Question about Gateway MX6025 Notebook Computer (PCMX6025) PC Notebook
No icons or start menu
I have rebooted my pc and used last good configuration, but still nothing, I don't have a recovery disc or a boot disc, just a motherboard disc with pcillin. I have tried to restart it with phoenix and put in a later date & restart but then it gets worse. please help. is there a way to get into the dos menu to do some fixes & recover some stuff from this pc before it totally crashes? had similar problem when i first got this pc & the company said to send it back & i lost everything on it. they just reinstalled windows xp.
    Genius:
  • 2,028 Answers
I'm afraid there is nothing that can be done from the bios. You will need an operating system disc. For the files you want to back up, you can purchase an IDE to USB hard drive cable for around $20. This will allow you to remove your hard drive and connect it, with the cable, to any computer as a slave drive or mass storage device, basically an external hard drive. You can then burn any data that you want to save to a disc from the drive. Of course, you will need access to another computer. If you need anything else feel free to ask.
Posted on Aug 05, 2008
Restore my emachines w3507 back to factory settings how do i do it
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Dec 28, 2012 | eMachines W3507 PC Desktop
Tip
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy...
Windows 7 Startup Problems - How to Fix Windows 7 Startup Problems With Easy Tips
If you fail to boot the operating system, you can:
#1. Use Windows startup Disk to fix Windows 7 startup problem
If the failure of booting is result from the errors or the damaged files of starting system, a start up disk will help to solve this problem with ease.
#2. Use last know Good Configuration to fix Windows 7 startup problem
It is also a common method to enter the operating system. To use last know Good Configuration you can press F8 when you reboot the system. Then select "Last know Good Configuration" on the Advanced Boot Options screen to enter this mode.
#3. Use System Restore option in safe mode to fix Windows 7 startup problem
Enter the safe mode as the step in to last know Good Configuration in method #2. Choose System Restore option in System Tool in start menu.
If you find the startup process of Windows 7 very slow, we suggest that you should:
#1. Remove redundant programs in your booting items as many as possible. After finishing this action, the speed of startup can be improved by no less than 40%.
#2. Delete short cuts on desktop. The more icons on the desktop, the longer it takes to restart Windows 7. To fix Windows 7 startup problem, you should clear up the unnecessary short cuts on your computer desktop.
#3. Optimize registry regularly with proper registry maintenance tool. Registry error is the main reason that slows down the rebooting speed. You had better do registry cleanup timely to speed up Windows 7 start up process.
on Jan 12, 2010 | Computers & Internet
Hp site
Use Recovery Console
When a Windows XP boot problem is severe, you'll need to usea more drastic approach. The Windows XP CD is bootable and will provide youwith access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROMdrive on the problem system and press [Ctrl][Alt][Delete] to reboot thecomputer. Once the system begins booting from the CD, simply follow the promptsthat will allow the loading of the basic files needed to run Setup. When yousee the Welcome To Setup screen, press R to start the Recovery Console.
You'll then see a Recovery Console menu. It displays the foldercontaining the operating system's files and prompts you to choose the operatingsystem you want to log on to. Just press the menu number on the keyboard, andyou'll be prompted to enter the Administrator's password. You'll then findyourself at the main Recovery Console prompt.
Use system utility software like RegInOut after restarting windows.
OR
Use Last known Good Configuration:
To use the Last Known Good Configuration feature, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Select the Last Known Good Configuration item from the menu and press [Enter].
Keep in mind that you get only one shot with the Last KnownGood Configuration feature. In other words, if it fails to revive your WindowsXP on the first attempt, the backup copy is also corrupt.
Jan 01, 2012 | HP Computers & Internet
How do you fix the blue screen of death on a dell computer
Check if you can still go to the boot options once you start your PC.
How to go to boot options:
1. Restart computer
2. once computer is turning on, keep tapping F8 key
3. Boot options menu should now appear
4. use keyboard arrow to choose safe mode with networking or last good known configuration
If you are able to go to safe mode, it means that you might have installed a program or software that messed up your PC. uninstall the program then reboot and check if it will boot up normally
If safe mode did not work, use last good known configuration, this will attempt to load your computer on the last time it worked (previous days)
If the above solutions did not work, you can use the windows recovery cd that came with your computer. Here you can repair your computer using the fix and repair option
If all else fails, the only way to fix it would be to reformat the PC
Hope this helps
Jul 28, 2011 | Computers & Internet
I need to press a key on my keyboard to start factory recovery
Hi and welcome to Fixya!
