Question about Garmin nuvi 255W GPS Receiver
What do the differant color lines signify - Garmin nuvi 255W GPS Receiver
  • 464 Answers
The different colors used for the roads indicate whether or not it is a major road vs a minor residential road and so on.
Hope this helps!
Posted on Mar 29, 2011
A yellow warning signal has come on my dashboard. It is a straight horizontal line on a slight slope with a short curved line over it and an exclamation mark. Engine will only turn over and not start.
Engine sync. When the chain was replaced, the timing was not set correctly. And are you sure the chain "went"? Highly unlikely. Probably was a different problem to begin with.
Apr 26, 2015 | BMW X5 Series Cars & Trucks
Who decided that black should be the last color for belt grading in martial arts?
Each belt color signifies a level of skill and technique learned throughout training. If each belt color is combined together (yellow, orange, green, purple, blue, brown and red) they would eventually produce black - thus determining why black is the final color level.
Sep 02, 2012 | Adidas Martial Arts
What does the green-colored martial arts belt signify?
At a green belt level, students learn to strengthen and refine their technique. In Japanese culture, this color represents the growth of a seed (the student) as it sprouts from the earth and begins to grow into a plant.
What does the color of the yellow martial arts belt signify?
Both the yellow and orange belts signify the sun. Yellow represents the rising sun and orange the sunset.
My daughter did the experiment of putting food coloring in the tank, then, we waited an hour and the color was in the bowl. Is it true that this would signify a leak in the toilet?
That is a very strong indication that you need to replace the flapper. As there are a lot of different makers and types I would recommend you try to match it up or go with a universal repair flapper. When you are installing the new flapper check the sealing surface to make sure there are no rough spots that could cause a lesk. If there are you can remove all water from the tank and use medium grade sandpaper to smooth it up. I hope this helps you.Thanks.
Feb 17, 2011 | Sterling Home
What is the difference between the red/black wire and the blue/white wire.
    How to Know Wire Colors
  1. Step 1 In most home-wiring applications, the circuit features one black wire, one white wire and a green or non-insulated ground wire. On this type of circuit the black wire is delivering the voltage and the white is acting as the neutral. The circuit has to have each in order to be complete. In some cases a white wire may be used as a hot feed. When this occurs it is commonplace for the white wire to have a strip of black electrical tape around the insulation to signify that it is being used as a hot wire.
  2. Step 2 You may notice a red wire from time to time. The red wire has a couple of responsibilities: It can be a second circuit, sharing the neutral with the circuit fed by the black wire or it can be a traveler, as used in a three-way switch configuration. Additional conductors like the one found in 4-wire electrical wire may be colored blue.
  3. Step 3 While some 240-volt circuits use different colored wires including orange, yellow, brown and gray, they are not typically found in the residential home, so we will go into those applications in another article.
Feb 05, 2010 | Yamaha NS-A60X Main / Stereo Speaker
When I am faxing do I put the paper print side up or down?
Most printers are different even from the same monufacturer. The easiest way to tell is look for the icon near the place where you load the fax. There is what appears to be a sheet of paper with a corner folded over. If the icon shows lines across the main part of the icon, and there are no lines on the part that is folded over, then the paper goes in the machine face up, or lines up. If there are no lines on the main part of the icon but there are lines on the part that is folded over, then it signifies the paper being loaded face down, or lines down.
Sep 12, 2009 | Canon L120 Fax Laser Printer
Icon near battery icon is flashing orange and green. what does this signify?
well that could be any thing, each pc/laptop will have icons in different orders and shapes/colors
if you hover the icon and right click on it it should give you more information.
Apr 16, 2009 | Dell Latitude D620 Laptop (Latitude-C620)...
Computer is on but no display.
Would you be able to try a different monitor? Also when you say no display do you mean nothing at all comes on screen or it does not display windows. Also when you remove the monitor from the computer does it display color bars? signifying that its still working.
Mar 06, 2009 | Computers & Internet
Garmin nuvi 255W GPS Receiver Logo
60 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
