Question about Cyber Acoustics CA-3080 Computer Speakers
I HAVE NO SOUND I NEED TO INSTALL HARD WARE AND I DO NOT HAVE TEH CD??
  • 27,725 Answers
What operating system are you using you can download lots of sound drivers from cnetdownload.com
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 27, 2011
When i started my laptop dvd rom produce sound i.e tik tik this is the problem of hard ware or not?if the problem of hard ware what i can solve it? email address:shah_zeb_0007@yahoo.com
If the laptop boot up properly with Windows and when you insert a CD or DVD into the DVD drive and the CD or DVD disc does not open and run then the DVD drive is faulty and needs to be replaced.
Feb 21, 2013 | Computers & Internet
I lost audio or sound on my 3 years old computer,i installed a new sound card, and the wizard wont find the hard ware. please help. Thanks
You need to install the driver for the new audio card. It should be on a CD that came with the new sound card. If you did install the driver from the CD then it may be too old and not functioning properly with either your OS or other hardware drivers that are newer.
You need to get a newer audio driver for this hardware device. You need to figure out who makes the audio card you bought (it should be on both the card itself and the box it came in). Browse to the website of the maker of this card, and go to their support/downloads section. You will need to enter in your model number and then you can download the newest version of the hardware driver. Download this driver and install it on your computer. You will be prompted to restart your computer, you need to do this to get your sound working.
Your speakers will now work!
please rate my solution
Jul 18, 2010 | Acer Aspire T135 PC Desktop
Audio is install but not work?
good day sir, hi, check your speakers audio wire, it migth be open, to test, plug your speakers, on a portable mp3 player, or another pc with sound, if your speakers are good then it could be any of the followings:
  1. your sound driver installed is not correct, or incomplete, locate your CD driver disk and run it again.
  2. If you cannot find your CD, download the driver from this site: http://www.jetway.com.tw/evisn/download/driver/index.htm#865
  3. If you have the CD, and still your sound card does not work, check your sound card status , right click my computer, properties, hard ware, then device manager. look at the sound video and game controller. Ig it has (!) or (?) means that there are hardware conflicts. You need to reinstall windows to solve these conflicts.
  4. If still no audio, check your sound card, or swap out a good sound card and see if it will work.
  5. If still no sound and all sound card seems not to work. get a USB sound card, plug in the USB sound card and thats it. If it has a CD driver run the CD.
Let me know your progress.
Nov 16, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Driver win xp
driver should be on teh vista CD.
open the CD with explore, go to drivers>> and select the dirver you need and copy the folder to the hard drive.
install the device, direct the brower to the device driver folder on the hard drive.
Nov 09, 2008 | HP Pavilion dv6000z Notebook
I need to install my netgear to my desk top
XP or vista usually automatically find hard ware if not install drivers from cd then plug in and turn on your netgear should work
Jul 12, 2008 | Computers & Internet
The sound has gone on my Toshiba Satellite Pro laptop. It started fading gradually a month or two ago and got progressively worse until I could only hear it by plugging headphones into the computer then,...
sounds like the hard ware has failed or died
try removing the sound device in device manager and when you re boot it will re install the driver
but as i said if it was gradually fading away then it will be the actual hard ware has given up
Mar 24, 2008 | Computers & Internet
ERROR AFTER INSTALLING
may i know your sound card pls so that i can find driver for you.
Jan 26, 2008 | Altec Lansing Multimedia Computer Speakers
Problems with suond
if you are having a problem in your sound try to click on the device manager check if your hard ware has a yellow question mark if there is then you need to install the driver for this using the moterboard cd
Dec 17, 2007 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Replacing cd-rom
u need open the cabinet and there should be a serew and remove it and connect teh new one and make sure teh power and date cable the red side of teh power as well as the red side on teh data cable should face same side and start the pc>and put the cd and install soft ware and start using teh dvd and cd>rate me solved if its helps thx
Nov 16, 2007 | HP Compaq dc5100 PC Desktop
NO SOUND DEVICE
u need to check the sound driver on>try this
right click-->my computer-->and properties-->hard ware-->and device manager-->and audio devices-->right click-->properties-->and click-repair-->or trouble shoot>and rebooot teh pc>and try
once u went to the device manager on teh audio device u can see red X mark or some thing which means the driver is not loaded try this rate me solved>
Oct 20, 2007 | Lenovo 3000 J Series 1.80G VBE PC Desktop
Cyber Acoustics CA-3080 Computer Speakers Logo
111 people viewed this question
Top Cyber Acoustics Audio Players & Recorders Experts
mukhtar21 shaikh
mukhtar21 shaikh
Carlos L. Burgos
Carlos L. Burgos
Marvin
Marvin
Are you a Cyber Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
