Question about Reddy Heater- Variable 75,000-125,000 BTU
Need regulator and hose assembly, for Reddy propane heater 76=125 btu
    Brigadier General:
  • 4,736 Answers
Here's a link where you can find what you need. But, you will need to have the Model Number, handy.
http://www.reddyheaters.net/
Don't forget to rate my response. Thanks!
Posted on Mar 28, 2011
What if I don't have my reddy heater regulator assembly?
You need a Regulator to use heater, as it controls the flow of Gas,
Jan 11, 2016 | Reddy Heater RLP100 Portable Forced Air...
Lights while holding primer/pilot button then runs out of propane within seconds. If you wait a minute it builds up then does the same thing like the propane tank is empty but it is full.
Turn off the propane tank and disconnect the heater hose from the tank. Wait 5 minutes and reconnect the heater hose/regulator to the propane t. Turn the tank valve on very, very slowly until it's completely open again. Now, try lighting the heater. If you are using a 20lb LP grill type tank, that should solve your problem.
Hope that helped.
Feb 12, 2011 | Reddy Heater-30-55,000 BTU Variable
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Jan 14, 2010 | Desa International Reddy Heater R40 40,000...
Heater starts and runs but will not go to full force
You can replace the filters ---fuel--- air--- spark plug and vanes in the pump assembly.This is called a fall check up!
Dec 22, 2009 | Reddy Heater-30-55,000 BTU Variable
Heating & Cooling Logo
114 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
