Question about Maax Living 6642 Hydromax Whirlpool - 102865-004
I want to reprogram my Maxx Living tub. I have had to do it once before with technical help so I know how....just need a chart of what code I need to set to match my configuration (CO1...CO2...C32 etc)
  • l dean Nov 01, 2012
    I have an error code of er06 and blinks
Hello what does f-51 mean on my maytag washer
Tabi, the Maytag folks state the F51 error code has to do with incorrect resistance reading from the motor. Without getting too technical, this can be caused by a number of problems. However, don't get discouraged yet.
A common problem with these washers is that it is relative easy for socks or other small articles of clothing to get ejected from the main tub and end up falling between the metal wash tub and the plastic tub that holds the water. Ultimately this prevents the wash tub from sitting centered and that can cause the F51 error.
Fortunately, this problem is easy to diagnose and fix. If you use a very stiff putty knife, you can release the spring clips that are about 6 inches in from each corner of the front of the machine. Once you have done that, you can raise the top of the machine. You can now use a flashlight and look down between the wash and outer tubs to see if anything is caught in there.
Please let me know if this helps or if you need more information.
Jan 29, 2015 | Maytag Washing Machines
1997 cadillac deville wont accelerate past 15- 20 mph here are the codes i pulled DTC P0603 Control Module Long Term Memory Reset DTC B1552 Keep Alive Memory (KAM) Error DTC B1341 Air Mix Door Two...
P0603 - GM Type Powertrain - Computer and Auxiliary Outputs - ISO/SAE Controlled Description Control Module Long Term Memory Reset Conditions
Cause DTC P0604 not set, key on, then the PCM determined that its calculated checksum that did not match a previous checksum • Refer to code repair chart for instructions on how to replace a PCM and how to reprogram the replacement
or you can ask the 24 hrs live technical support obd2 bmw icom, they will like to help you, good luck
Aug 28, 2013 | Cars & Trucks
E maxx no reverse movment
Hi
The ESC has the ability to have reverse locked out. This is necessary because race tracks require it. Go to the Traxxas web site and download the manual. Reprogram as necessary. Good luck
May 02, 2010 | Traxxas E-maxx Evx-2 Monster Truck
Need shim chart for xz550 vision
Shim chart http://www.ridersofvision.net/Technical/XZ550ValveShimChart.xls
The guys at ridersofvision.net know all there is to know about xz550s
Feb 09, 2010 | 1983 Yamaha XZ 550
How do i get it connected to the tv? and how do u use codes i dont know how to use the codes
To get your Innovage Jumbo Remote Control connected to your TV you need to program it with control codes specific to the brand of your TV. If you know the brand of TV you have you can look up the control codes for that brand in a chart. If you don't know the brand, or if the codes in the chart do not work on your TV, you can perform the auto-search function of your remote to find the codes that work.
To search for the control codes that will work on your TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 08, 2009 | Innovage Jumbo Remote Control
MAXX code E01, jets don't work
well first of all i have to assume that this tub is equipped with jet's on the floor and lights,if not then there's no reason for it those buttons to light up, now if it is equipped with these features and your getting a error code all this means is that this tub need to Re Configured to run this type of system,this is something a tech needs to look at because you wouldn't be getting error codes if the tub was configured wrong the reason your getting error codes is because something isn't plugged in correctly at the control box and the computer detected a fault.
Justin 503-547-3483
Mar 13, 2009 | Maax Calla 6042 Bathtub - 101058-000
Code list for universal remote control-name brand is living solutions
This is what the manual says: Prgoramming the remote using PowerScan: 1. Manually turn OFF the device you wish to program (TV, VCR, DVD) 2. Press and hold the apprpriate device key (TV, VCR, DVD) until the red LED illuminates. This indicates that the Remote is in Programming mode. 3. Press and release the power key. The LED flashes once and stays ON, indicating that the remote is in PowerScan mode. 4. Press either the CH+ or CH- key Button repeatedly until the device switches ON. The CH+ Button searches upward in the code list, while the CH- key searches downward. (So since I have a Toshiba tv, I elected to search upward to get to 'T' faster. 5. When the device turns on, press and release the OK Button to store the new code and exit. To exit without setting the code, press the GO BACK Button. NOTE: If you press CH+ or CH- again after the device turns on, the device will not be programmed; you will need to repeat Steps 1-5 again. 6. Press and other operable key (VOL+/VOL-). If the device responds, no further programming is required. If not, repeat Steps 1-5.
Jun 08, 2008 | Big Button TV Universal Remote
Maax Living 6642 Hydromax Whirlpool - 102865-004 Logo
66 people viewed this question
Top Maax Home Experts
Mike
Tim Whalen
Tim Hunt
Tim Hunt
Are you a Maax Home Expert? Answer questions, earn points and help others
