Question about Dryers
WHIRLPOOL,,,,,,,,,,,,,WGD5300VWO DRUM WONT TURN,,,,,,,,,,,,,,HOT AIIR IS BLOWING OK NO WEIRD NOISE OUT OF DRUM JUST WONT TURN WITH MOTOR,,,,,,,,,,,,, was brand new 13 mons ago,,,,,,,,,,,,,,,,,,,,,,,1 yr waranty just expired,,,,SUCKS/FIGURES Im lousy with repairs,,,,,,,,,,,,,,,,,,,,,,,whats my projected repair costs?? scott
  • Dryers Master
  • 2,128 Answers
The belt broke.whatch this video and you'll see how to fix it. YouTube - Dryer Belt Replacement (part #341241) ..the belt is around 20 dollars
Posted on Mar 27, 2011
Testimonial: "AFTER WATCHING VIDEO, HAD THE PROBLEM FIXED IN 20 MINUTES. IDLER PULLEY CAME OFF. REATTACHED IT AND WORKS PERFECT. THANKYOU VERY MUCH."
  • carlysimps Mar 28, 2011
    THANKYOU VERY MUCH. VIDEO WAS A BIG HELP. FIXED THE PROBLEM WITH IT.
  • Sal DeAngelo Apr 04, 2011
    your welcome,and glad i could help.
Dryer gets hot but drum wont turn
When the drum doesn't turn the belt is most often the cause. But it could also be the timer. Suggest you try to rotate the drum and see if you can feel or hear belt and motor resistance. But unfortunately you are going to have to open up the machine to be sure.
Jul 01, 2011 | Whirlpool Dryers
My dryer is producing heat but is not drying, i am drying the same size load i usually do on the same cycle. the lent is cleaned out, and the oustide vent is blowing hot air. why are my clothes not getting...
make sure that all the seals are ok, door,front and back drum seal, blower housing seal(inside dryer). also consider that depending on washer type if you overload or have a worn drive belt in washer it will take twice the time to dry. also make sure that the dryer drum tumble. open door,press door switch and start dryer to see if drum turn. lastly disconnect vent pipe behind dryer and dry a load. if it dry ok then you have a partial blockage. you can also have a weak heating element.
Feb 11, 2011 | Whirlpool WED5300S Electric Dryer
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Heating but drum does not turn
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley. If you have to replace your drum belt and if you have a front loading machine. Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum. Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn. While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them. I will include these two websites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7.
Good luck, I hope this helps Please do not forget to rate me Thank you
Dec 26, 2009 | Estate TGDS840JQ Gas Dryer
Whirlpool washing machine won't spin
its probably your motor coupling u have to take pump and motor off to get to it
Apr 15, 2009 | Washing Machines
Whirlpool top load washer LSQ9610LG0 wont spin but makes noise
HI thanks for your question. the part that failed is called the motor coupling. it s located on the motor and the transmission. if you need help to replace come on back. but that's the part you need to change. thanks
Oct 14, 2008 | Whirlpool LSQ9610L Top Load Washer
Dryers Logo
362 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
