Question about Samsung HLR5067WX 50" Rear Projection HDTV
TV shuts off itself randomly. It's 5 years old, never replace lamp. It's probably dusty also. What would a repairman charge?
  • 56 Answers
Hello, doesnt sound like much of a problem. Probably a dry joint in the powersupply board. As the tv heats up it cause the components to break contact with the PCB. Its just a matter of resoldering it. Cost? Around $100-$200 should see it out,depending on who you get. I hope I have been of service.
Posted on Mar 28, 2011
What is the solution to the blinking green light and welcome screen then tv shuts itself off
I recently had this problem on my model as well, though it was lessthan a year old. The method that worked for me is to update thefirmware of the TV itself; you can download the new software, with complete instructions on how to update your TV at http://support.mitsubishi-tv.com/documents/WD-60C9
After doing this, my set started working again.
Do not replace your lamp. the light will blink red for a bad lamp, not green.
Jun 18, 2011 | Mitsubishi WD-60C9 60" DLP HDTV
Tv is turning itself off randomly, Cleaned dust from inside and this seemed to fix temporarilly. Now the problem is back and happens more. I believe it is over heating. The lamp has never been changed and...
Hi:
If its been over two or three years since you replaced the lamp it time to do so now, these lamps are only good for about 6500 hours of use, thats a little under 3 years. Also they are on a timer, so the first step is to change the lamp.
May 15, 2011 | Samsung Televison & Video
Samsung hls5086wx/xaa turns off at random
Go to website Encompass Electronics.com type in your model number it will list part and part number ,you can also look for Lamp on E-Bay Encompass 1-800-638-3328 Also ck Color Wheel remove lamp take a flash light to watch when you turn TV on see if the color wheel is turning if it is defective set will shut OFF. But most likely its your Lamp.
Oct 05, 2009 | Televison & Video
I have a Samsung DLP 50" TV (HL-R4667W) that has been nothing but trouble. The bulb has to be replaced about every 6 mos or the set turns itself off. I believe there is some other problem other that the...
If the color wheel is the problem you can generally hear a high pitch whine coming from the TV. If it is seized the lamp will ignite for a few seconds and then shut off.
The ballast is only used to ignite the lamp, it shouldn't cause the TV to turn off once it is on.
Since the TV shuts off after it is on I recommend the following:
1st - The lamp cover has a safety switch. if the lamp cover is not pressing on the switch, the TV will turn off after random periods of time.
2nd - The other thing to check is the fan for the Lamp. If the fan is seized or spinning slowly, the lamp will heat up and trip the thermal protection switch. Once that happens the lamp is super hot and could rupture while cooling down.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
Intermittent shut off
20 years is too long and the components ternmial might be loose or crack at this time, I'll susgest you look for any dry cold solder on the main board and do resoldering to the components terminal.
Nov 30, 2008 | Fisher PC-25R20 25" TV
Sony Wega 50
Usually this is a classic lamp problem, but it could also relate to a defective lamp ballast (power supply).
Now if you are replacing lamps frequently, it's likely the lamp isn't getting enough airflow to keep it cool. If you don't get the airflow issue solved it will take out the thermal safety fuse near the lamp and your set won't come on and the power light will blink red 6 times repeating itself until you unplug it. Some lamp fans are so deeply nested it takes a trained tech to get them out. Dusty environments are bad for TV's with fans in them, especially projection types.
Nov 09, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
50vx500
The lamps can do many odd things when they are on the way out includung the picture coming on and then dissapearing for a while then coming back. The lamps adverage life is 2000 hours, and at 3-5 years it is on borrowed time.
May 13, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Power shutting off and coming back on
The problem is your bulb is going out or malfunctioning. I had this same problem and Sony's repair service couldn't fix it. I posted on another forum and found a great tv repairman that told me that when the lamp is going out or bad that it can cause the tv to do strange things. I replaced the bulb and the problem is gone. Here's a tip, you can replace just the bulb for about half the price of the full lamp assembly. Sony wants $250 but I bought just the bulb for $125 on ebay, spent 20 minutes taking apart the housing to replace the bulb. Just make sure you take note of how the spring is installed before you take the first part off. Other than that, piece of cake.
Apr 15, 2007 | Sony KDS-R50XBR1 50" HDTV
Samsung HLR5067WX 50" Rear Projection HDTV Logo
366 people viewed this question
Jerry Greenberg
Jerry Greenberg
