Question about Samsung CLX6220FX COLMON MFC Printer
Paper is jamming and the display says check reverse unit . How do I fix this problem ?
5 Suggested Answers
  • 3 Answers
SOURCE: 202 paper jam error, but no jam present
I cleared that error on one by replacing the fuser. It had a small piece of paper stuck in the roller.
Posted on Jul 02, 2008
SOURCE: Paper Jam 2
We had the same proplem - did you check there was no paper jammed when you opened the back cover?
Posted on Oct 11, 2008
canontech
  • 1219 Answers
SOURCE: Canon IR3530 jamming
Hi, lets go from begining:
1) Remove rollers from lower cass, and put them on first cass. Use fresh paper too. - Does it helps? try abaut 50 copies.If helps replace rollers.
FB6-3405 x1, FC6-6661 X1, FC6-7083 X1
2) when you open right lower door and right door you will be able to see axis with two small rollers.Clean it verry well, use alcohol.
3) On lower right door there must be metal plate for pressure on delivery roller, if there is no plate, put in each corner some tape or filc 2-3mm thick, wich will add pressure on plastic paper cover wich guides paper on delivery roller.
4) Does your jamed paper have any anomalities on itself, like: look like accordian, small wrinkles,...
If yes, check separation plate on fixing unit, pressure of rollers ( between fixing film and press. roller - NIP CHECK ).
5) Beaneath drum you will see small plastic sensor flapper - is he worn out? This is paper registration sensor, if he get in first position before the paper pass him you will get jam code.
Note:
Try to flip paper in cassete, up side down, and try then. If then works, the problem is in moisture on paper.
Hope that helped
Posted on Jun 30, 2010
SOURCE: Display reads paper jam 2 check inside
Open the Top Half of the Copier. The Scanner Section pops open by pushing up.
Underneath the Scanner Section is the Fuser Unit. Check in the Fuser Section, you will find paper Jam in the Fuser Section.
Posted on Aug 27, 2011
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Key disabled message
The Down Arrow and the View buttons are disabled on the T6050 as default because reverse paper feeding is not recommended on the T6050 printer because they only have one pair of tractors which are mounted above the platen. If the printer tries to reverse feed paper, it could cause a paper jam unless the platen gap is open sufficiently to allow the paper to feed down through the gap unhindered.
You can enable reverse paper feeding if you are sure that a paper jam will not occur. This is done as follows. Set the printer to Offline. Press the Mode key: display will show Offline Normal. Press any Arrow key until display shows Offline Oper. Press the Forms/1 key. Press any Arrow key until display shows Oper Forms. Press the CPI/2 key. Press any Arrow key until display shows Forms RevPap. Press the LPI/3 key. Press any Arrow key until display shows RevPap Enabled. Press the Enter key and reverse feeding will be set. Set the printer to Online. Once the reverse paper function has been enabled this option will need to be saved to prevent the setting being lost when the printer is powered off. To save the Menu Configuration; Put the printer OFFLINE Press the MODE button, then press the DOWN ARROW until CONFIG is displayed Press FORMS/1, then press the DOWN ARROW until PRINTER is displayed Press CPI/2, then press the DOWN ARROW until SAVE is displayed Press LPI/3, and with POWERUP shown in the display, press ENTER.
Mar 05, 2012 | Tally Line Matrix T6050 Printer
Hi, if you can help me regarding our Canon IR 8500, it stop working, when you start to turn it on, it is not going to ready position, it is only reservation copy can be made, when you press the start, it...
Check to see if paper is jammed in the connectors for unit 1. Slide out unit one use a small mirror to look at the back side of the connectors for unit one. Black in color rear of unit one left side. Then also use a flashlight to check the machine side receptical for those same connectors. Paper sometimes gets wedged in there after paper jam removal.
Aug 13, 2010 | Canon Office Equipment & Supplies
Note:
Hope that helped
Jun 29, 2010 | Canon ImageRUNNER 3570 Copier/Printer
Canon image runner 2200 has paper jam. I'm missing the manual to check the paper path
On display should be detaild description where the paper is jamed. In duplex, in fixing, in cass.,...
If there is no paper picked up - change rollers from cass., if the paper is got out or pass fixing unit, check the sensor flapper in fixing unit - if respond is slow apply wd40 on it or replace it.
May 18, 2010 | Canon imageRUNNER 2200
Apr 27, 2010 | Samsung CLX-6210FX Laser Printer
Brother mfc8220 jam problem
We looked everywhere for a piece of paper stuck in the machine and couldn't find it. We finally fixed the problem by moving the paper size adjuster in the paper try until it was right up against the paper. If the paper is free to move around in the tray, apparently the machine sees that as a paper jam.
Feb 03, 2009 | Brother MFC-8220 Fax
Paper jam in display.
take out drum unit, look at the bottom side of it. there is a slot opening in the middle. it may have a small piece of paper lodged in that slot, preventing your sensor lever thats under the drum, from working.
hth,
razors
Dec 18, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
Huge paper jam ( piece of a checkbook)
Throw it out and buy a new one! staples won't replace this unit and your gonna have to take it apart and clean the gears.
Also tell your employees to stop reversing the drive gears with paper inside the bucket it only reverses the flow and jams the unit.
I would buy a cross cut shredder next time.
Hope that helps.
Jan 19, 2008 | Techko SH1524CP Shredder
Samsung CLX6220FX COLMON MFC Printer Logo
1,621 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
