Question about AEG Lavamat 12710 Front Load Washer / Dryer
I have a AEG L12720 washer/dryer combination, Now the dryer part isn't working good anymore. The pump pumps the water out, the wash is hot, and the the machine tumbles around. But after 125minutes the wash is not dry. What can be happend? I know that the machine was to full last week and overheated with code E2.
SOURCE: AEG LAVA COMBO 1000
check your timer maybe the motors inside is defective, or your wiring is cut by the rats, or your timer itself is defective, the contact is not working properly.
Posted on Apr 14, 2008
mediarich
  • 188 Answers
SOURCE: Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid. plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
Posted on Oct 03, 2008
SOURCE: my aeg washer dryer comes up with e20 flashing
I had the same problem (E20) for a long time and tried everything in the manual before I called AEG to have someone stop by and fix it.
He took the whole top off as well as the back and pulled out all this fuzz that was stopped somewhere. He said it normally comes from using too much detergant and also from not letting the machine run empty every now and then....but it doesn't say to do this in the manual. And anyway, I can't imagine that using too much wash powder made 1/2 kg of fluff.
I still have a guarantee on the machine, but they say that because it is my fault that I got E20 I have to pay for the repairment myself.
I actually think that they build the machine purposly in this way to keep up the money flow. I have an attorney on the case now.
Posted on Jan 14, 2009
SOURCE: My aeg lavamat 16810 washer dryer won't dry. The
I had the same problem and fixed it by replacing the triple valve. One of the inlets passes water to the condenser and this had failed. You can tell this by opening up the top and when the drier starts you here the drain working and then should hear a gentle hiss as the water is let through. If you don't hear anything then after 10 mins you get the E10 error. It cost me £27 which is cheaper than getting a new machine or a call out charge. If you feel competent then all you need is a philips screwdriver, pliers to get the clips off and a flat head driver to remove the rubber hoses.
Posted on Nov 11, 2009
SOURCE: locating fluff filter on aeg washer/dryer
I have the same problem with mine. There isn't a fluff filter that you can get to easily. When the engineer came to fix something else he showed me this big tube thing inside the machine that had the inside coated with fluff. The machine wasn't very old and I only use the dryer for underwear (apparently towels make it much worse). So ... you'll have to get someone to dismantle the machine to get to the fluff. I was wondering if it is covered by the guarantee because it is ruining my washing.
Posted on Mar 14, 2010
AEG FAVOURIT 675 no water coming threw plastic tube on top of washer. How can I fix and check this problem.
Replace your water pump ... probably working but impeller is too worn! Good Luck! Handy Henry
Feb 19, 2017 | AEG Washing Machines
REPLACE PUMP
easy
  • How to Replace a Washing Machine Water Pump: 12 Steps www.wikihow.com/Replace-a-Washing-Machine-Water-Pump
    • 4 MIN
    • 76K VIEWS
    2016-01-08 · Video embedded · How to Replace a Washing Machine Water Pump. Washing machines are durable and expensive appliances. Repairing them is often less expensive than replacing ...
  • Washer Not Draining? Washer Drain Pump Replacement (Part ... www.youtube.com/watch?v=DwV71h86Gxw
    • BY REPAIRCLINIC.COM
    • 3 MIN
    • 381K VIEWS
    2010-05-14 · This video provides step-by-step instructions for replacing the drain pump on top loading direct drive Whirlpool washing machines. The most ...
  • Geeks On Home: How to Replace a Washing Machine Drain Pump www.geeksonhome.com/how_6509829_replace-washing-machine-drain-pump... How to Replace a Washing Machine Drain Pump. Washing machines take the drudgery out of laundry day, and they're a lot easier than using a washbasin or beating ...
  • Related searches for Washing Machines replace pump
  • How To Replace The Pump in a Washing Machine - YouTube www.youtube.com/watch?v=cvyCSQMPkCc
    • BY BUYSPARES
    • 5 MIN
    • 74K VIEWS
    2011-07-13 · For all your washing machine spare parts and accessories, visit: http://bit.ly/1VKQiNZ If the pump in your washing machine is faulty or broken, ...