In order to revert the machine back to its factory setting, you need to have the recovery disk (if you don't have it, call the warranty support line of e-machines so they can provide it to you).
To restore Windows from your recovery discs, you will need to
insert the first backup disc and enable the F12 Boot Menu via the BIOS Setup
Utility.
1 Turn on your computer and insert the first system recovery disc into the
optical disc drive. Restart your computer.
2 During startup when the eMachines logo shows, press the F2 key to enter
BIOS Setup, where you can set system parameters.
3 Use the left and right arrow keys to select the Main submenu.
4 Use the up and down arrow keys to select F12 Boot Menu.
5 Use the F5 or F6 key to change F12 Boot Menu to Enabled.
6 Press the ESC key to enter the Exit submenu, press the ENTER key to Exit
Saving Changes. Press the ENTER key again to select Yes. The system will
reboot.
7 After rebooting, when the eMachines logo shows, press the F12 key to
open the Boot Menu. Here you can select which device to boot from.
8 Use the arrow keys to select the IDE1*, then press the ENTER key. Windows
will be installed from the recovery disc.
9 Insert the second recovery disc when prompted, then follow the onscreen
prompts to complete the restore.
10 Remove the recovery disc from the optical drive once the restore is
complete. Do this before rebooting your computer.
Hope this helps!
Takasashi
Jul 25, 2011 | eMachines E620-5885 Notebook
I have a acer aspire x1700 that will not boot gives me a message that says windows failed to start status 0xc0000034. it will not run a disk
You can try two things:
1. Boot up and Immediately begin tapping the F8 key. When the Option menu comes up select "Last known good configuration"
2. Sounds like you need to reboot using your windows recovery disc.
If it will not boot up using the disc, try again but press F12 while booting (Sometimes F2 or Del) to get into the Bios settings. Here you can tell the computer to boot up from a disc.
When booted, select Repair your Computer.
Apr 01, 2011 | Acer Computers & Internet
How can i fix my lenovo t60 ibm thinkpad. I just press the restart...but the message on the monitor said that the registry cannot load the hive...systemroot/system32/config/software...and its beggining to...
This problem usually requires the Operating System CD, but here are a few things you can try before having to have the OS CD:
Try loading the Last Known Good Configuration (your most recent settings that worked) by following these instructions:
  1. To load the last known good configuration in Windows, reboot the computer.
  2. Before the Windows Loading screen appears, press and hold your "F8 Key", this should bring up the "Windows Advanced Options Menu" as shown below.
  3. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
  4. As can be seen from the example below, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Still unsuccessful? You will need the OS CD, unless you have the Recovery Console already installed and available using the Operating System Selection screen:
  1. Start your computer by running the Recovery Console.
  2. Run the chkdsk /p command on the drive, and then restart your computer.
If you are still unsuccessful, you will need to run an OS Repair using the Operating System CD, here are the steps:
Windows XP
  1. Boot the computer using the XP CD. You may need to change the boot order in the system BIOS so the CD boots before the hard drive. Check your system documentation for steps to access the BIOS and change the boot order.
  2. When you see the "Welcome To Setup" screen, you will see the options below:d3573cb.gif
  3. Press ENTER to start the Windows Setup.
  4. Accept the License Agreement and Windows will search for existing Windows installations.
  5. Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, END setup.
  6. Setup will copy the necessary files to the hard drive and reboot. Do not press any key to boot from CD when the message appears. Setup will continue as if it were doing a clean install, but your applications and settings will remain intact.
Windows Vista
If you have a Windows Vista installation disc, you need to restart (boot) your computer using the installation disc. If you do not restart your computer from the disc, the option to repair your computer will not appear.
Here is a step by step picture guide.
If you have a Windows Vista installation disc:
  1. Insert the installation disc.
  2. Restart your computer.
    Click the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, click the arrow next to the Lock button eb058ccf-b21e-4dfe-9bb7-1ad6c83b705c.png, and then click Restart.
