Question about Dryers
One of the paddles in the drum is broken on one end. Is that a screw that holding it or something else. Is it something I can fix by taking the back off?
    Sergeant:
  • 192 Answers
It is usually a rivet, and you might be able to punch it out and replace it.
If not find a hardware store and ask for some JB weld and explain what you are going to use it for. It should hold for a while longer.
Posted on Mar 27, 2011
How to fix when your paddle is stuck on your cuisinart stand up mixer
The shaft of the paddle is bent. After frustrating discussions with Cuisinart customer service, I was able to free my paddle. First, you will notice that the paddle screws onto the shaft. Unscrew it. Then, take the nut off the shaft. Next, put a wrench on the shaft that is only slightly larger than the shaft, followed by a washer. Next, screw the nut back onto the shaft. Finally, holding the wrench at the end, hit the wrench close to the shaft with a hammer. If the shaft doesn't come out, hit harder. Since the shaft is bent, you'll need to purchase a new paddle.
Jul 12, 2014 | Cuisinart Food Mixers
Gltf530dso frigidaire washer
http://www.appliancepartspros.com/frigidaire-vane-131274600-ap2106479.html
This is the part. You have to remove all the panels, The drum counter weights and finally the drum. Then you have to remove the inner drum from the plastic outer drum. Once removed you can get to the screws that hold the paddles in place. Then put it all back together. It may be easier to call a repair man in your area.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
May 23, 2014 | Washing Machines
I HAVE A MAYTAG NEPTUNE GAS DRYER MODEL 3MDE3000AYE. ONE OF THE THREE PADDLES INSIDE THE DRUM CAME OFF. I AM TRYING TO REATTACH IT TO THE DRUM, BUT THE SCREWS HOLDING THE PADDLE ARE INSIDE THE DRUM.
unplug the dryer,open the door,remove the two screws holding the door on and remove the other two screws opposite them,take off the door and pull the front panel off,spin the drum until the baffle you are trying to repair is in the bottom right hand corner and you can get at it like that
Mar 13, 2010 | Dryers
One of the paddles inside the drum has come loose on one end--broken fastener. How do I take the top off to fix it?
you have to start by taking off the door at the hinges, then the front panel will twist off at the smaller raised portion, about 2 inches wide. once you have the front off, you will see the screws that hold the top to the front.
the drum baffles are held in with screws and if you can just use a bigger screw or just tighten the ones that are there.
Mar 13, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
MDE7600AYW Atlantis Dryer -paddle inside dryer is coming loose
You will need to take the back panel off use a 1/4 in socket driver.Then you should see the drum.
Len
Feb 21, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer Paddle Loose
Take the four screws, out of the door and remove it. The front of the dryer will fold down and lift off, you will be able to see in side the dryer. If you want to lift the top remove the screws that are now exposed. Along with the brackets the top will now lift up.
This should allow you to access the tumbler.
Dec 10, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Broken water paddle
be sure to unplug the refrigerator.
remove the drip tray by sliding it forward.. then remove two screws . slide the dispencer cover up two screw hold in the control remove water line two screws hold in water paddle. remove paddle and wire.
to replace water line use a long screw driver to push back into cover. make sure it extends bellow outlet..
hope it helps
Aug 08, 2008 | Frigidaire FRS26R4A Side by Side...
Baffles
These are the paddle bits that are inside the drum? If so I had the same problem and I found that the lugs that hold them to the drum were broken.
I fixed mine by using plastic cable ties (=tie-wraps) passed through the slots in the paddles and through holes in the inner drum. It's fiddly getting the ends back out of the space between the outer and inner drums - I used another tie-wrap bent into a loop and stuffed into a suitable hole to "catch" the end of the tie I was fitting. It's not a pretty solution but it works and it is almost free!
If this "fixes ya", I'd appreciate a rating for my reply, If not, please delay the rating and add a comment with any extra info you have and I will try to think of something else.
Thanks, D
Jul 13, 2008 | EuroTech EWF172 Front Load Washer
Drum Paddle broken Hotpoint Aquarius
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Dryers Logo
48 people viewed this question
Top Dryers Experts
