Question about Dryers
Hi, Model: Maytag DE8410 electric dryer The cycle completes and the buzzer sounds, but does it not stop until I pull the door open. I think I also got it to stop by rotating the cycle knob as well. I checked the push button start switch and it does not appear to be stuck. The dryer does not automatically start when I turn the knob and close the door, which also makes me believe the start switch is not stuck. I cleaned out the entire vent. 1) The dryer is NOT plugged in. Is it safe for me to vacuum out all the lint on the inside of the dryer, around the motor, pulleys, et cetera? Any other suggestions are appreciated. Thanks, al
  • Dryers Master
  • 528 Answers
The timer might be bad and the part # for it is 306040
it is safe to clean it when it is not plug in , just be cearful not to move the wire from the place they in.
if it is not big problem dont replace the timer its 100$+ so live it till the unit die ... it is old unit any way...
Posted on Mar 28, 2011
  • robpimentel Mar 29, 2011
    Thanks for the response. I cleaned out the interior. There was quite a bit of lint on the motor itself.
    I've run the dryer 3 times since then and each time the buzzer sounded once, and the cycle ended. It is behaving as expected.
    1) If the timer is failing, could the behaviour be intermittent?
    2) The dryer has been squealing since I replaced the heating element about two years ago. Is this due to the cable(s)?
    Thanks,
    al
  • 911 SERVICE TODAY
    911 SERVICE TODAY Mar 29, 2011
    for #1 yes
    for # 2 no it can be other parts that every 4-5 years need to be replace :belt,felts, wells.. it is regular damage of parts that if you change them your machine will be good for a few more years...
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Maytag dryer problem
most likely you need a new door switch which is located under the top front if you open the door you will see the switch recepticle replace that switch its cheap https://www.google.com/search?q=maytag+dryer+switch&num=100&source=lnms&tbm=isch&sa=X&ved=0ahUKEwju8qXBp9nZAhXLo1kKHVoICLUQ_AUIDCgD&biw=1536&bih=772
Mar 07, 2018 | Dryers
I have a Maytag dryer (Model MDE2600)and the buzzer will not go off unless the door is opened. Buzzer begins when door is closed.
Hi
Buzzer comes on because the control senses that the door is not closed and won't start the cycle. This issue is caused by door switch-latch assembly (part#6 and part#9 in this diagram) that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jan 17, 2011 | Maytag Dryers
Buzzer won't go off when dryer is stopped - All else works fine - must leave door open
Fiddled around with the start button. It had gotten stuck in the on position and when I moved it around it freed up. I consider this a temporary fix only and have already ordered a replacement switch.
Aug 02, 2008 | Maytag Dryers
Clothes Dryer will not stop or be quiet
On some Kenmore which is made by whirlpool, there is a resistor connected to the timer control. when the machine is off can you listen to the timer switch and hear it running, making a clock ticking sound? If so, you need a new resistor. Being a dryer, when you open the door and it stops the button needs to be reset before it starts again, right? So I wouldnt be looking at the door switch as much as the start button. It may be the evil one.
Dec 23, 2007 | Kenmore 63942 Dryer
Dryers Logo
361 people viewed this question
Top Dryers Experts
Marvin
Marvin
