Question about PfaFF Sewing Machines
How do I correctly replace the hook and race on my Pfaff 207 sewing machine? Thanks!
SOURCE: changing Pfaff 1222 sewing machine belt
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Posted on Aug 27, 2008
  • 980 Answers
SOURCE: Manual for a PFAFF 1222 sewing
Try www.sewingonline.co.uk/instructions or www.sewing-machine-manuals.com and click on relics, don't be put off by the word relics
Posted on Nov 03, 2009
  • 980 Answers
SOURCE: Replaced the hook gear in a singer 720 sewing
email me drivewithken@blueyonder.co.uk and I will attach timing instructions
Ken
Posted on Nov 25, 2009
SOURCE: Bernina Virtuosa 153 Quilter's Edition sewing machine jams
Bernina Virtuosa 150 pressure foot does not go down quite all the way. The stitches don't go straight and are not even. PrewettOE
Posted on Dec 13, 2009
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
I have a Pfaff Quilt Expressions 2046. The bobbin casing is turning and not staying still. I can rotate and get it to snap up at the top but it will not stay in that position. I have cleaned and oiled,...
I suggest that the sewing machine be checked to see if there
is something wrong with the hook & hook race or if the bobbin
casing needs to be replaced
Oct 08, 2012 | Sewing Machines
How do you adjust timing on pfaff 138 sewing machine
Take the foot off the machine
Remove the needle plate
Remove the feed dogs
rotate by hand until the needle is at the lowest position
continue rotating until the needle rises 2 mm
the hook assembly should be passing exactly by the scarf of the needle
if not loosen the two screws that secure the the hook assembly and rotate the hook assembly by hand until it is exactly at the scarf of the needle and the distance between the hook and the scarf is .1 mm (almost touching the needle)
tightened the two screws, replace the feed dogs and foot and it should sew perfectly
Jul 30, 2012 | PfaFF Sewing Machines
Can't reassemble the shuttle/hook in Singer sewing machine - it is Model # 1120 - an inexpensive machine but works great. It jammed and I released the retaining clamps (?) and the other little parts fell...
Turn the hand wheel until the hook race is in the left position..replace the hook to right side...replace the hook race cover..smooth end to the bottom..and snap back the hook retaining arms...now ready for inserting bobbin case...Good Luck
May 29, 2009 | Singer 1120 Mechanical Sewing Machine
RACE AND HOOK NOT ASSEMBLED CORRECTLY IN MACHINE 534FB
Turn the hand wheel until the hook race ON YOUR MACHINE is in the left position ...insert your hook ( semi circular hook) to the right side( jagged edge to the bottom)...insert the hook race cover ( circular, with the two jagged points facing inwards and in 12 o'clock position) and snap back the two hook retaining arms. Ready for inserting bobbin case. Good Luck
Apr 30, 2009 | Singer 8280 Mechanical Sewing Machine
Pfaff tiptroni6122, the thread loops up on the bottom of material
Sounds like the hook timing is off. You don't need a new hook but you may need a new position finger. If you are unfamiliar with working on sewing machines then it needs to go to the shop. This is a great machine and is worth keeping up. Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Feb 04, 2009 | PfaFF Hobby 4260
Sewing design thread breackage
Assuming that the timing, needle clearance, position finger and needle plate position are all properly set you can try the following:
1. Oil the hook (use Pfaff hook oil, it is a lighter weight than the normal white oil used on sewing machines).
2. Check the hook tip and flank for damage, buff out if possible.
3. Check the needle plate for damage and buff out.
4. Replace the needle.
This is a great machine and is worth keeping up, Pfaff doesn't make the all metal hook anymore which is a shame.
good luck!
Feb 01, 2009 | PfaFF Creative 7570
Shuttle alignment and assembly
The shuttle/race/bobbin system shouldn't really be taken apart by the average user. Unfortunately, your chances of ever getting it back together properly so the machine will sew (this is the timing of the machine) are very slim. You'll need to take it to a sewing machine technician. I would recommend an authorized Pfaff tech as they'll be sure to have the proper tools to do this correctly - won't be inexpensive but will be worth it. Most "neighborhood sewing machine repair folks" don't have experience on computer machines. Resetting timing on a computer machine isn't the same as the old mechanicals and requires some expertise.
May 02, 2008 | PfaFF Creative 7570
Where does the oil go?
To oil machine.....Remove the bobbin case.Snap the two retaining arms outwards.Remove the hook race cover (circular ring ) and the hook ( half semi circular) and clean with a soft cloth.Lubricate right hand side wall ( 1-2 drops of oil) turn hand wheel a few times until the hook race is in the left position...replace hook..replace hook race cover ( smooth end to the bottom) and snap back the two hook retaining arms and insert bobbin case and bobbin.
Jan 06, 2008 | Singer 1116 Mechanical Sewing Machine
Sewing Machines Logo
26 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
