Question about Orion Car Audio & Video
Buzzing when truck is running - Orion Car Audio & Video
  • 3 Answers
Check to see if the power wire is ran next to the rca cables or speaker wires. Or try a noise reducer you can find one at wal-mart or radio shack fairly cheap and in most cases reliable.
Posted on Mar 27, 2011
Buzzing sound coming from under the back end
Under the left side of your back seat is a fuse / relay box . When you first turn the key on the fuel pump relay turns on for a few seconds to prime the fuel system . That relay is in that fuse / relay box ,that is what your hearing . Does the vehicle start an run good , no problems other then the buzzing sound .The vehicle battery is also under the rear seat on the right side . How To Locate and disconnect Battery Buick Lesabre Pontiac Bonneville 00...
Feb 19, 2016 | 2002 Buick LeSabre Custom
Buzzing under hood of truck but disconnect batery and it stops
The buzzing is probably coming from an electric motor that is stuck or a relay that is stuck closed. You are probably going to need an automotive electrician to run down the problem. If it is an electric motor, the motor will get hot to the touch. Does your heater motor work? Does all the electrical system operate properly? Check all your electrical system. To isolate the problem pull one fuse at a time then put it back if the buzzing doesn't stop when the buzzing stops, you have isolated the circuit. Then you can take it to a mechanic and have it fixed.
Apr 11, 2014 | 2003 Volvo S60
Static popping and buzzing sounds come from the speakers when the car is running. The Radio is not turned on and it will continue for a long time, quit then start again as you are driving.
Is it a factory amplified system? Could be the volume knob. Might try unplugging the radio for test purposes and see if it still pops and buzzes to get a better idea of where to go next
Dec 28, 2013 | 2004 Lexus ES 330
Buzz from fuel pump contiously is that in order
some fuel pumps will run like this for years other are short lived
May 31, 2012 | Cars & Trucks
There is a buzzing noise coming from the air con unit
if everything is running may just be contactor,if compressor is running not fan turn it off call service tech out(Fan motor bad)if fan is running but no compressor turn it off call service
Jan 06, 2010 | Mitsubishi Heating & Cooling
Running rough and buzzing at throttle body injectors
Sounds like the engine has a vacuum leak at the throttle body area.
Jul 18, 2009 | 1990 Chevrolet Astro Extended
Buzzing sound in kia
idler pulley
alternator bearing
power steering pump
or a belt
Jul 09, 2009 | 2004 Kia Sorento
Truck dies
Listen For Fuel PUMP key on only not running. it will buzz a few secs, every time you cycle key from off to on .if no buzz Bad fuel pump.I have Duel tanks MY rear pump went out.
Aug 04, 2008 | 1990 Ford F150
Car Audio & Video Logo
44 people viewed this question
Top Orion Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Mark Skinner
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
