Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Remote doe note work - Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
  • 902 Answers
You will need to reprogram your remote are you using the one that came with the tv? or an aftermarket
Posted on Mar 27, 2011
My remote does not work
Remote Code for LCD Coby TV model TFTV2425 - Comcast Help and ...
forums.xfinity.com/t5/XfinityTV.../Remote...LCD-Coby-TV.../916553
Apr 14, 2011 - Remote Code for LCD Coby TV model TFTV2425 ... If your home entertainment device does not respond to the remote control after trying all of the codes listed for your ... I just changed to an hd box andcodes given by comcast did not work. Looked at my old remote notes and that is what I found and it works. Comcast DVR remote won't "select" an input from th...
May 26, 2011
Remote code for coby tvs
Feb 7, 2011
Comcast remote code for Coby tv/dvd
Mar 20, 2010
More results from forums.xfinity.com
Coby tv remote doesn t work Questions & Answers - Fixya
www.fixya.com > Forum > Tags > tv remote doesn t work
Dec 15, 2015 | Coby TFDVD2274 22 in. LCD TV
How to programURC 5600B00 remote to bell receiver
Turn on a device (e.g.,VCR) and, if
applicable, insert media, (e.g.,
cassette or disc).
NOTE: Please read steps 2-4 completely
before proceeding.Highlight or write down
the codes and device you wish to program
before moving on to step 2.
2. On the remote control,press a device
key once (i.e., VCR,DVD, TV,or
CBL/SAT ).Press and hold SET until
the LED blinks twice, then release
SETP.
3. Use the Manufacturer's Codes to
locate the type of device and brand
name and then enter the first fourdigit
code for your component. If
performed correctly, the LED will
blink twice.
NOTE: If the LED did not blink twice, then
repeat steps 2 through 3 and try entering
the same code again.
4. Aim the remote control at the device
and press POWER once.The device
should turn off. If it does not respond,
repeat steps 2-3, trying each code for
your brand until you find one that
works. If it still does not work, try
Searching For Your Code.
NOTE: If the device does not have a
POWER key, press the (Play) key.
5. Repeat steps 1 through 4 for each
device you want to control.
Jun 16, 2012 | Televison & Video
Which universal remote is compatable
you should be able to set up any universal remote to your TV.
as you did not note what television can can't tell you what remote will work best or have more available functions on the remote, but you should be able to get any universal remote to turn on and off the tv, change the channel with the up and down buttons and adjust the volume.
try each code in the universal remotes manual to see which one works best. NOTE: the first code you get to work may not work as well as the next, so if some function does not work you are looking for, try the next code. If you get a universal remote with code search function that is even better as you can using the remote to figure out the best code match.
good luck, and if you have probablems getting your remote to work, post a comment what tv you have and what remote so we can better resolve your issue.
Jul 02, 2011 | Televison & Video
Cannot program dvd player. unit does not fully answer commands from remote.
To program the DVD player's remote control to operate your TV, follow these steps:
  1. Turn on the TV, and then aim the DVD player’s remote control at the TV.
  2. Press and hold the [TV Power] button on the DVD player's remote control.
  3. While holding the [TV Power] button, use the number buttons on the remote to enter the two digit code assigned to your brand of TV.
Note 1: If your DVD player's remote control can be programmed to operate a TV, the TV brand codes will be listed in your owner's manual. If you don't have your owner's manual available, click here to go to the download center and download a copy.
Note 2: Many TV brands have more than one code. If the first code does not work, try the next available code.
  1. If the TV turns off, the code worked correctly and your remote control is now programmed. If the TV stays on, repeat steps 1 through 3 with a different code listed for your brand of TV.
Note: If none of the codes listed allows your DVD player's remote to control your TV, then the remote is not compatible with your specific model.
Let us know if you want something more else please accept the suggestion.
Thank You for contacting Fixya.com
Jun 11, 2010 | Audio Players & Recorders
Remote starter does not work. keyless entry does work. 2008 impala.
I experienced this exact problem and found a note in the manual about fuel pressure problems if the gas cap is not properly inserted. I removed the fuel cap and reinserted it and the remote start worked fine since.
Fred
Feb 20, 2010 | 2008 Chevrolet Impala
Remote does not work
You can get a replacement remote directly through Coby:
What to send:
$6 Money Order 'Made out to Coby Electronics'
Note with your name, address, phone#, model# and what part you need
Send to:
Coby Electronics
Att: Customer Service
56-65 Rust St
Maspeth, NY 11378
Aug 05, 2008 | Coby TF-TV1901 19 in. LCD Television
Big Easy programming
TV Toshiba 0154 0156 0060 1256PROGRAMMING
TV/VCR COMBO CONTROL
Perform the following instructions to
control a TV/VCR Combo:
1. Turn on the TV/VCR Combo and
insert a video cassette.
2. On the remote control,press VCR/DVD.
Press and hold SET until the LED
blinks twice, then release SET.
3. Use the Setup Codes For TV/VCR
Combos (on the back side) to locate
the brand name and then enter the
first four-digit code for your device.
If performed correctly, the LED will
blink twice.
and press POWER once. It should turn
off. If the device does not respond,
POWER key, press the (PLAY) key.
hope that helps
Jun 26, 2008 | One For All URC-3300 Remote Control
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
23 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
