Question about GE Microwave Ovens
I have a GE spacemaker xl JVM1631 and it started to make a loud noise and gave off a burning smell. After reading some reviews online, I called GE warranty dept. They sent me a new magnetron. I replaced it but it's still doing the same thing. What else could be the problem? I also heard that I need to replace the diode..? Any help would be appreciated.
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile XL Spacemaker microwave oven
I would first advise you to check the waveguide cover. This is probbaly a large one, covering the ceiling of the microwave.
If there is grease or food debris on it or above it, using the microwave can cause it to arc and smoke.
Otherwise, it may be a problem with the high voltage transformer or magnetron. It would have to be checked.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Oct 12, 2007
SOURCE: GE Spacemaker XL 1800 Microwave It has a louder than normal humming noise and it isn't cooking anything.
On a GE...with a louder than normal hum and not heating...most likely the mag, but could also be a shorted H.V. diode. Most of the time on those it's the mag, but you better have the diode replaced also even if it seems ok. Most GE's have 10yr warranty on the mag. If you don't know what you're doing leave servicing the high voltage circuit to the pros. Wouldn't want you to have a "shocking experience" or take the risk of exposing yourself/family to any radiation leaks.
Posted on Dec 10, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Buzzing noise and burned magnetron antenna
Seems you've posted on this several times, and I've answered them all, but I'll cover this one, too.
GE had a campaign (but not a recall, mind you!) covering several models.
Details are in their bulletin at http://207.234.249.73/mwd/ge_mw_mag_kit_bulletin.pdf
Even if your model is not on the list, the same problem can occur, requiring a kit. I just think the difference is that GE has stopped paying for the repairs.
The parts kit (that GE used to pay for) is part # WB27X10489 and is shown in the photo below.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 20, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
SOURCE: New GE Magnetron. Where does this new HV diode go?
Fixed it. There was a back capacitor fuse (I believe that's what it's called) on the old magnetron. I removed it and put it on the new magnetron. The HV diode is on the big silver capacitor and very easy to replace. I just didn't see it. It was definitely the magnetron and I hope that this new one comes with a warranty for 5 more years.
Posted on Dec 01, 2008
Buzzing noise and burned smell
Faulty diode pack and possibly magnetron.
Mar 27, 2014 | GE JVM1631 Microwave Oven
Loud noise followed by a burnt smell coming from the control panel. Not heating up at all.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101/./.'';
May 19, 2010 | GE JVM1631 Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
GE Spacemaker XL1800(JVM1850CF001) - Loud Humming noise
You either have a bad magnetron tube (5 or 10 year parts warranty item through GE Factory Service 1-800-432-2737 or www.geappliances.com) or a shorted high voltage rectifier. I think the light being out is a secondary problem.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1800 first no inside light followed by loud noise
I agree that the light is unrelated. 99.9% chance you have a bad magnetron tube but it is covered by either a 5 or 10 year parts warranty through GE. Call GE Factory Service at 1-800-432-2737 or schedule online at www.geappliances.com
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
My GE spacemaker microwave won't heat and makes an unusual sound
I have the same problem on my oven- model JVM1640WB and called an appliance repairman who is honest and reliable (I've used him before). He said the problem is with the electrode, to fix it is roughly $300. He recommended buying a new microwave rather than fixing it.
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400
IF THE UNIT IS STILL UNDER THE 90 DAYS BRING IT BACK TO
WHERE YOU GOT IT BEFORE IT STARTS A FIRE!!
Jan 07, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
32 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
