SOURCE: need a manual for Pasquini Livia 90
Hi I have one that I wrote if you want it. Send me your e-mail and I'll sent to you.
SOURCE: descaling the livia 90
The proper and only way to descale the boiler should only be done by a trained technician. As far removing the water tank goes, you simply lift it up from the left and right hand sides - this may be difficult if you have never removed it since calcium may have built up on the seal at the bottom of the reservoir - simply wiggle it side to side to remove. To clean the reservoir, you can use a green scour pad with water. If it is heavy build up you can use a product called CLR, and let sit overnight. You can save the CLR and reuse. Rinse well to remove all clr.
My experience is working over 10 years at Pasquini as a master technician running the home repair sales and service center.
I stock all Pasquini parts for any service of your Pasquini espresso machines and grinders. Contact us for any of your Pasquini sales and service needs.
