Question about Konica Office Equipment & Supplies
Our Konica Minolta BIZ HUB C10 message in window is MEM.RX. Can you explain what this means. Thanks
    Sergeant:
  • 192 Answers
In the Fax/E-mail - Fax Configuration - Reception Operation page, set-
tings for receiving faxes can be specified.Memory RX Mode:
Select whether to allow ("On") memory reception or not
("Off"). In cases when confidential faxes are being
received, the received document can be stored in the
memory and printed at a specified time or when memory
reception is set to "Off". A password can be set to spec-
ify the starting time or ending time of memory reception,
or to cancel the function. The set starting time and end-
ing time are valid every day until memory reception is
turned off.
Choices: On, Off
Default: Off
Configuration Menu Equivalent:
RX SETTING - MEMORY RX MODE
Posted on Mar 27, 2011
I was changing the toner of Konica Minolta biz hub 163, and it shows a message that reads service call C0070. Please, what will I do to continue my work?
Sir/Mam,
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 13, 2016 | Konica Minolta Office Equipment & Supplies
Wanted suitable konica minolta black and white copier to be installed in a school
First for a school you will need to know the volume of copies you are going to use per month.Then go from there, there so many segments.For example 30k to 40k per month would put you in a segment 4 something like a konica Minolta Biz Hub 601 or Biz Hub 750
Sep 07, 2010 | Konica Minolta Bizhub 222 Black and White...
Print Booklets with Konica Minolta Biz Hub C650 Printer
Select Print, and then "Properties"
Layout Tab - select Print Type: Booklet
Basic Tab - Select original size and then size of PAPER to be printed. 11x17 is standard 8.5x11 book when folded.
Finish Tab - select saddle stitch.
Thats it, easy as pie.
Jan 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Dec 06, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
147 people viewed this question
Top Konica Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
NOEL
NOEL
Andrew Taylor
Andrew Taylor
Are you a Konica Office Equipment and Supply Expert? Answer questions, earn points and help others