  • How to Replace the Pump on a Washing Machine - Bosch ' ... www.espares.co.uk/.../how-to-replace-the-pump-on-a-washing-machine- View All Washing Machine Pumps Now » How to Replace the Pump on a Washing Machine - Bosch. Is your washing machine failing to drain following a wash cycle?
  • How to Replace the Pump on a Whirlpool Washing Machine www.geeksonhome.com/...replace-pump-whirlpool-washing-machine.html How to Replace the Pump on a Whirlpool Washing Machine. The pump in a washing machine helps remove the water from the washer's tub. Water comes in through the ...
  • How to replace a washing machine pump on Aeg, Electrolux ... www.youtube.com/watch?v=yrY9R_T8qrY
    • BY HOW-2-REPAIR.COM
    • 10 MIN
    • 17K VIEWS
    2014-03-26 · How to replace a washing machine pump on Aeg, Electrolux, John Lewis, Zanussi washer dryers Please remember to mark us to your ...
  • How to change and replace a washing machine pump on ... www.how-to-repair.com > Home > Washing machines > Pumps After checking that the pump is faulty in our previous tutorials you will need to replace the old washing machine pump with a new one. Disconnect the appliance from ...
  • Whirlpool Washing Machine Pump Parts from RepairClinic.com www.repairclinic.com/.../a11b5c36/Whirlpool-Washing-Machine-Pump-Parts Shop for your Whirlpool Washing Machine Pump from our huge inventory. Return any part for any reason.
  • How to Replace Beko Washing Machine Pump www.how-to-repair.com > Home > Washing machines > Pumps This video will show you how to replace Beko washing machine pump, If your Beko washing machine is not emptying or draining the water then it is a good chance
  • Mar 10, 2016 | Washing Machines
    Why AEG Lavamat 88840 Front Load Washer doesn't spin?
    either the pump is blocked so cant pump water out so stops program.or brushes in motor worn down(both cheap fixes)
    May 22, 2015 | AEG Lavamat 88840 Front Load Washer
    E1O DISPLAYED
    The other E10 fault is a clogged drain pump. Instructions to clean and free this are in the user manual obtained here. http://www.aeg.co.uk/Support/Manuals/
    Peter Kay
    Mar 08, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
    Machine starts but timer unit is not fuctioning
    See if you can remove the timer motor and test it. If it doesn't work, check Repairclinic.com for a motor or a new timer.
    Good problem description, most folks don't give us good clues.
    Nov 27, 2013 | AEG Lavamat 16810 Front Load Washer/Dryer
    My AEG lavamat turbo 16810 update, makes a rumbling noise when the pump runs. The filter is clear so I presume I need to remove a foreign body from pump. My question is how do I get to it. can you give...
    I'm not sure if this model has an access panel with 2 screws at the bottom, but if not, An easy way to access is by tilting the washer against the wall and removing the bottom panel, Should be 4 screws. from there you can remove the hose and retrieve the debris from the pump most likely change. have a fairly good size bowl and towels close by to catch the water. make sure the washer is disconnected from it's power source. Hope this helps.
    May 02, 2011 | AEG Lavamat 16810 Front Load Washer/Dryer
    Alarm on aeg lavamat washing machine is E20. What is this?
    saup box prop,, clean vith hot water in 2 min have fromt pump open and fluss aut
    Dec 13, 2009 | AEG Lavamat 72640 Front Load Washer
    AEG LAVAMAT 12700 VI turbo washing machine doesn't drain
    Hi, You have taken out the strainer of the washer front and cleaned it regularly haven't you?? If that's clear, it's probably just the waste line blocked. Try removing the waste pipe where it joins under the sink, put it in a bucket and see if the washer drains. It's probably full of sh"te. If that doesn't work, then I'm probably full of sh"te and you might need a new pump.
    Feb 10, 2009 | AEG L12700ViT Front Load Washer / Dryer
    AEG Lavamat 12710 Front Load Washer / Dryer Logo
    69 people viewed this question
    Top AEG Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Einar Axel...
    Einar Axel...
    Level 1 Expert
    Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
