Question about Nelson Sprinkler: Traveling Tractor
Water is leaking from the bottom gear housing. Do I need a gasket? or some other sealer? Can I get a repair manual?
  • 43,501 Answers
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
Posted on May 19, 2011
Water leaking beside thermostat houseing
Replace the corroded housing and you will have to replace the rusted welsh plug in the rear of the engine . If it is from inside the bell housing it means gear box out and fly wheel / flex plate off
Jan 25, 2014 | 2002 Dodge Stratus
How to change thermostat housing leake in 06 dodge charger 2.7L
Purchase a new thermostat including ask for thermostat housing gasket...inspect the housing for cracks as removed...use permatex blue or red gasket sealer/maker on both contact parts when reassembling...Of course be sure it is not the hose connection that is leaking at the housing...Is your water temperature remaining normal? How often have you been adding water?
Oct 31, 2013 | Vehicle Parts & Accessories
1998 cadillac has head gasket leak, need to repair with some kind of gasket repair or sealer kit.
Use Bars leak brand head gasket sealer. There are other good products out there as well, contact a local NAPA or Carquest for suggestions on what works best.
Jul 25, 2012 | Cars & Trucks
Chev s10 1998 over heating water in oil can i do a quick fix with gasket sealer an still drive truck until i can afford to replace gaskets
Over the years I have seen quite a number of sealers advertised to repair gaskets etc. There are newer ones out that make the same claims (also expensive @ about $100). Though it is possible that they work, I have no idea for how long. As always, the best cure for a cylinder head gasket problem is still to actually do the repair.
Regardless of how you correct the problem, make certain that you drain the oil and filter or you will be looking at a bearing failure shortly.
Feb 04, 2011 | Chevrolet S 10 Cars & Trucks
Keeps over heating, has water and coolant not sure where the thermostat is located because i don't have the manual. oil has been added but i dont have any other clues besides the water pump. Any advice?
Thermostat
Removal & Installation
To Remove:
  1. Before servicing the vehicle refer to the precautions at the beginning of
    this section.
  2. Partially drain the coolant, (until the level is below the thermostat).
  3. Remove or disconnect the following:
    • The air cleaner and duct assembly
    • The crossover exhaust pipe
    • The radiator hose from the thermostat housing
    • The thermostat housing bolts
    • Any remaining sealer from the bolt threads
    • The gasket
    • The thermostat
To Install:
  1. Install or connect the following:
    • The thermostat
    • The gasket
      NOTE: Apply RTV sealer, GM P/N 1052366 or the equivalent, to the
      thermostat housing bolt threads.
      1. Torque to: 18 ft. lbs. (25 Nm)
    • The radiator hose to the thermostat housing
    • The coolant
  2. Thoroughly inspect the cooling system for leaks.
Oct 07, 2010 | 2003 Chevrolet Venture Passanger
Water pump
NOT HARD BUT YOU HAVE TO DRAIN COOLANT OUT OF SYSTEM.CATCHING IT IN A DRAIN PAN .THE 2.4 ENGINE YOU HAVE TO REMOVE. OXYGEN SENSOR THE EXHAUST MANIFOLD HEAT SHIELD.REMOVE COOLANT INLET HOUSING BOLT THROUGH THE EXHAUST MANIFOLD .REMOVE EXHAUST MANIFOLD BRACE TO MANIFOLD BOLT.REMOVE TO EXHAUST TO PIPE STUDS.REMOVE COOLANT INLET HOUSING TO WATER PUMP COVER BOLT.REMOVE EXHAUST PIPE FROM THE EXHAUST MANIFOLD BY PULLING IT DOWNWARD.REMOVE COOLANT INLET PIPE FROM THE OIL PAN.REMOVE BRAKE VACUUM PIPE FROM THE CAMSHAFT HOUSING.REMOVE EXHAUST MANIFOLD FROM THE CYLINDER HEAD.REMOVE HEATER HOSE FROM THE HEATER OUTLET PIPE.REMOVE THE TIMING CHAIN COVER AND TENSIONER.REMOVE WATER PUMP COVER TO ENGINE BOLTS.REMOVE 3 WATER PUMP TO TIMING CHAIN HOUSING NUTS.REMOVE THE WATER PUMP AND COVER ASSEMBLY.THE 3.1 AND 3.4 ENGINES DRAIN COOLING SYSTEM .REMOVE DRIVE BELT.REMOVE WATERPUMP PULLEY TO REMOVE PULLEY YOU NEED A LONG SKINNEY SCREW DRIVER TO HOLD PULLEY FROM TURNING WHILE YOU REMOVE THE BOLTS.THEN REMOVE WATER PUMP.CLEAN OLD GASKET MATERIAL OFF ENGINE BLOCK WHERE WATER PUMP GOES.BECAREFUL NOT TO SCRATCH PUMP SURFACE ON ENGINE BLOCK.YOU CAN BUY CAN OF GASKET REMOVER AT ANY AUTO PARTS STORES. THEN WHEN YOU PUT ON NEW WATER PUMP.BESURE TO COAT BOTH SIDES OF THE WATER PUMP GASKET WITH GASKET SEALER .BEFORE PUTTING GASKET SEALER ON WATER PUMP GASKET.BESURE TO GET HOLES MATCH UP RIGHT ON WATER PUMP AND GASKET.WHEN YOU GET IN PUMP IN PLACE TORQUE IT AT 89 INCH POUNDS AND PULLEY BOLTS 18 FT LBS.THE 2.4 ENGINE BEST TO HAVE** HAYNES REPAIR MANUAL ** BECAUSE REMOVING THE WATER PUMP YOU ARE DEALING WITH THE TIMING CHAIN AND TENSIONER.YOU NEED ALL THE EXHAUST BOLTS TORQUE SPECS.AND WHEN YOU COMPLETE WATER PUMP FIX.ADD COOLANT.CRANK ENGINE.CHECK FOR LEAKS.BLEED COOLANT SYSTEM.
Jun 14, 2010 | 1999 Pontiac Grand Am GT
98 Ford Explorer SOHC 4.0 V6 Water Leak
take it to a mechinc shop and have them do a pressure test
May 16, 2010 | 1998 Ford Explorer
Water pump still leaks 92 cadillac deville
yes always use gasket sealer on both sides of the gasket. and make sure the old gasket is completely removed but do not use a chisel ar anything as you will leave gouges in the metal and cause a leak. Best to clean it is with some sand paper and just take your time. And just a thougtht but all i use is the black gasket sealer. It seems to wwork the best.
Jul 28, 2009 | 1992 Cadillac DeVille
Nelson Sprinkler:  Traveling Tractor Logo
439 people viewed this question
Top Nelson Garden Experts
Dennis
Mike Squire
Phil Walker
Phil Walker
Are you a Nelson Garden Expert? Answer questions, earn points and help others
