibm wheelwriter typewriter will not return all of the way
HI:
Take a rag with some light oil like 3 in 1 oil or WD 40 and clean off the metal rod that the carrier moves across. Then apply some more around the entire rod with your fingers. The carrier should move much better after that.
Andrew
Jun 13, 2012 | IBM Personal Wheelwriter By Lexmark
IBM Wheelwriter 3 squeaks.
The squeaking is caused by lack of lubrication on the Platen (roller) bearings..the feed rolls that grip the platen or the linespace mechanism. Have to be careful on too much oil..I just put a drop on a corner of a piece of paper and touch what you want to oil..it will **** the oil right off the paper. a light oil like gun or sewing machine oil.
Hope this helps
Squipps
Oct 06, 2009 | Lexmark Wheelwriter 3 Typewriter
IBM Wheelwriter 3 spacing
The first thing to do is to put some WD40 on the silver shaft that the carrier slides on, if that dosen't do it either the gear on the carrier motor is cracked or the keyboard is bad. With the machine off slide the carrier back and forth if you get a tight spot every few inches the carrier motor gear is cracked.
DickyO
Aug 24, 2009 | IBM Wheelwriter 30 Typewriter
Carriage will not return
the silver shaft that the carrier moves back & fourth on is gummy take a rag & put some light wait oil on it wipe the silver shaft down. With the power off move the carrier back and fouth. spray or put on more oil on shaft wipe down any extra oil.
Jan 22, 2009 | Lexmark Wheelwriter 15 Series II...
IBM Wheelwriter 3500
First look inside the typewriter for forgien objects and debris, Then put some libhe oil (WD40 works well) on the shaft that the print head slides on.
DickyO
Oct 09, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 6 ribbon not advancing
Befor you put a nrw motor in try a few drops of light oil on the m
motor bearings (WD40 works well).
DickyO
Mar 24, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 3 printwheel
If you know where the print solenoid is try a few drops of oil on the front and rear of the plunger. If the pad needs replaced it can be done without removing the printer from the machine but it is tough. If you know how to remove the printer take it out, remove the printwheel, there are two screws that hold the solenoid once the dolenoid is out the installation is simple.
DickyO
Mar 23, 2008 | IBM Wheelwriter 30 Typewriter
IBM wheelwriter 6 Series II
try turning the machine off put a SMALL amount of oil on the large round rod running across the typewriter manually push the print head left and right a few times to see if it will loosen up. The problem is usually caused be drying oil you may consider having it serviced by a pro.
Oct 31, 2007 | Lexmark Wheelwriter 6 Series II Typewriter
Typewriter won't return carriage
try wiping the large bar that runs left to right under the carrier with a cloth wet with a light oil and then move the carrier by hand to see if it will free up. Be sure the typewriter is turned off.
Oct 01, 2007 | IBM Wheelwriter 30 Typewriter
Need a user manual
Oil rails not with WD. Machine oil.
I have instruction books $ 10.00 828-687-3929
Sep 28, 2007 | Lexmark Wheelwriter 3 Typewriter
Lexmark Wheelwriter 3 Typewriter Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
