Question about Sony MHC-RG290 Shelf System
Hi i have this problem the hifi works like normal but the fan does not spin
  • bronxz_billy Mar 28, 2011
    i have a panasonic sa ak750 when the volume is low the fan still works but thank you will try this :)
  • 10,594 Answers
Fan will spin on high volume, increase volume and check does fan spin?
If still fan does not spin then it might be stuck or defective and unit will take apart to check fan.
Thanks.
Posted on Mar 27, 2011
  • Shahid Electronics
    Shahid Electronics Mar 28, 2011
    but the fan does not spin << ' >> the fan still works
    I'm confused, either left part of question is true or right part?
    Product model and brand is also different and my first answer was for Sony MHC-RG290 that is mentioned in question headings.
HI, I HAVE A MERCEDES 1994 C180, THE FAN BLOWER SPINS REALLY SLOW, DO I NEED TO REPLACE THE RESISTOR
Resistors have a set value and either work at that value or burn out.. They are just a piece of resistance wire cut to a length for the value. If the motor is spinning slower than normal I would suspect a motor problem probably seizing bushes on the armature.
Apr 05, 2013 | Cars & Trucks
Dell latitude e6400 fan not spinning
Is the laptop running hot? Sometimes the power saving mode in the BIOS will shut off the fan to conserve power when the processor isn't in danger of overheating. Try getting into the BIOS and playing with the fan and power saving settings to verify that the fan actually works as installed in your system. Otherwise, if you know that the fan works and you have it plugged into the system board correctly, there must be an electrical malfunction internally on the laptop and there is no way to troubleshoot further unless you know a lot about circuitry.
Jan 08, 2013 | Dell Computers & Internet
Audio output to hi fi from d530 sff
Yes there is. You can use the same connector you use for headphones / speakers. You need a cable - type depends on your HiFi inputs could you specify what HiFi you have?
Although Jack-2xCinch (Male-Male) should work on standard HiFi towers.
Dec 31, 2011 | HP Computers & Internet
Rheem condenser fan don't spin up under it'sown power.
If you have a multimeter that tests "uf" or "mfd" that is microfarads. That will test the capacitor. Turn off power to unit, touch top of cap with insulated screwdriver across terminals to discharge and remove fan and common. MARK WHICH WIRES GO WHERE. Or if no mfds on multimeter, amps×2650÷volts=mfd. Amp draw on fan wire off of cap times 2650 divided by the volts between common and fan on the cap. If cap is good it's likely the motor.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Apr 12, 2017 | Heating & Cooling
How do you connect projector to satellite receiver
Hi
A satellite receiver is no different to connect when it comes projector than a vcr, dvd player etc.
There will be Video out RCA plug normally yellow in color. There there are two chords for Audio. Normally Red for the right channel and white for the left. Both RCA. If your receiver is mono, you will have only one audio.
There are corresponding jacks in the projector. There might be a video out and audio out in the projector. You can ignore those.
If you use a amplifier, The connections will go from receiver to amp and from amp to projector. It is a good idea to have an amp in between. You don't have to send the audio to the projector (which normally is not great sound quality). Just use the home hifi for it.
So summary of ideal connection :
-Video out receiver in yellow RCA to video in projector.
- One or two Audio out (Red+White RCA) from receiver to your Hifi Audio in
Listen to Hifi and watch thru projector.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 24, 2010 | Epson PowerLite 3LCD Projector
Cooling Fan Spinning Fast On A Cold Start
most fans are clutch fans and they work or are engaged by temp.most all will spin under really cold conditions.this is normal.but to be sure, with the motor off and key in your pocket grab the fan and see if it wiggles or has any slop. if not alls good
Dec 20, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
ASUS Lap top computer, 2 months old' makes loud fan type noises at each start up.
Hi
Its normal for a laptop computer or a desktop computer to spin its fans at maximum speed during start up - its part of the power on self test.
If the fan is very loud like on this video the sound is very bad -
that would be a bad fan, constant bad noise. but if your fan only makes noise in start up, its normal.
your warranty should cover the replacement of the fan if its bad.
Oct 02, 2009 | ASUS Z71V Notebook Computer - 15.4"...
FAN BLOWER VERY LOUD ON HIGH
HI!!! open the fan conpartment pull the fan out and see how it works maybe wobless when spin the bearing from the fan worn out o something is inside the.fan compartment?????
Feb 26, 2009 | 2000 Toyota Camry
Sony hifi wont play cd's
Optical lens requires cleaning.
Please put cd cleaner in tray and check if it cleans dirt on lens. Still same problem, then unplug unit from AC outlet, take off top cover of hifi system and clean lens with good quality cotton bud. hope this will resolve problem.
Jan 26, 2009 | Audio Players & Recorders
Panasonic VCR pv-7451: No sound in "normal" mode
Are these prerecorded tapes or ones that you recently recorded? Or are they all normal audio tapes?? Try a pre recored and turn off the HI fi audio and thats an easy thing to do as put it in normal and mono.. Get back to us so we can assit. Not enough info as could be 100 things.
Jun 28, 2006 | Panasonic PV-7451 VHS VCR
Sony MHC-RG290 Shelf System Logo
90 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