  3. If prompted, press any key to start Windows from the installation disc.
Windows 7
  1. If a startup problem is detected, Startup Repair will start automatically and try to fix the problem.
  2. If the problem is severe enough that Startup Repair doesn't start on its own and you can't access the System Recovery Options menu on your computer's hard disk, you can get to the menu and start Startup Repair by using the Windows installation disc or a system repair disc that you created earlier.
Jul 13, 2010 | IBM Lenovo ThinkPad T60p Notebook
Will not re-boot
Hello #1: Use a Windows startup diskOne of the first things you should reach for when troubleshooting a Windows XP boot problem is a Windows startup disk. This floppy disk can come in handy if the problem is being caused when either the startup record for the active partition or the files that the operating system uses to start Windows have become corrupted.
To create a Windows startup disk, insert a floppy disk into the drive of a similarly configured, working Windows XP system, launch My Computer, right-click the floppy disk icon, and select the Format command from the context menu. When you see the Format dialog box, leave all the default settings as they are and click the Start button. Once the format operation is complete, close the Format dialog box to return to My Computer, double-click the drive C icon to access the root directory, and copy the following three files to the floppy disk:
  • Boot.ini
  • NTLDR
  • Ntdetect.com
After you create the Windows startup disk, insert it into the floppy drive on the afflicted system and press [Ctrl][Alt][Delete] to reboot the computer. When you boot from the Windows startup disk, the computer will bypass the active partition and boot files on the hard disk and attempt to start Windows XP normally.
#2: Use Last Known Good ConfigurationYou can also try to boot the operating system with the Last Known Good Configuration feature. This feature will allow you to undo any changes that caused problems in the CurrentControlSet registry key, which defines hardware and driver settings. The Last Known Good Configuration feature replaces the contents of the CurrentControlSet registry key with a backup copy that was last used to successfully start up the operating system.
Keep in mind that you get only one shot with the Last Known Good Configuration feature. In other words, if it fails to revive your Windows XP on the first attempt, the backup copy is also corrupt.
#3: Use System RestoreAnother tool that might be helpful when Windows XP won't boot is System Restore. System Restore runs in the background as a service and continually monitors system-critical components for changes. When it detects an impending change, System Restore immediately makes backup copies, called restore points, of these critical components before the change occurs. In addition, System Restore is configured by default to create restore points every 24 hours.
To use System Restore, first restart the computer by pressing [Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the single beep, press [F8] to display the Windows Advanced Options menu. Now, select the Safe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Start button, access the All Programs | Accessories | System Tools menu, and select System Restore. Because you're running in Safe mode, the only option on the opening screen of the System Restore wizard is Restore My Computer To An Earlier Time, and it's selected by default, so just click Next. Then, follow along with the wizard to select a restore point and begin the restoration procedure.
#4: Use Recovery ConsoleWhen a Windows XP boot problem is severe, you'll need to use a more drastic approach. The Windows XP CD is bootable and will provide you with access to a tool called Recovery Console.
To boot from the Windows XP CD, insert it into the CD-ROM drive on the problem system and press [Ctrl][Alt][Delete] to reboot the computer. Once the system begins booting from the CD, simply follow the prompts that will allow the loading of the basic files needed to run Setup. When you see the Welcome To Setup screen, shown inFigure A, press R to start the Recovery Console.
Please let me know if you have any further questions or concerns.
Thanks.
Apr 30, 2010 | HP Pavilion dv1000 Notebook
How to reboot acer extensa 5630 laptop
Put recovery disc in and while system is starting press F12 key repeatedly until boot menu appears then select boot from CD
Sep 17, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Can't get the system to boot in any configuration
Hi there.
The system files have become corrupt so it won't start properly, the only option left for you to do is recover the system.
If you didn't get any recovery disks with the laptop then you must use the recovery partition.
As the computer starts you can try ALT+F10 or CTRL+F10 during the initial boot cycle - this will prompt the laptop to access the recovery partition on the hard drive.
Good luck
Jun 01, 2009 | Acer Aspire 5920-6335 Laptop
Gateway MX6025 Notebook Computer (PCMX6025) PC Notebook Logo
81 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
