Question about Car Audio & Video
Arry.dawesthe fuse box is not labeled and i want to put a radio in a car that never had a radio . what fuse do i do i attach the hot wire to
  • 3 Answers
If your car has never had a radio you can use a power tester to see what comes on in the fuse box when the key is on but you'll probaly have to run a constant power wire to the battery post itself.
Posted on Mar 28, 2011
I have a 2002 Ford Escort zx2 I replace the battery 3 days ago and my radio will still not turn on... any suggestions??
Check the radio fuse in the fuse box. Maybe its blown, otherwise it may be a failure of wiring or the radio itself. Check the wiring before removing the radio to check the back of it. Check the wiring in the attached link:
2002 Ford Escort ZX2 Car Radio Stereo Audio Wiring Diagram
Feb 09, 2015 | 2002 Ford Escort
Is the fuse box suppose to be switched power? i just installed an aftermarket radio and it does not turn off after i remove the key. i have to turn off the radio. i read there is no switched power in the...
About half of your fuse block is switched and the other half isn't. Use a test light and check the fuses with the key on and then with the key off to find a good place to make your connection. Don't use any fuses that connect to the computer (usually red 10Amp). When you make the hookup. after finding a good fuse to use (generally 20A or higher), pull the fuse out and check to see which side is hot. Connect to that side and use an in-line fuse in the wire to the radio. You also need to attach a second wire from the radio in most cases to run the memory and clock. That wire attaches to a "always on" fuse attached the same way as the other one.
Jul 18, 2011 | 2005 Chevrolet Equinox
My radio does not go on clock works but radio does work ford f 150
usually there are 2 -12 volt leads on the radio...one that is hot all the time, and one that is switched by the ignition switch...it sounds like the hot all the time lead is working because the clock works...the hot lead is for the clock and for station memory backup.....is seems like the switched power to the radio is not getting power...check the fuses in the fuse box ..the one labeled radio sould be for the switched connection
May 26, 2011 | 2004 Ford F150
Need diagram for 2000 kia sephia wiring harness to the radio
i found one in a haynes book covers sephia and spectra 94 to 04 .i have no idea how to scan this an attach . theres not much to the diagram you have an audio 10A fuse hot in acc or run grn wire .you also have a room fuse 10A hot at all times pnk wire .both are in the i/p fuse block . in the fuse relay box you also have tail lh fuse 10A hot with lights on blu/wht wire the rest is just radio to speakers and antena . wish i could be more help
Aug 07, 2010 | 2000 Kia Sephia
How to run the wires for the stero
Take heed! Red is normally the hot wire. From the unit it goes to a fused 12 volt circuit. Either white or black can be ground wires. If you put current to rhe black or white you chance burning up the radio. Black or white needs to be attached to a metal piece of the dashboard. If you have a meter, there should be continuity to grnd and metal. Good luck
Dec 04, 2009 | 2001 Pontiac Grand Am SE
Car will not start after radio was removed.
possible blown fuse from hot wire touching inside dash ; check fuses in fuse box
Apr 19, 2009 | 1994 Volkswagen Jetta
Generac rv altenator wiring
white is neutral black is hot and green is ground
Feb 14, 2009 | Honda 6370C - Parallel Power Kit For ...
91 accord wagon-where can i find another ''hot'' unswitched wire
Trace the yellow wire back to the fuse box located at the side kick panel under the dashboard and place a new wire to replace the " short" wire. The clock wire may share the same wire for your radio. You can confirm this by looking at the label at the fuse box either located at the side kick panel as mentioned before or inside engine compartment, under the hood.
Jan 05, 2009 | 1991 Honda Accord
Car Stereo
Elliott, You can pick up this ignition "hot" connection on the fuse box at the hot side of any fuse labeled accessory or of course radio or stereo. Most fuse boxes have a male connection just for this. Barring that you can hook it along side any component on the car that only works with the key or or better yet something that only works with the key switch set to accessory.
Dec 23, 2007 | Car Audio & Video
Car Audio & Video Logo
21 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
